[PATCH 26/29] shsim: Simplify bsp_specs
Tue Dec 19 00:01:22 UTC 2017
This bsp_specs included non-standard logic to pass endian arguments
to the linker. These should not be necessary. If they are, it is a
bug in the sh gcc target. The code was "%{ml:-EL}%{mb:-EB}"
Also the file linkcmds.sim was not referenced and was deleted.
Updates #3250.
 c/src/lib/libbsp/sh/shsim/Makefile.am          |   1 -
 c/src/lib/libbsp/sh/shsim/bsp_specs            |   6 +-
 c/src/lib/libbsp/sh/shsim/preinstall.am        |   4 -
 c/src/lib/libbsp/sh/shsim/startup/linkcmds     |   1 +
 c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim | 232 -------------------------
 5 files changed, 2 insertions(+), 242 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim
diff --git a/c/src/lib/libbsp/sh/shsim/Makefile.am b/c/src/lib/libbsp/sh/shsim/Makefile.am
index 53097af..dbe089f 100644
--- a/c/src/lib/libbsp/sh/shsim/Makefile.am
+++ b/c/src/lib/libbsp/sh/shsim/Makefile.am
@@ -21,7 +21,6 @@ libbspstart_a_SOURCES = start/start.S
 project_lib_DATA = start.$(OBJEXT)
 dist_project_lib_DATA += startup/linkcmds
-dist_project_lib_DATA += startup/linkcmds.sim
 noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/sh/shsim/bsp_specs b/c/src/lib/libbsp/sh/shsim/bsp_specs
index 70c5ecb..87638cc 100644
--- a/c/src/lib/libbsp/sh/shsim/bsp_specs
+++ b/c/src/lib/libbsp/sh/shsim/bsp_specs
@@ -1,13 +1,9 @@
 %rename endfile old_endfile
 %rename startfile old_startfile
-%rename link old_link
 *startfile:
 %{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N} %{ml:-EL}%{mb:-EB}
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
 *endfile:
 %{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/sh/shsim/preinstall.am b/c/src/lib/libbsp/sh/shsim/preinstall.am
index 57fe5d3..738a41b 100644
--- a/c/src/lib/libbsp/sh/shsim/preinstall.am
+++ b/c/src/lib/libbsp/sh/shsim/preinstall.am
@@ -69,7 +69,3 @@ $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
 PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
-$(PROJECT_LIB)/linkcmds.sim: startup/linkcmds.sim $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.sim
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.sim
diff --git a/c/src/lib/libbsp/sh/shsim/startup/linkcmds b/c/src/lib/libbsp/sh/shsim/startup/linkcmds
index 3f7ea0e..41c7245 100644
--- a/c/src/lib/libbsp/sh/shsim/startup/linkcmds
+++ b/c/src/lib/libbsp/sh/shsim/startup/linkcmds
@@ -19,6 +19,7 @@
 OUTPUT_ARCH(sh)
 ENTRY(_start)
+STARTUP(start.o)
 _RamBase = DEFINED(_RamBase) ? _RamBase : 0x00000000;
 _RamSize = DEFINED(_RamSize) ? _RamSize : 16M;
diff --git a/c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim b/c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim
deleted file mode 100644
index c9f9ad5..0000000
--- a/c/src/lib/libbsp/sh/shsim/startup/linkcmds.sim
+++ /dev/null
@@ -1,232 +0,0 @@
- * Memory layout for an SH 7032 with main memory in area 0
- * NOTES:
- * + All RAM/ROM areas are mapped onto area 0, because gdb's simulator
- * is not able to simulate memory areas but area 0. Area 5 (on-chip
- * peripherials) can not be mapped onto area 0 and will cause SIGILL
- * exceptions.
- * + Assumed to be compatible with other SH-cpu family members (eg. SH7045)
- *  Authors: Ralf Corsepius (corsepiu at faw.uni-ulm.de)
- *  COPYRIGHT (c) 2001, Ralf Corsepius, Ulm, Germany
- *  This program is distributed in the hope that it will be useful,
- *  but WITHOUT ANY WARRANTY; without even the implied warranty of
- *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-OUTPUT_ARCH(sh)
-ENTRY(_start)
-_RamBase = DEFINED(_RamBase) ? _RamBase : 0x00040000;
-_RamSize = DEFINED(_RamSize) ? _RamSize : 256K;
-_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
-MEMORY
-  rom           : o = 0x00000000, l = 128k
-  onchip_peri	: o = 0x05000000, l = 512
-  ram           : o = 0x00040000, l = 256k
-  onchip_ram    : o = 0x00080000, l = 8k
-SECTIONS
-  /* boot vector table */
-  .monvects 0x00000000 (NOLOAD) :
-    _monvects = . ;
-  } > rom
-  /* monitor play area */
-  .monram 0x00040000 (NOLOAD) :
-  _ramstart = .;
-  } > ram
-  /* monitor vector table */
-  .vects   0x00042000 (NOLOAD) : {
-    _vectab = . ;
-    *(.vects);
-  /* Read-only sections, merged into text segment: */
-  . = 0x00044000 ;
-  .interp        : { *(.interp) 	}
-  .hash          : { *(.hash)		}
-  .dynsym        : { *(.dynsym)		}
-  .dynstr        : { *(.dynstr)		}
-  .gnu.version   : { *(.gnu.version)	}
-  .gnu.version_d : { *(.gnu.version_d)	}
-  .gnu.version_r : { *(.gnu.version_r)	}
-  .rela.dyn       :
-      *(.rela.init)
-      *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
-      *(.rela.fini)
-      *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
-      *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
-      *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
-      *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
-      *(.rela.ctors)
-      *(.rela.dtors)
-      *(.rela.got)
-      *(.rela.sdata .rela.sdata.* .rela.gnu.linkonce.s.*)
-      *(.rela.sbss .rela.sbss.* .rela.gnu.linkonce.sb.*)
-      *(.rela.sdata2 .rela.sdata2.* .rela.gnu.linkonce.s2.*)
-      *(.rela.sbss2 .rela.sbss2.* .rela.gnu.linkonce.sb2.*)
-      *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
-    } >ram
-  .rel.text      :
-    { *(.rel.text) *(.rel.gnu.linkonce.t*) }
-  .rel.data      :
-    { *(.rel.data) *(.rel.gnu.linkonce.d*) }
-  .rel.rodata    :
-    { *(.rel.rodata) *(.rel.gnu.linkonce.r*) }
-  .rel.got       : { *(.rel.got)		}
-  .rel.ctors     : { *(.rel.ctors)	}
-  .rel.dtors     : { *(.rel.dtors)	}
-  .rel.init      : { *(.rel.init)	}
-  .rel.fini      : { *(.rel.fini)	}
-  .rel.bss       : { *(.rel.bss)		}
-  .rel.plt       : { *(.rel.plt)		}
-  .init          : { *(.init)	} =0
-  .plt      	 : { *(.plt)	}
-  .text   .   	 :
-    *(.text*)
-    *(.stub)
-     * Special FreeBSD sysctl sections.
-    . = ALIGN (16);
-    ___start_set_sysctl_set = .;
-    *(set_sysc*);   /* set_sysctl_* but name is truncated by SH-coff */
-    ___stop_set_sysctl_set = ABSOLUTE(.);
-    *(set_doma*);   /* set_domain_* but name is truncated by SH-coff */
-    *(set_pseu*);   /* set_pseudo_* but name is truncated by SH-coff */
-    /* .gnu.warning sections are handled specially by elf32.em.  */
-    *(.gnu.warning)
-    *(.gnu.linkonce.t*)
-  } > ram
-  .fini           :
-    KEEP (*(.fini))
-  } =0
-  _etext = .;
-  PROVIDE (etext = .);
-  .rodata  .  : { *(.rodata*) .rodata.* KEEP (*(SORT(.rtemsroset.*))) *(.gnu.linkonce.r*) } > ram
-  .rodata1 .  : { *(.rodata1) } > ram
-  .tdata : {
-    __TLS_Data_begin = .;
-    *(.tdata .tdata.* .gnu.linkonce.td.*)
-    __TLS_Data_end = .;
-  } > ram
-  .tbss : {
-    __TLS_BSS_begin = .;
-    *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
-    __TLS_BSS_end = .;
-  } > ram
-  __TLS_Data_size = __TLS_Data_end - __TLS_Data_begin;
-  __TLS_Data_begin = __TLS_Data_size != 0 ? __TLS_Data_begin : __TLS_BSS_begin;
-  __TLS_Data_end = __TLS_Data_size != 0 ? __TLS_Data_end : __TLS_BSS_begin;
-  __TLS_BSS_size = __TLS_BSS_end - __TLS_BSS_begin;
-  __TLS_Size = __TLS_BSS_end - __TLS_Data_begin;
-  __TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
-  /* Adjust the address for the data segment.  We want to adjust up to
-     the same address within the page on the next page up.  */
-  . = ALIGN(128) + (. & (128 - 1));
-  .data  .  :
-    *(.data*)
-    KEEP (*(SORT(.rtemsrwset.*)))
-    *(.gcc_exc*)
-    ___EH_FRAME_BEGIN__ = .;
-    *(.eh_fram*)
-    ___EH_FRAME_END__ = .;
-    LONG(0);
-    *(.gcc_except_table*)
-    *(.gnu.linkonce.d*)
-    CONSTRUCTORS
-  } > ram
-  .data1  . : { *(.data1) }
-  .ctors  .       :
-    ___ctors = .;
-    *(.ctors)
-    ___ctors_end = .;
-  .dtors  .       :
-    ___dtors = .;
-    *(.dtors)
-    ___dtors_end = .;
-  .got     .      : { *(.got.plt) *(.got) }
-  .dynamic .      : { *(.dynamic) }
-  /* We want the small data sections together, so single-instruction offsets
-     can access them all, and initialized data all before uninitialized, so
-     we can shorten the on-disk segment size.  */
-  .sdata   .  : { *(.sdata) }
-  _edata  =  .;
-  PROVIDE (edata = .);
-  __bss_start = .;
-  .sbss    .  : { *(.sbss*) *(.scommon) }
-  .bss     .  :
-   *(.dynbss)
-   *(.bss .bss* .gnu.linkonce.b*)
-   *(COMMON)
-  } > ram
-  _end = . ;
-  PROVIDE (end = .);
-  _WorkAreaBase = . ;
-  . = 0x00080000 ;
-  _CPU_Interrupt_stack_low  = 0x00080000 ;
-  _CPU_Interrupt_stack_high = _CPU_Interrupt_stack_low + 4096 ;
-  /* Stabs debugging sections.  */
-  .stab 0 : { *(.stab) }
-  .stabstr 0 : { *(.stabstr) }
-  .stab.excl 0 : { *(.stab.excl) }
-  .stab.exclstr 0 : { *(.stab.exclstr) }
-  .stab.index 0 : { *(.stab.index) }
-  .stab.indexstr 0 : { *(.stab.indexstr) }
-  .comment 0 : { *(.comment) }
-  /* DWARF debug sections.
-     Symbols in the DWARF debugging sections are relative to the beginning
-     of the section so we begin them at 0.  */
-  /* DWARF 1 */
-  .debug          0 : { *(.debug) }
-  .line           0 : { *(.line) }
-  /* GNU DWARF 1 extensions */
-  .debug_srcinfo  0 : { *(.debug_srcinfo) }
-  .debug_sfnames  0 : { *(.debug_sfnames) }
-  /* DWARF 1.1 and DWARF 2 */
-  .debug_aranges  0 : { *(.debug_aranges) }
-  .debug_pubnames 0 : { *(.debug_pubnames) }
-  /* DWARF 2 */
-  .debug_info     0 : { *(.debug_info) }
-  .debug_abbrev   0 : { *(.debug_abbrev) }
-  .debug_line     0 : { *(.debug_line) }
-  .debug_frame    0 : { *(.debug_frame) }
-  .debug_str      0 : { *(.debug_str) }
-  .debug_loc      0 : { *(.debug_loc) }
-  .debug_macinfo  0 : { *(.debug_macinfo) }
-  /* SGI/MIPS DWARF 2 extensions */
-  .debug_weaknames 0 : { *(.debug_weaknames) }
-  .debug_funcnames 0 : { *(.debug_funcnames) }
-  .debug_typenames 0 : { *(.debug_typenames) }
-  .debug_varnames  0 : { *(.debug_varnames) }
-  .stack 0x00081ff0 : { _stack = .; *(.stack) } /* > onchip_ram */
-  /* These must appear regardless of  .  */
1.8.3.1
