[PATCH 00/12] m68k bsp_specs simplification
Tue Dec 19 18:27:35 UTC 2017
This set of patches simplifies the bsp_specs files across the
m68k BSPs.
This leaves the PowerPC BSPs for this pass.
Joel Sherrill (12):
  mcf5329: Simplify bsp_specs
  mrm332: Simplify bsp_specs
  genmcf548x, mvme147, mvme147s, mvme162, mvme167: Simplify bsp_specs
  av5282: Simplify bsp_specs
  csb360: Simplify bsp_specs
  gen68360: Simplify bsp_specs
  gen68340: Simplify bsp_specs
  mcf52235: Simplify bsp_specs
  mcf5206elite: Simplify bsp_specs
  mcf5225x: Simplify bsp_specs
  mcf5235: Simplify bsp_specs
  uC5282: Simplify bsp_specs
 c/src/lib/libbsp/m68k/av5282/bsp_specs                    | 6 +-----
 c/src/lib/libbsp/m68k/av5282/startup/linkcmds             | 2 ++
 c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash        | 2 ++
 c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram          | 2 ++
 c/src/lib/libbsp/m68k/csb360/bsp_specs                    | 6 +-----
 c/src/lib/libbsp/m68k/csb360/startup/linkcmds             | 3 +++
 c/src/lib/libbsp/m68k/gen68340/bsp_specs                  | 7 ++-----
 c/src/lib/libbsp/m68k/gen68340/startup/linkcmds           | 3 +++
 c/src/lib/libbsp/m68k/gen68360/bsp_specs                  | 6 +-----
 c/src/lib/libbsp/m68k/gen68360/startup/linkcmds           | 3 +++
 c/src/lib/libbsp/m68k/genmcf548x/bsp_specs                | 7 ++-----
 c/src/lib/libbsp/m68k/mcf5206elite/bsp_specs              | 6 +-----
 c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds       | 3 +++
 c/src/lib/libbsp/m68k/mcf5206elite/startup/linkcmds.flash | 3 +++
 c/src/lib/libbsp/m68k/mcf52235/bsp_specs                  | 7 ++-----
 c/src/lib/libbsp/m68k/mcf52235/startup/linkcmds           | 1 +
 c/src/lib/libbsp/m68k/mcf5225x/bsp_specs                  | 7 ++-----
 c/src/lib/libbsp/m68k/mcf5225x/startup/linkcmds           | 2 ++
 c/src/lib/libbsp/m68k/mcf5235/bsp_specs                   | 7 ++-----
 c/src/lib/libbsp/m68k/mcf5235/startup/linkcmds            | 2 ++
 c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsflash       | 2 ++
 c/src/lib/libbsp/m68k/mcf5235/startup/linkcmdsram         | 2 ++
 c/src/lib/libbsp/m68k/mcf5329/bsp_specs                   | 6 +-----
 c/src/lib/libbsp/m68k/mcf5329/startup/linkcmds            | 1 +
 c/src/lib/libbsp/m68k/mcf5329/startup/linkcmdsflash       | 1 +
 c/src/lib/libbsp/m68k/mrm332/bsp_specs                    | 6 +-----
 c/src/lib/libbsp/m68k/mrm332/startup/linkcmds             | 2 ++
 c/src/lib/libbsp/m68k/mvme147/bsp_specs                   | 7 ++-----
 c/src/lib/libbsp/m68k/mvme147s/bsp_specs                  | 7 ++-----
 c/src/lib/libbsp/m68k/mvme162/bsp_specs                   | 6 +-----
 c/src/lib/libbsp/m68k/mvme167/bsp_specs                   | 6 +-----
 c/src/lib/libbsp/m68k/shared/startup/linkcmds.base        | 1 +
 c/src/lib/libbsp/m68k/uC5282/bsp_specs                    | 7 ++-----
 c/src/lib/libbsp/m68k/uC5282/startup/linkcmds             | 2 ++
 34 files changed, 61 insertions(+), 80 deletions(-)
1.8.3.1
