[PATCH 18/29] ARM BSPs: Simplify bsp_specs
Tue Dec 19 00:01:14 UTC 2017
Updates #3520.
 c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs   | 6 +-----
 c/src/lib/libbsp/arm/atsam/bsp_specs              | 6 +-----
 c/src/lib/libbsp/arm/beagle/bsp_specs             | 6 +-----
 c/src/lib/libbsp/arm/csb336/bsp_specs             | 6 +-----
 c/src/lib/libbsp/arm/csb337/bsp_specs             | 6 +-----
 c/src/lib/libbsp/arm/edb7312/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/gdbarmsim/bsp_specs          | 6 +-----
 c/src/lib/libbsp/arm/gumstix/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/imx/bsp_specs                | 6 +-----
 c/src/lib/libbsp/arm/lm3s69xx/bsp_specs           | 6 +-----
 c/src/lib/libbsp/arm/lpc176x/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/lpc24xx/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/lpc32xx/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/raspberrypi/bsp_specs        | 6 +-----
 c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs    | 6 +-----
 c/src/lib/libbsp/arm/rtl22xx/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/shared/startup/linkcmds.base | 1 +
 c/src/lib/libbsp/arm/smdk2410/bsp_specs           | 6 +-----
 c/src/lib/libbsp/arm/stm32f4/bsp_specs            | 6 +-----
 c/src/lib/libbsp/arm/tms570/bsp_specs             | 6 +-----
 c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs        | 6 +-----
 21 files changed, 21 insertions(+), 100 deletions(-)
diff --git a/c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs b/c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs
index f1a3265..47dd31d 100644
--- a/c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs
+++ b/c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs
@@ -1,13 +1,9 @@
 %rename endfile old_endfile
 %rename startfile old_startfile
-%rename link old_link
 *startfile:
 %{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
 *endfile:
 %{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/arm/atsam/bsp_specs b/c/src/lib/libbsp/arm/atsam/bsp_specs
--- a/c/src/lib/libbsp/arm/atsam/bsp_specs
+++ b/c/src/lib/libbsp/arm/atsam/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/beagle/bsp_specs b/c/src/lib/libbsp/arm/beagle/bsp_specs
--- a/c/src/lib/libbsp/arm/beagle/bsp_specs
+++ b/c/src/lib/libbsp/arm/beagle/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/csb336/bsp_specs b/c/src/lib/libbsp/arm/csb336/bsp_specs
--- a/c/src/lib/libbsp/arm/csb336/bsp_specs
+++ b/c/src/lib/libbsp/arm/csb336/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/csb337/bsp_specs b/c/src/lib/libbsp/arm/csb337/bsp_specs
--- a/c/src/lib/libbsp/arm/csb337/bsp_specs
+++ b/c/src/lib/libbsp/arm/csb337/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/edb7312/bsp_specs b/c/src/lib/libbsp/arm/edb7312/bsp_specs
--- a/c/src/lib/libbsp/arm/edb7312/bsp_specs
+++ b/c/src/lib/libbsp/arm/edb7312/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/bsp_specs b/c/src/lib/libbsp/arm/gdbarmsim/bsp_specs
--- a/c/src/lib/libbsp/arm/gdbarmsim/bsp_specs
+++ b/c/src/lib/libbsp/arm/gdbarmsim/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/gumstix/bsp_specs b/c/src/lib/libbsp/arm/gumstix/bsp_specs
--- a/c/src/lib/libbsp/arm/gumstix/bsp_specs
+++ b/c/src/lib/libbsp/arm/gumstix/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/imx/bsp_specs b/c/src/lib/libbsp/arm/imx/bsp_specs
--- a/c/src/lib/libbsp/arm/imx/bsp_specs
+++ b/c/src/lib/libbsp/arm/imx/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/bsp_specs b/c/src/lib/libbsp/arm/lm3s69xx/bsp_specs
--- a/c/src/lib/libbsp/arm/lm3s69xx/bsp_specs
+++ b/c/src/lib/libbsp/arm/lm3s69xx/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/lpc176x/bsp_specs b/c/src/lib/libbsp/arm/lpc176x/bsp_specs
--- a/c/src/lib/libbsp/arm/lpc176x/bsp_specs
+++ b/c/src/lib/libbsp/arm/lpc176x/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/lpc24xx/bsp_specs b/c/src/lib/libbsp/arm/lpc24xx/bsp_specs
--- a/c/src/lib/libbsp/arm/lpc24xx/bsp_specs
+++ b/c/src/lib/libbsp/arm/lpc24xx/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/lpc32xx/bsp_specs b/c/src/lib/libbsp/arm/lpc32xx/bsp_specs
--- a/c/src/lib/libbsp/arm/lpc32xx/bsp_specs
+++ b/c/src/lib/libbsp/arm/lpc32xx/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/raspberrypi/bsp_specs b/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
--- a/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
+++ b/c/src/lib/libbsp/arm/raspberrypi/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs b/c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/rtl22xx/bsp_specs b/c/src/lib/libbsp/arm/rtl22xx/bsp_specs
--- a/c/src/lib/libbsp/arm/rtl22xx/bsp_specs
+++ b/c/src/lib/libbsp/arm/rtl22xx/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/shared/startup/linkcmds.base b/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
index 61f2b6f..c631454 100644
--- a/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
+++ b/c/src/lib/libbsp/arm/shared/startup/linkcmds.base
@@ -25,6 +25,7 @@ OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
 OUTPUT_ARCH (arm)
 ENTRY (_start)
+STARTUP (start.o)
  * Global symbols that may be defined externally
diff --git a/c/src/lib/libbsp/arm/smdk2410/bsp_specs b/c/src/lib/libbsp/arm/smdk2410/bsp_specs
--- a/c/src/lib/libbsp/arm/smdk2410/bsp_specs
+++ b/c/src/lib/libbsp/arm/smdk2410/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/stm32f4/bsp_specs b/c/src/lib/libbsp/arm/stm32f4/bsp_specs
--- a/c/src/lib/libbsp/arm/stm32f4/bsp_specs
+++ b/c/src/lib/libbsp/arm/stm32f4/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
diff --git a/c/src/lib/libbsp/arm/tms570/bsp_specs b/c/src/lib/libbsp/arm/tms570/bsp_specs
index e0ee7b9..9c4b57c 100644
--- a/c/src/lib/libbsp/arm/tms570/bsp_specs
+++ b/c/src/lib/libbsp/arm/tms570/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N -EB}
 *endfile:
 %{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs b/c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs
--- a/c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs
@@ -1,13 +1,9 @@
 *startfile:
-*link:
 *endfile:
1.8.3.1
