[PATCH 09/12] dosfs: Use self-contained recursive mutex
Thu Dec 21 14:09:57 UTC 2017
Update #2843.
 cpukit/libfs/src/dosfs/msdos.h           | 21 ++++++++-------
 cpukit/libfs/src/dosfs/msdos_dir.c       | 26 +++++++-----------
 cpukit/libfs/src/dosfs/msdos_file.c      | 46 +++++++++-----------------------
 cpukit/libfs/src/dosfs/msdos_fsunmount.c |  2 +-
 cpukit/libfs/src/dosfs/msdos_init.c      | 16 ++---------
 cpukit/libfs/src/dosfs/msdos_initsupp.c  | 17 ++----------
 cpukit/libfs/src/dosfs/msdos_misc.c      |  8 ++----
 cpukit/libfs/src/dosfs/msdos_statvfs.c   | 10 +++----
 cpukit/sapi/include/confdefs.h           |  7 -----
 9 files changed, 43 insertions(+), 110 deletions(-)
diff --git a/cpukit/libfs/src/dosfs/msdos.h b/cpukit/libfs/src/dosfs/msdos.h
index abfede8203..ea94954cac 100644
--- a/cpukit/libfs/src/dosfs/msdos.h
+++ b/cpukit/libfs/src/dosfs/msdos.h
@@ -24,6 +24,7 @@
 #include <rtems/libio_.h>
 #include <rtems/dosfs.h>
+#include <rtems/thread.h>
 #include "fat.h"
 #include "fat_file.h"
@@ -62,11 +63,7 @@ typedef struct msdos_fs_info_s
                                                             * nodes of file
                                                             * type
-    rtems_id                          vol_sema;           /*
-                                                           * semaphore
-                                                           * associated with
-                                                           * the volume
+    rtems_recursive_mutex vol_mutex;
     uint8_t                          *cl_buf;              /*
                                                             * just placeholder
                                                             * for anything
@@ -75,16 +72,22 @@ typedef struct msdos_fs_info_s
     rtems_dosfs_convert_control      *converter;
 } msdos_fs_info_t;
+RTEMS_INLINE_ROUTINE void msdos_fs_lock(msdos_fs_info_t *fs_info)
+    rtems_recursive_mutex_lock(&fs_info->vol_mutex);
+RTEMS_INLINE_ROUTINE void msdos_fs_unlock(msdos_fs_info_t *fs_info)
+    rtems_recursive_mutex_unlock(&fs_info->vol_mutex);
 /* a set of routines that handle the nodes which are directories */
 extern const rtems_filesystem_file_handlers_r  msdos_dir_handlers;
 /* a set of routines that handle the nodes which are files */
 extern const rtems_filesystem_file_handlers_r  msdos_file_handlers;
-/* Volume semaphore timeout value. This value can be changed to a number
- * of ticks to help debugging or if you need such a  */
-#define MSDOS_VOLUME_SEMAPHORE_TIMEOUT    RTEMS_NO_TIMEOUT
  * Macros for fetching fields from 32 bytes long FAT Directory Entry
  * Structure
diff --git a/cpukit/libfs/src/dosfs/msdos_dir.c b/cpukit/libfs/src/dosfs/msdos_dir.c
index e07c723e83..535d5f56f0 100644
--- a/cpukit/libfs/src/dosfs/msdos_dir.c
+++ b/cpukit/libfs/src/dosfs/msdos_dir.c
@@ -65,7 +65,6 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
     int                rc = RC_OK;
     int                eno = 0;
-    rtems_status_code  sc = RTEMS_SUCCESSFUL;
     msdos_fs_info_t   *fs_info = iop->pathinfo.mt_entry->fs_info;
     rtems_dosfs_convert_control *converter = fs_info->converter;
     const rtems_dosfs_convert_handler *convert_handler = converter->handler;
@@ -87,10 +86,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
     int                lfn_entries = 0;
     bool               is_first_entry;
-    sc = rtems_semaphore_obtain(fs_info->vol_sema, RTEMS_WAIT,
-                                MSDOS_VOLUME_SEMAPHORE_TIMEOUT);
-    if (sc != RTEMS_SUCCESSFUL)
-        rtems_set_errno_and_return_minus_one(EIO);
+    msdos_fs_lock(fs_info);
      * cast start and count - protect against using sizes that are not exact
@@ -123,7 +119,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
                             bts2rd, fs_info->cl_buf);
         if (ret < MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE)
-            rtems_semaphore_release(fs_info->vol_sema);
+            msdos_fs_unlock(fs_info);
@@ -137,7 +133,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
             if ((*MSDOS_DIR_ENTRY_TYPE(entry)) ==
                 MSDOS_THIS_DIR_ENTRY_AND_REST_EMPTY)
                 return cmpltd;
@@ -252,7 +248,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
                                     j * bts2rd, &cur_cln);
                 if (rc != RC_OK)
                     return rc;
@@ -262,7 +258,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
                 rc = fat_file_open(&fs_info->fat, &dir_pos, &tmp_fat_fd);
                 if (rc != RC_OK)
                     return rc;
@@ -336,7 +332,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
                     rc = fat_file_close(&fs_info->fat, tmp_fat_fd);
                     if (rc != RC_OK)
                         return rc;
@@ -348,7 +344,7 @@ msdos_dir_read(rtems_libio_t *iop, void *buffer, size_t count)
         j++;
     return cmpltd;
@@ -382,14 +378,10 @@ msdos_dir_stat(
     struct stat *buf
     msdos_fs_info_t   *fs_info = loc->mt_entry->fs_info;
     fat_file_fd_t     *fat_fd = loc->node_access;
     buf->st_dev = rtems_disk_get_device_identifier(fs_info->fat.vol.dd);
     buf->st_ino = fat_fd->ino;
@@ -402,7 +394,7 @@ msdos_dir_stat(
     buf->st_ctime = fat_fd->ctime;
     buf->st_mtime = fat_fd->mtime;
     return RC_OK;
diff --git a/cpukit/libfs/src/dosfs/msdos_file.c b/cpukit/libfs/src/dosfs/msdos_file.c
index d150a1ff22..d7b170a01a 100644
--- a/cpukit/libfs/src/dosfs/msdos_file.c
+++ b/cpukit/libfs/src/dosfs/msdos_file.c
@@ -47,21 +47,17 @@ ssize_t
 msdos_file_read(rtems_libio_t *iop, void *buffer, size_t count)
     ssize_t            ret = 0;
     fat_file_fd_t     *fat_fd = iop->pathinfo.node_access;
     ret = fat_file_read(&fs_info->fat, fat_fd, iop->offset, count,
                         buffer);
     if (ret > 0)
         iop->offset += ret;
     return ret;
@@ -82,14 +78,10 @@ ssize_t
 msdos_file_write(rtems_libio_t *iop,const void *buffer, size_t count)
     ssize_t            ret = 0;
     if (rtems_libio_iop_is_append(iop))
         iop->offset = fat_fd->fat_file_size;
@@ -98,7 +90,7 @@ msdos_file_write(rtems_libio_t *iop,const void *buffer, size_t count)
                          buffer);
     if (ret < 0)
         return -1;
@@ -113,7 +105,7 @@ msdos_file_write(rtems_libio_t *iop,const void *buffer, size_t count)
     if (ret > 0)
         fat_file_set_ctime_mtime(fat_fd, time(NULL));
     return ret;
@@ -132,15 +124,11 @@ msdos_file_stat(
     struct stat *buf
     uint32_t           cl_mask = fs_info->fat.vol.bpc - 1;
@@ -154,7 +142,7 @@ msdos_file_stat(
     return RC_OK;
@@ -172,15 +160,11 @@ int
 msdos_file_ftruncate(rtems_libio_t *iop, off_t length)
     int                rc = RC_OK;
     uint32_t old_length;
     old_length = fat_fd->fat_file_size;
     if (length < old_length) {
@@ -206,7 +190,7 @@ msdos_file_ftruncate(rtems_libio_t *iop, off_t length)
     return rc;
@@ -225,27 +209,21 @@ int
 msdos_file_sync(rtems_libio_t *iop)
     int                rc = RC_OK;
     rc = fat_file_update(&fs_info->fat, fat_fd);
     if (rc != RC_OK)
         return rc;
     rc = fat_sync(&fs_info->fat);
-    if ( rc != 0 )
     return RC_OK;
diff --git a/cpukit/libfs/src/dosfs/msdos_fsunmount.c b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
index e3cef45824..6b44ab0fdb 100644
--- a/cpukit/libfs/src/dosfs/msdos_fsunmount.c
+++ b/cpukit/libfs/src/dosfs/msdos_fsunmount.c
@@ -54,7 +54,7 @@ msdos_shut_down(rtems_filesystem_mount_table_entry_t *temp_mt_entry)
     fat_shutdown_drive(&fs_info->fat);
-    rtems_semaphore_delete(fs_info->vol_sema);
+    rtems_recursive_mutex_destroy(&fs_info->vol_mutex);
     (*converter->handler->destroy)( converter );
     free(fs_info->cl_buf);
     free(temp_mt_entry->fs_info);
diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
index 59afaf15ef..6ae77c86ae 100644
--- a/cpukit/libfs/src/dosfs/msdos_init.c
+++ b/cpukit/libfs/src/dosfs/msdos_init.c
@@ -75,24 +75,12 @@ const rtems_filesystem_operations_table  msdos_ops = {
 void msdos_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
-  msdos_fs_info_t *fs_info = mt_entry->fs_info;
-  rtems_status_code sc = rtems_semaphore_obtain(
-    fs_info->vol_sema,
-    RTEMS_WAIT,
-    RTEMS_NO_TIMEOUT
-  if (sc != RTEMS_SUCCESSFUL) {
-    rtems_fatal_error_occurred(0xdeadbeef);
+  msdos_fs_lock(mt_entry->fs_info);
 void msdos_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
-  rtems_status_code sc = rtems_semaphore_release(fs_info->vol_sema);
+  msdos_fs_unlock(mt_entry->fs_info);
 /* msdos_initialize --
diff --git a/cpukit/libfs/src/dosfs/msdos_initsupp.c b/cpukit/libfs/src/dosfs/msdos_initsupp.c
index b43e61dde0..a8451615d2 100644
--- a/cpukit/libfs/src/dosfs/msdos_initsupp.c
+++ b/cpukit/libfs/src/dosfs/msdos_initsupp.c
@@ -57,7 +57,6 @@ msdos_initialize_support(
     int                rc = RC_OK;
     msdos_fs_info_t   *fs_info = NULL;
     fat_file_fd_t     *fat_fd = NULL;
     fat_dir_pos_t      root_pos;
@@ -133,20 +132,8 @@ msdos_initialize_support(
         rtems_set_errno_and_return_minus_one(ENOMEM);
-    sc = rtems_semaphore_create(3,
-                                1,
-                                RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY |
-                                RTEMS_INHERIT_PRIORITY,
-                                0,
-                                &fs_info->vol_sema);
-        fat_file_close(&fs_info->fat, fat_fd);
-        fat_shutdown_drive(&fs_info->fat);
-        free(fs_info->cl_buf);
-        free(fs_info);
-        rtems_set_errno_and_return_minus_one( EIO );
+    rtems_recursive_mutex_init(&fs_info->vol_mutex,
+                               RTEMS_FILESYSTEM_TYPE_DOSFS);
     temp_mt_entry->mt_fs_root->location.node_access = fat_fd;
     temp_mt_entry->mt_fs_root->location.handlers = directory_handlers;
diff --git a/cpukit/libfs/src/dosfs/msdos_misc.c b/cpukit/libfs/src/dosfs/msdos_misc.c
index 24eb2d11e0..20fcbb3b75 100644
--- a/cpukit/libfs/src/dosfs/msdos_misc.c
+++ b/cpukit/libfs/src/dosfs/msdos_misc.c
@@ -2072,16 +2072,12 @@ int
 msdos_sync(rtems_libio_t *iop)
     int                rc = RC_OK;
     return rc;
diff --git a/cpukit/libfs/src/dosfs/msdos_statvfs.c b/cpukit/libfs/src/dosfs/msdos_statvfs.c
index 99f200f3b7..a9e61c568f 100644
--- a/cpukit/libfs/src/dosfs/msdos_statvfs.c
+++ b/cpukit/libfs/src/dosfs/msdos_statvfs.c
@@ -24,12 +24,8 @@ int msdos_statvfs(
   msdos_fs_info_t *fs_info = root_loc->mt_entry->fs_info;
   fat_vol_t *vol = &fs_info->fat.vol;
   sb->f_bsize = FAT_SECTOR512_SIZE;
   sb->f_frsize = vol->bpc;
@@ -54,7 +50,7 @@ int msdos_statvfs(
       rc = fat_get_fat_cluster(&fs_info->fat, cur_cl, &value);
       if (rc != RC_OK)
         return rc;
@@ -71,6 +67,6 @@ int msdos_statvfs(
     sb->f_bavail = vol->free_cls;
   return RC_OK;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 27f5b3eedd..e86920b728 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -417,14 +417,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #if !defined(CONFIGURE_FILESYSTEM_ENTRY_DOSFS) && \
     defined(CONFIGURE_FILESYSTEM_DOSFS)
-  #if !defined(CONFIGURE_MAXIMUM_DOSFS_MOUNTS)
-    #define CONFIGURE_MAXIMUM_DOSFS_MOUNTS 1
-  #endif
   #define CONFIGURE_FILESYSTEM_ENTRY_DOSFS \
     { RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize }
-  #define _CONFIGURE_SEMAPHORES_FOR_DOSFS CONFIGURE_MAXIMUM_DOSFS_MOUNTS
-#else
-  #define _CONFIGURE_SEMAPHORES_FOR_DOSFS 0
 #endif
@@ -460,7 +454,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
 #define _CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS \
     (_CONFIGURE_SEMAPHORES_FOR_FIFOS + \
      _CONFIGURE_SEMAPHORES_FOR_NFS + \
-     _CONFIGURE_SEMAPHORES_FOR_DOSFS + \
      _CONFIGURE_SEMAPHORES_FOR_RFS)
 #ifdef CONFIGURE_INIT
2.12.3
