[PATCH 0/8] Simplify PowerPC bsp_specs
Joel Sherrill
joel at rtems.org
Wed Dec 20 21:20:40 UTC 2017
Hi
This simplifies the PowerPC bsp_spec files. This target was
more complex than that others and it likely has impact on the
preinstall removal work.
If anyone notices any issues or typos, please speak up.
Joel Sherrill (8):
gen5200, gen83xx, gen83x, mpc55xxevb, psim, qoriq, t32mppc, tqm8xx,
virtex: Simplify bsp_specs
virtex5: Simplify bsp_specs
virtex4: Simplify bsp_specs
ss555: Simplify bsp_specs
mpc8260ads: Simplify bsp_specs
haleakala: Simplify bsp_specs
qemuppc: Simplify bsp_specs
beatnik, motorola_powerpc, mvme3100, mvme5500: Simplify bsp_specs
c/src/lib/libbsp/powerpc/beatnik/Makefile.am | 3 +-
c/src/lib/libbsp/powerpc/beatnik/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/beatnik/preinstall.am | 6 +-
c/src/lib/libbsp/powerpc/beatnik/startup/linkcmds | 5 +
c/src/lib/libbsp/powerpc/gen5200/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/gen83xx/bsp_specs | 7 +-
c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds | 2 +
.../powerpc/gen83xx/startup/linkcmds.mpc83xx | 2 +
c/src/lib/libbsp/powerpc/haleakala/bsp_specs | 7 +-
.../lib/libbsp/powerpc/haleakala/startup/linkcmds | 1 +
.../libbsp/powerpc/motorola_powerpc/Makefile.am | 3 +-
.../lib/libbsp/powerpc/motorola_powerpc/bsp_specs | 7 +-
.../libbsp/powerpc/motorola_powerpc/preinstall.am | 6 +-
.../powerpc/motorola_powerpc/startup/linkcmds | 6 +
c/src/lib/libbsp/powerpc/mpc55xxevb/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/mpc8260ads/bsp_specs | 6 +-
.../lib/libbsp/powerpc/mpc8260ads/startup/linkcmds | 2 +
c/src/lib/libbsp/powerpc/mvme3100/Makefile.am | 3 +-
c/src/lib/libbsp/powerpc/mvme3100/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/mvme3100/preinstall.am | 6 +-
c/src/lib/libbsp/powerpc/mvme3100/startup/linkcmds | 5 +
c/src/lib/libbsp/powerpc/mvme5500/Makefile.am | 4 +-
c/src/lib/libbsp/powerpc/mvme5500/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/mvme5500/preinstall.am | 6 +-
c/src/lib/libbsp/powerpc/mvme5500/startup/linkcmds | 5 +
c/src/lib/libbsp/powerpc/psim/bsp_specs | 7 +-
c/src/lib/libbsp/powerpc/psim/startup/linkcmds | 2 +
c/src/lib/libbsp/powerpc/qemuppc/bsp_specs | 3 +-
c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds | 3 +
c/src/lib/libbsp/powerpc/qoriq/bsp_specs | 6 +-
.../powerpc/qoriq/startup/linkcmds.qoriq_core_0 | 2 +
.../powerpc/qoriq/startup/linkcmds.qoriq_core_1 | 2 +
.../powerpc/qoriq/startup/linkcmds.qoriq_e500 | 2 +
.../powerpc/qoriq/startup/linkcmds.qoriq_e6500_32 | 2 +
c/src/lib/libbsp/powerpc/shared/startup/linkcmds | 297 ---------------------
.../libbsp/powerpc/shared/startup/linkcmds.base | 1 +
.../libbsp/powerpc/shared/startup/linkcmds.share | 296 ++++++++++++++++++++
c/src/lib/libbsp/powerpc/ss555/bsp_specs | 6 +-
c/src/lib/libbsp/powerpc/ss555/startup/linkcmds | 1 +
c/src/lib/libbsp/powerpc/t32mppc/bsp_specs | 5 +-
.../powerpc/t32mppc/startup/linkcmds.t32mppc | 2 +
c/src/lib/libbsp/powerpc/tqm8xx/bsp_specs | 6 +-
.../libbsp/powerpc/tqm8xx/startup/linkcmds.base | 2 +
.../libbsp/powerpc/tqm8xx/startup/linkcmds.tqm8xx | 2 +
c/src/lib/libbsp/powerpc/virtex/bsp_specs | 6 +-
.../lib/libbsp/powerpc/virtex/startup/linkcmds.in | 2 +
c/src/lib/libbsp/powerpc/virtex4/bsp_specs | 8 +-
c/src/lib/libbsp/powerpc/virtex4/startup/linkcmds | 2 +
c/src/lib/libbsp/powerpc/virtex5/bsp_specs | 8 +-
c/src/lib/libbsp/powerpc/virtex5/startup/linkcmds | 2 +
50 files changed, 398 insertions(+), 399 deletions(-)
create mode 100644 c/src/lib/libbsp/powerpc/beatnik/startup/linkcmds
create mode 100644 c/src/lib/libbsp/powerpc/motorola_powerpc/startup/linkcmds
create mode 100644 c/src/lib/libbsp/powerpc/mvme3100/startup/linkcmds
create mode 100644 c/src/lib/libbsp/powerpc/mvme5500/startup/linkcmds
delete mode 100644 c/src/lib/libbsp/powerpc/shared/startup/linkcmds
create mode 100644 c/src/lib/libbsp/powerpc/shared/startup/linkcmds.share
1.8.3.1
