sparc-rtems5-gcc Internal Compiler Error
Joel Sherrill
joel at rtems.org
Tue Dec 19 16:28:59 UTC 2017
Thanks. I missed the update to the RSB somehow. Rebuilding now.
-joel
On Tue, Dec 19, 2017 at 9:47 AM, Daniel Cederman <cederman at gaisler.com>
wrote:
> Hi Joel,
> Yes, there was a bug in one of the errata fixes. It has been fixed now,
> see https://gcc.gnu.org/ml/gcc-patches/2017-12/msg00593.html and
> https://devel.rtems.org/ticket/3242#comment:4.
> Daniel C
> On 2017-12-19 16:18, Joel Sherrill wrote:
>> Hi
>> Has anyone else seen this?
>> sparc-rtems5-gcc --pipe -DHAVE_CONFIG_H -I..
>> -I../../cpukit/../../../ut700/lib/include -mcpu=leon3 -mfix-ut700 -O2
>> -g -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
>> src/libscore_a-objectgetnoprotection.o -MD -MP -MF
>> src/.deps/libscore_a-objectgetnoprotection.Tpo -c -o
>> src/libscore_a-objectgetnoprotection.o `test -f
>> 'src/objectgetnoprotection.c' || echo '../../../../../../rtems/c/src
>> /../../cpukit/score/'`src/objectgetnoprotection.c
>> ../../../../../../rtems/c/src/../../cpukit/score/src/objectgetnoprotection.c:
>> In function '_Objects_Get_no_protection':
>> ../../../../../../rtems/c/src/../../cpukit/score/src/objectgetnoprotection.c:48:1:
>> internal compiler error: Segmentation fault
>> 0x8823cf crash_signal
>> ../../gcc-7.2.0/gcc/toplev.c:337
>> 0x5d5211 active_insn_p
>> ../../gcc-7.2.0/gcc/emit-rtl.c:3525
>> 0x5d5211 next_active_insn(rtx_insn*)
>> ../../gcc-7.2.0/gcc/emit-rtl.c:3538
>> 0xaf6d20 sparc_do_work_around_errata
>> ../../gcc-7.2.0/gcc/config/sparc/sparc.c:1056
>> 0xaf6d20 execute
>> ../../gcc-7.2.0/gcc/config/sparc/sparc.c:1482
>> $ sparc-rtems5-gcc --version
>> sparc-rtems5-gcc (GCC) 7.2.0 20170814 (RTEMS 5, RSB
>> 7034d65872831fdc5221a01ec3c281f95b97483b, Newlib 2.5.0.20170922)
>> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171219/bdd22c14/attachment.html>
