[PATCH] c-user: Add self-contained objects chapter
Thu Dec 21 14:10:39 UTC 2017
Update #2843.
 c-user/index.rst                  |    1 +
 c-user/self_contained_objects.rst | 1070 +++++++++++++++++++++++++++++++++++++
 2 files changed, 1071 insertions(+)
 create mode 100644 c-user/self_contained_objects.rst
diff --git a/c-user/index.rst b/c-user/index.rst
index 5ee50c9..d125c28 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -65,6 +65,7 @@ to the Community Project hosted at http://www.rtems.org/.
 	board_support_packages
 	user_extensions
 	configuring_a_system
+	self_contained_objects
 	multiprocessing
 	symmetric_multiprocessing_services
 	pci_library
diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
new file mode 100644
index 0000000..23ec5cf
--- /dev/null
+++ b/c-user/self_contained_objects.rst
@@ -0,0 +1,1070 @@
+.. comment SPDX-License-Identifier: CC-BY-SA-4.0
+.. COMMENT: Copyright (c) 2014, 2017.
+.. COMMENT: embedded brains GmbH.
+.. COMMENT: All rights reserved.
+Self-Contained Objects
+Introduction
+One of the original design goals of RTEMS was the support for heterogeneous
+computing based on message passing.  This was realized by synchronization
+objects with an architecture-independent identifier provided by the system
+during object creation (a 32-bit unsigned integer used as a bitfield) and a
+user-defined four character name.  This approach in the so called Classic API
+has some weaknesses:
+* Dynamic memory (the workspace) is used to allocate object pools.  This
+  requires a complex configuration with heavy use of the C pre-processor.
+  The unlimited objects support optionally expands and shrinks the object pool.
+  Dynamic memory is strongly discouraged by some coding standards, e.g.  MISRA
+  C:2012 :cite:`MISRA:2012:C`.
+* Objects are created via function calls which return an object identifier.
+  The object operations use this identifier and map it internally to an object
+  representation.
+* The object identifier is only known at run-time.  This hinders compiler
+  optimizations and static analysis.
+* The objects reside in a table, e.g. they are suspect to false sharing of
+  cache lines :cite:`Drepper:2007:Memory`.
+* The object operations use a rich set of options and attributes.  For each
+  object operation these parameters must be evaluated and validated at run-time
+  to figure out what to do exactly for this operation.
+For applications that use fine grained locking the mapping of the identifier to
+the object representation and the parameter evaluation are a significant
+overhead that may degrade the performance dramatically.  An example is the `new
+network stack (libbsd) <https://git.rtems.org/rtems-libbsd>`_ which uses
+hundreds of locks in a basic setup.  Another example is the OpenMP support
+(libgomp).
+To overcome these issues new self-contained synchronization objects are
+available since RTEMS 4.11.  Self-contained synchronization objects encapsulate
+all their state in exactly one data structure.  The user must provide the
+storage space for this structure and nothing more.  The user is responsible for
+the object life-cycle.  Initialization and destruction of self-contained
+synchronization objects cannot fail provided all function parameters are valid.
+In particular, a not enough memory error cannot happen.  It is possible to
+statically initialize self-contained synchronization objects.  This allows an
+efficient use of static analysis tools.
+Several header files define self-contained synchronization objects.  The Newlib
+:file:`<sys/lock.h>` header file provides
+* mutexes,
+* recursive mutexes,
+* condition variables,
+* counting semaphores,
+* binary semaphores, and
+* Futex synchronization :cite:`Franke:2002:Futex`.
+They are used internally in Newlib (e.g. for FILE objects), for the C++11
+threads and the OpenMP support (libgomp).  The Newlib provided self-contained
+synchronization objects focus on performance.  There are no error checks to
+catch software errors, e.g. invalid parameters.  The application configuration
+is significantly simplified, since it is no longer necessary to account for
+lock objects used by Newlib and GCC.  The Newlib defined self-contained
+synchronization objects can be a statically initialized and reside in the
+``.bss`` section.  Destruction is a no-operation.
+The header file :file:`<pthread.h>` provides
+* POSIX barriers (:c:type:`pthread_barrier_t`),
+* POSIX condition variables (:c:type:`pthread_cond_t`),
+* POSIX mutexes (:c:type:`pthread_mutex_t`),
+* POSIX reader/writer locks (:c:type:`pthread_rwlock_t`), and
+* POSIX spinlocks (:c:type:`pthread_spinlock_t`)
+as self-contained synchronization objects.  The POSIX synchronization objects are
+used for example by the Ada run-time support.  The header file
+:file:`<semaphore.h>` provides self-contained
+* POSIX unnamed semaphores (:c:type:`sem_t` initialized via :c:func:`sem_init`).
+RTEMS Thread API
+To give RTEMS users access to self-contained synchronization objects an API is
+necessary.  One option would be to simply use the POSIX threads API (pthreads),
+C11 threads or C++11 threads.  However, these standard APIs lack for example
+binary semaphores which are important for task/interrupt synchronization.  The
+timed operations use in general time values specified by seconds and
+nanoseconds.  Setting up the time values in seconds (time_t has 64 bits) and
+nanoseconds is burdened with a high overhead compared to time values in clock
+ticks for relative timeouts.  The POSIX API mutexes can be configured for
+various protocols and options, this adds a run-time overhead.  There are a
+variety of error conditions.  This is a problem in combination with some coding
+standards, e.g.  MISRA C:2012.  APIs used by Linux (e.g. `<linux/mutex.h>
+<http://lxr.free-electrons.com/source/include/linux/mutex.h>`_) or the FreeBSD
+kernel (e.g. `MUTEX(9)
+<https://www.freebsd.org/cgi/man.cgi?query=mutex&sektion=9>`_) are better
+suited as a template for high-performance synchronization objects.  The goal of
+the `RTEMS Thread API` is to offer the highest performance with the lowest
+space-overhead on RTEMS.  It should be suitable for device drivers.
+Mutual Exclusion
+The :c:type:`rtems_mutex` and :c:type:`rtems_recursive_mutex` objects provide
+mutual-exclusion synchronization using the :ref:`PriorityInheritance` in
+uni-processor configurations or the :ref:`OMIP` in SMP configurations.
+Recursive locking should be used with care :cite:`Williams:2012:CA`.  The
+storage space for these object must be provided by the user.  There are no
+defined comparison or assignment operators for these type.  Only the object
+itself may be used for performing synchronization.  The result of referring to
+copies of the object in calls to
+* :c:func:`rtems_mutex_lock`,
+* :c:func:`rtems_recursive_mutex_lock`,
+* :c:func:`rtems_mutex_unlock`,
+* :c:func:`rtems_recursive_mutex_unlock`,
+* :c:func:`rtems_mutex_set_name`,
+* :c:func:`rtems_recursive_mutex_set_name`,
+* :c:func:`rtems_mutex_get_name`,
+* :c:func:`rtems_recursive_mutex_get_name`,
+* :c:func:`rtems_mutex_destroy`, and
+* :c:func:`rtems_recursive_mutex_destroy`
+is undefined.  Objects of the type :c:type:`rtems_mutex` must be initialized
+via
+* :c:func:`RTEMS_MUTEX_INITIALIZER`, or
+* :c:func:`rtems_mutex_init`.
+They must be destroyed via
+* :c:func:`rtems_mutex_destroy`.
+is undefined.  Objects of the type :c:type:`rtems_recursive_mutex` must be
+initialized via
+* :c:func:`RTEMS_RECURSIVE_MUTEX_INITIALIZER`, or
+* :c:func:`rtems_recursive_mutex_init`.
+* :c:func:`rtems_recursive_mutex_destroy`.
+.. raw:: latex
+    \clearpage
+Static mutex initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_mutex mutex = RTEMS_MUTEX_INITIALIZER(
+          name
+        rtems_recursive_mutex mutex = RTEMS_RECURSIVE_MUTEX_INITIALIZER(
+          name
+DESCRIPTION:
+    An initializer for static initialization.  It is equivalent to a call to
+    :c:func:`rtems_mutex_init` or :c:func:`rtems_recursive_mutex_init`
+    respectively.
+NOTES:
+    Global mutexes with a ``name`` of ``NULL`` may reside in the ``.bss``
+    section.
+.. raw:: latex
+    \clearpage
+Run-time mutex initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_mutex_init(
+          rtems_mutex *mutex,
+          const char  *name
+        void rtems_recursive_mutex_init(
+          rtems_recursive_mutex *mutex,
+          const char            *name
+DESCRIPTION:
+    Initializes the ``mutex`` with the specified ``name``.
+NOTES:
+    The ``name`` must be persistent throughout the life-time of the mutex.  A
+    ``name`` of ``NULL`` is valid.  The mutex is unlocked after initialization.
+.. raw:: latex
+    \clearpage
+Lock the mutex
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_mutex_lock(
+        void rtems_recursive_mutex_lock(
+DESCRIPTION:
+    Locks the ``mutex``.
+NOTES:
+    This function must be called from thread context with interrupts enabled.
+    In case the mutex is currently locked by another thread, then the thread is
+    blocked until it becomes the mutex owner.  Threads wait in priority order.
+    A recursive lock happens in case the mutex owner tries to lock the mutex
+    again.  The result of recursively locking a mutex depends on the mutex
+    variant.  For a normal (non-recursive) mutex (:c:type:`rtems_mutex`) the
+    result is unpredictable.  It could block the owner indefinetly or lead to a
+    fatal deadlock error.  A recursive mutex (:c:type:`rtems_recursive_mutex`)
+    can be locked recursively by the mutex owner.
+    Each mutex lock operation must have a corresponding unlock operation.
+.. raw:: latex
+    \clearpage
+Unlock the mutex
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_mutex_unlock(
+        void rtems_recursive_mutex_unlock(
+DESCRIPTION:
+    Unlocks the ``mutex``.
+NOTES:
+    In case the currently executing thread is not the owner of the ``mutex``,
+    then the result is unpredictable.
+    Exactly the outer-most unlock will make a recursive mutex available to
+    other threads.
+.. raw:: latex
+    \clearpage
+.. raw:: latex
+    \clearpage
+Set mutex name
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_mutex_set_name(
+          const char  *name
+        void rtems_recursive_mutex_set_name(
+          const char            *name
+DESCRIPTION:
+    Sets the ``mutex`` name to ``name``.
+NOTES:
+.. raw:: latex
+    \clearpage
+Get mutex name
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_mutex_get_name(
+          const rtems_mutex *mutex
+        const char *rtems_recursive_mutex_get_name(
+          const rtems_recursive_mutex *mutex
+DESCRIPTION:
+    Returns the ``mutex`` name.
+NOTES:
+    The name may be ``NULL``.
+Mutex destruction
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_mutex_destroy(
+        void rtems_recursive_mutex_destroy(
+DESCRIPTION:
+    Destroys the ``mutex``.
+NOTES:
+    In case the mutex is locked or still in use, then the result is
+    unpredictable.
+Condition Variables
+The :c:type:`rtems_condition_variable` object provides a condition variable
+synchronization object.  The storage space for this object must be provided by
+the user.  There are no defined comparison or assignment operators for this
+type.  Only the object itself may be used for performing synchronization.  The
+result of referring to copies of the object in calls to
+* :c:func:`rtems_condition_variable_wait`,
+* :c:func:`rtems_condition_variable_signal`,
+* :c:func:`rtems_condition_variable_broadcast`,
+* :c:func:`rtems_condition_variable_set_name`,
+* :c:func:`rtems_condition_variable_get_name`, and
+* :c:func:`rtems_condition_variable_destroy`
+is undefined.  Objects of this type must be initialized via
+* :c:func:`RTEMS_CONDITION_VARIABLE_INITIALIZER`, or
+* :c:func:`rtems_condition_variable_init`.
+* :c:func:`rtems_condition_variable_destroy`.
+.. raw:: latex
+    \clearpage
+Static condition variable initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_condition_variable condition_variable = RTEMS_CONDITION_VARIABLE_INITIALIZER(
+          name
+DESCRIPTION:
+    :c:func:`rtems_condition_variable_init`.
+NOTES:
+    Global condition variables with a ``name`` of ``NULL`` may reside in the
+    ``.bss`` section.
+.. raw:: latex
+    \clearpage
+Run-time condition variable initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_init(
+          rtems_condition_variable *condition_variable,
+          const char               *name
+DESCRIPTION:
+    Initializes the ``condition_variable`` with the specified ``name``.
+NOTES:
+    The ``name`` must be persistent throughout the life-time of the condition
+    variable.  A ``name`` of ``NULL`` is valid.
+.. raw:: latex
+    \clearpage
+Wait for condition signal
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_wait(
+DESCRIPTION:
+    Atomically waits for a condition signal and unlocks the mutex.  Once the
+    condition is signalled to the thread it wakes up and locks the mutex again.
+NOTES:
+    Threads wait in priority order.
+.. raw:: latex
+    \clearpage
+Signals a condition change
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_signal(
+DESCRIPTION:
+    Signals a condition change to the highest priority waiting thread.  If no
+    threads wait currently on this condition variable, then nothing happens.
+.. raw:: latex
+    \clearpage
+Broadcasts a condition change
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_broadcast(
+DESCRIPTION:
+    Signals a condition change to all waiting thread.  If no threads wait
+    currently on this condition variable, then nothing happens.
+.. raw:: latex
+    \clearpage
+.. raw:: latex
+    \clearpage
+Set condition variable name
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_set_name(
+          const char               *name
+DESCRIPTION:
+    Sets the ``condition_variable`` name to ``name``.
+NOTES:
+.. raw:: latex
+    \clearpage
+Get condition variable name
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_condition_variable_get_name(
+          const rtems_condition_variable *condition_variable
+DESCRIPTION:
+    Returns the ``condition_variable`` name.
+NOTES:
+Condition variable destruction
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_condition_variable_destroy(
+DESCRIPTION:
+    Destroys the ``condition_variable``.
+NOTES:
+    In case the condition variable still in use, then the result is
+    unpredictable.
+Counting Semaphores
+The :c:type:`rtems_counting_semaphore` object provides a counting semaphore
+* :c:func:`rtems_counting_semaphore_wait`,
+* :c:func:`rtems_counting_semaphore_post`,
+* :c:func:`rtems_counting_semaphore_set_name`,
+* :c:func:`rtems_counting_semaphore_get_name`, and
+* :c:func:`rtems_counting_semaphore_destroy`
+* :c:func:`RTEMS_COUNTING_SEMAPHORE_INITIALIZER`, or
+* :c:func:`rtems_counting_semaphore_init`.
+* :c:func:`rtems_counting_semaphore_destroy`.
+.. raw:: latex
+    \clearpage
+Static counting semaphore initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_counting_semaphore counting_semaphore = RTEMS_COUNTING_SEMAPHORE_INITIALIZER(
+          name,
+          value
+DESCRIPTION:
+    :c:func:`rtems_counting_semaphore_init`.
+NOTES:
+    Global counting semaphores with a ``name`` of ``NULL`` may reside in the
+    ``.bss`` section.
+.. raw:: latex
+    \clearpage
+Run-time counting semaphore initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_counting_semaphore_init(
+          rtems_counting_semaphore *counting_semaphore,
+          const char               *name,
+          unsigned int              value
+DESCRIPTION:
+    Initializes the ``counting_semaphore`` with the specified ``name`` and
+    ``value``.  The initial value is set to ``value``.
+NOTES:
+    The ``name`` must be persistent throughout the life-time of the counting
+    semaphore.  A ``name`` of ``NULL`` is valid.
+.. raw:: latex
+    \clearpage
+Wait for a counting semaphore
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_counting_semaphore_wait(
+DESCRIPTION:
+    Waits for the ``counting_semaphore``.  In case the current semaphore value
+    is positive, then the value is decremented and the function returns
+    immediately, otherwise the thread is blocked waiting for a semaphore post.
+NOTES:
+.. raw:: latex
+    \clearpage
+Post a counting semaphore
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_counting_semaphore_post(
+DESCRIPTION:
+    Posts the ``counting_semaphore``.  In case at least one thread is waiting
+    on the counting semaphore, then the highest priority thread is woken up,
+    otherwise the current value is incremented.
+NOTES:
+    This function may be called from interrupt context.  In case it is called
+    from thread context, then interrupts must be enabled.
+.. raw:: latex
+    \clearpage
+.. raw:: latex
+    \clearpage
+Set counting semaphore name
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_counting_semaphore_set_name(
+          const char               *name
+DESCRIPTION:
+    Sets the ``counting_semaphore`` name to ``name``.
+NOTES:
+.. raw:: latex
+    \clearpage
+Get counting semaphore name
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_counting_semaphore_get_name(
+          const rtems_counting_semaphore *counting_semaphore
+DESCRIPTION:
+    Returns the ``counting_semaphore`` name.
+NOTES:
+Counting semaphore destruction
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_counting_semaphore_destroy(
+DESCRIPTION:
+    Destroys the ``counting_semaphore``.
+NOTES:
+    In case the counting semaphore still in use, then the result is
+    unpredictable.
+Binary Semaphores
+The :c:type:`rtems_binary_semaphore` object provides a binary semaphore
+* :c:func:`rtems_binary_semaphore_wait`,
+* :c:func:`rtems_binary_semaphore_wait_timed_ticks`,
+* :c:func:`rtems_binary_semaphore_try_wait`,
+* :c:func:`rtems_binary_semaphore_post`,
+* :c:func:`rtems_binary_semaphore_set_name`,
+* :c:func:`rtems_binary_semaphore_get_name`, and
+* :c:func:`rtems_binary_semaphore_destroy`
+* :c:func:`RTEMS_BINARY_SEMAPHORE_INITIALIZER`, or
+* :c:func:`rtems_binary_semaphore_init`.
+* :c:func:`rtems_binary_semaphore_destroy`.
+.. raw:: latex
+    \clearpage
+Static binary semaphore initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        rtems_binary_semaphore binary_semaphore = RTEMS_BINARY_SEMAPHORE_INITIALIZER(
+          name
+DESCRIPTION:
+    :c:func:`rtems_binary_semaphore_init`.
+NOTES:
+    Global binary semaphores with a ``name`` of ``NULL`` may reside in the
+    ``.bss`` section.
+.. raw:: latex
+    \clearpage
+Run-time binary semaphore initialization
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_binary_semaphore_init(
+          rtems_binary_semaphore *binary_semaphore,
+          const char             *name
+DESCRIPTION:
+    Initializes the ``binary_semaphore`` with the specified ``name``.  The
+    initial value is set to zero.
+NOTES:
+    The ``name`` must be persistent throughout the life-time of the binary
+.. raw:: latex
+    \clearpage
+Wait for a binary semaphore
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_binary_semaphore_wait(
+DESCRIPTION:
+    Waits for the ``binary_semaphore``.  In case the current semaphore value is
+    one, then the value is set to zero and the function returns immediately,
+    otherwise the thread is blocked waiting for a semaphore post.
+NOTES:
+.. raw:: latex
+    \clearpage
+Wait for a binary semaphore with timeout in ticks
+CALLING SEQUENCE:
+    .. code-block:: c
+        int rtems_binary_semaphore_wait_timed_ticks(
+          uint32_t                ticks
+DIRECTIVE STATUS CODES:
+    .. list-table::
+      :class: rtems-table
+      * - ``0``
+        - The semaphore wait was successful.
+      * - ``ETIMEDOUT``
+        - The semaphore wait timed out.
+DESCRIPTION:
+    Waits for the ``binary_semaphore`` with a timeout in ``ticks``.  In case
+    the current semaphore value is one, then the value is set to zero and the
+    function returns immediately with a return value of ``0``, otherwise the
+    thread is blocked waiting for a semaphore post.  The time waiting for a
+    semaphore post is limited by ``ticks``.  A ``ticks`` value of zero
+    specifies an infinite timeout.
+NOTES:
+.. raw:: latex
+    \clearpage
+Tries to wait for a binary semaphore
+CALLING SEQUENCE:
+    .. code-block:: c
+        int rtems_binary_semaphore_try_wait(
+    .. list-table::
+      * - ``0``
+      * - ``EAGAIN``
+        - The semaphore wait failed.
+DESCRIPTION:
+    Tries to wait for the ``binary_semaphore``.  In case the current semaphore
+    value is one, then the value is set to zero and the function returns
+    immediately with a return value of ``0``, otherwise it returns immediately
+    with a return value of ``EAGAIN``.
+NOTES:
+.. raw:: latex
+    \clearpage
+Post a binary semaphore
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_binary_semaphore_post(
+DESCRIPTION:
+    Posts the ``binary_semaphore``.  In case at least one thread is waiting
+    on the binary semaphore, then the highest priority thread is woken up,
+    otherwise the current value is set to one.
+NOTES:
+.. raw:: latex
+    \clearpage
+.. raw:: latex
+    \clearpage
+Set binary semaphore name
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_binary_semaphore_set_name(
+          const char             *name
+DESCRIPTION:
+    Sets the ``binary_semaphore`` name to ``name``.
+NOTES:
+.. raw:: latex
+    \clearpage
+Get binary semaphore name
+CALLING SEQUENCE:
+    .. code-block:: c
+        const char *rtems_binary_semaphore_get_name(
+          const rtems_binary_semaphore *binary_semaphore
+DESCRIPTION:
+    Returns the ``binary_semaphore`` name.
+NOTES:
+Binary semaphore destruction
+CALLING SEQUENCE:
+    .. code-block:: c
+        void rtems_binary_semaphore_destroy(
+DESCRIPTION:
+    Destroys the ``binary_semaphore``.
+NOTES:
+    In case the binary semaphore still in use, then the result is
+    unpredictable.
+Threads
+.. warning::
+   The self-contained threads support is work in progress.  In contrast to the
+   synchronization objects the self-contained thread support is not just an API
+   glue layer to already existing implementations.
+The :c:type:`rtems_thread` object provides a thread of execution.
+CALLING SEQUENCE:
+    .. code-block:: c
+        RTEMS_THREAD_INITIALIZER(
+          name,
+          thread_size,
+          priority,
+          flags,
+          entry,
+          arg
+        void rtems_thread_start(
+          rtems_thread *thread,
+          const char   *name,
+          size_t        thread_size,
+          uint32_t      priority,
+          uint32_t      flags,
+          void       ( *entry )( void * ),
+          void         *arg
+        void rtems_thread_restart(
+          void         *arg
+        ) RTEMS_NO_RETURN;
+        void rtems_thread_event_send(
+          uint32_t      events
+        uint32_t rtems_thread_event_poll(
+          uint32_t      events_of_interest
+        uint32_t rtems_thread_event_wait_all(
+        uint32_t rtems_thread_event_wait_any(
+        void rtems_thread_destroy(
+        void rtems_thread_destroy_self(
+          void
2.12.3
