Removing preinstall status.
Chris Johns
chrisj at rtems.org
Tue Dec 19 23:40:32 UTC 2017
Hi,
I am now up to the testsuite and referencing the BSP specs file from the source
tree and not installing a copy.
I have simplified the process to get a source tree. The work is held at:
https://ftp.rtems.org/pub/rtems/people/chrisj/includes-move/
and follow the README.txt's 'Build No Preinstall' section. The 'inc-down' script
will pull down all the files you need and the 'build-no-preinstall' script will
update the source ready to build.
Note, make sure you have the RTEMS 5 tools in your path and edit the end of the
'build-no-preinstall' script to point to your RSB for 'sb-bootstrap'.
I have been testing the beagleboneblack and erc32 BSPs so testing and patch
feedback for other BSPs is welcome. Every little bit helps so please considering
giving it a try.
Thanks
