[PATCH 7/8] qemuppc: Simplify bsp_specs
Wed Dec 20 21:20:47 UTC 2017
Updates #3520.
 c/src/lib/libbsp/powerpc/qemuppc/bsp_specs        | 3 +--
 c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds | 3 +++
 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/bsp_specs b/c/src/lib/libbsp/powerpc/qemuppc/bsp_specs
index c876261..0360c8c 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/bsp_specs
+++ b/c/src/lib/libbsp/powerpc/qemuppc/bsp_specs
@@ -4,8 +4,7 @@
 *startfile:
 %{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s \
-    start.o%s -e _start -u __vectors}}
+%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s}}
 *endfile:
 %{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s ecrtn.o%s}
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds b/c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds
index 206fc77..f8fbfab 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds
+++ b/c/src/lib/libbsp/powerpc/qemuppc/startup/linkcmds
@@ -2,6 +2,9 @@ OUTPUT_FORMAT("elf32-powerpc", "elf32-powerpc",
               "elf32-powerpc")
 OUTPUT_ARCH(powerpc:common)
 ENTRY(_start)
+STARTUP(start.o)
+EXTERN(__vectors)
 MEMORY
         RAM       : ORIGIN = 0, LENGTH = 4M
1.8.3.1
