[PATCH 05/12] csb360: Simplify bsp_specs
Tue Dec 19 18:27:40 UTC 2017
Updates #3520.
 c/src/lib/libbsp/m68k/csb360/bsp_specs        | 6 +-----
 c/src/lib/libbsp/m68k/csb360/startup/linkcmds | 3 +++
 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/csb360/bsp_specs b/c/src/lib/libbsp/m68k/csb360/bsp_specs
index 5154de8..87638cc 100644
--- a/c/src/lib/libbsp/m68k/csb360/bsp_specs
+++ b/c/src/lib/libbsp/m68k/csb360/bsp_specs
@@ -1,13 +1,9 @@
 %rename endfile old_endfile
 %rename startfile old_startfile
-%rename link old_link
 *startfile:
 %{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
 *endfile:
 %{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/m68k/csb360/startup/linkcmds b/c/src/lib/libbsp/m68k/csb360/startup/linkcmds
index e06ccc3..09670c1 100644
--- a/c/src/lib/libbsp/m68k/csb360/startup/linkcmds
+++ b/c/src/lib/libbsp/m68k/csb360/startup/linkcmds
@@ -19,6 +19,9 @@ RamSize = DEFINED(RamSize) ? RamSize : 31M;
 *  WARNING: it MUST match BSP_RAMBAR !!!!!!!!!!! */
 _VBR = 0x20000000;
+ENTRY(start)
+STARTUP(start.o)
  * Setup the memory map of the CSB360 board
1.8.3.1
