[PATCH] sptests/spsem04: new test case for PIP starvation
Thu Dec 21 16:01:56 UTC 2017
On Thu, Dec 21, 2017 at 3:52 AM, Sebastian Huber
> On 20/12/17 17:02, Gedare Bloom wrote:
>> On Wed, Dec 20, 2017 at 10:58 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Dec 20, 2017 at 1:02 AM, Sebastian Huber
>>>> I think this is already covered by test_inherit_nested_vertical() in
>>>> spmutex01.
>>> Thanks for the pointer, you're correct. I need this kind of test for
>>> some release/maintenance to fix PIP in 4.10 (and checking it on 4.11).
>> FYI: I have this spsem04 on 4.10 and 4.11, and it demonstrates the
>> broken PIP we know and love.
>>> I may try to unpack the parts of spmutex01 that are backward-compatible.
>> If I can't easily port backward spmutex01, I may like to add these
>> tests to the release branches if acceptable.
>> I intend to implement some solution similar to the one you suggested
>> in https://devel.rtems.org/ticket/2412
> I am not opposed to duplicated tests in general, but we should keep a bit
> the test run time in mind. Individual test programs require a boot cycle.
Understood. There is a tradeoff made though, by lumping more tests in
a single test application the test complexity increases, and test
failures become slightly harder to investigate. I guess it makes sense
to have these combined tests like spmutex01 after the
components-under-test have been fully developed, but it does make
debugging an individual component more difficult.
> I don't care about the tests in 4.10 and 4.11 that much.
