[PATCH 06/12] spi: Use self-contained mutex
Thu Dec 21 14:09:54 UTC 2017
Update #2843.
 cpukit/dev/include/dev/spi/spi.h |  5 +++--
 cpukit/dev/spi/spi-bus.c         | 36 ++++++------------------------------
 2 files changed, 9 insertions(+), 32 deletions(-)
diff --git a/cpukit/dev/include/dev/spi/spi.h b/cpukit/dev/include/dev/spi/spi.h
index 66bbac2427..f0f84f1461 100644
--- a/cpukit/dev/include/dev/spi/spi.h
+++ b/cpukit/dev/include/dev/spi/spi.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2016, 2017 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -27,6 +27,7 @@
 #include <rtems/seterr.h>
+#include <rtems/thread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -96,7 +97,7 @@ struct spi_bus {
    * @brief Mutex to protect the bus access.
-  rtems_id mutex;
+  rtems_recursive_mutex mutex;
    * @brief Maximum Speed in Hz
diff --git a/cpukit/dev/spi/spi-bus.c b/cpukit/dev/spi/spi-bus.c
index 343e203485..a3ee6f14fb 100644
--- a/cpukit/dev/spi/spi-bus.c
+++ b/cpukit/dev/spi/spi-bus.c
@@ -7,7 +7,7 @@
  *  Dornierstr. 4
@@ -33,20 +33,12 @@
 static void spi_bus_obtain(spi_bus *bus)
-  rtems_status_code sc;
-  sc = rtems_semaphore_obtain(bus->mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-  _Assert(sc == RTEMS_SUCCESSFUL);
-  (void) sc;
+  rtems_recursive_mutex_lock(&bus->mutex);
 static void spi_bus_release(spi_bus *bus)
-  sc = rtems_semaphore_release(bus->mutex);
-  (void) sc;
+  rtems_recursive_mutex_unlock(&bus->mutex);
 static void spi_bus_set_defaults(spi_bus *bus, spi_ioc_transfer *msg)
@@ -304,34 +296,18 @@ static int spi_bus_do_init(
   void (*destroy)(spi_bus *bus)
-  sc = rtems_semaphore_create(
-    rtems_build_name('S', 'P', 'I', ' '),
-    1,
-    RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
-    0,
-    &bus->mutex
-  if (sc != RTEMS_SUCCESSFUL) {
-    (*destroy)(bus);
-    rtems_set_errno_and_return_minus_one(ENOMEM);
+  rtems_recursive_mutex_init(&bus->mutex, "SPI Bus");
   bus->transfer = spi_bus_transfer_default;
   bus->setup = spi_bus_setup_default;
   bus->destroy = destroy;
   bus->bits_per_word = 8;
   return 0;
 void spi_bus_destroy(spi_bus *bus)
-  sc = rtems_semaphore_delete(bus->mutex);
-  (void) sc;
+  rtems_recursive_mutex_destroy(&bus->mutex);
 void spi_bus_destroy_and_free(spi_bus *bus)
2.12.3
