[PATCH] 4.10: fix version number
Thu Dec 21 17:28:33 UTC 2017
This is for the 4.10 branch of the rtems-tools.git repo. There are a
few version numbers in the branch that are wrong, which makes at least
tester unusable.
On Thu, Dec 21, 2017 at 12:19 PM, Gedare Bloom <gedare at rtems.org> wrote:
>  rtemstoolkit/version.py  | 2 +-
>  tester/rtems/version.cfg | 2 +-
>  2 files changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtemstoolkit/version.py b/rtemstoolkit/version.py
> index b90b3ea..a763bbc 100644
> --- a/rtemstoolkit/version.py
> +++ b/rtemstoolkit/version.py
> @@ -53,7 +53,7 @@ except (ValueError, SystemError):
>  # Default to an internal string.
> -_version = '4.12'
> +_version = '4.10'
>  _revision = 'not_released'
>  _version_str = '%s.%s' % (_version, _revision)
>  _released = False
> diff --git a/tester/rtems/version.cfg b/tester/rtems/version.cfg
> index 22e850b..fd84594 100644
> --- a/tester/rtems/version.cfg
> +++ b/tester/rtems/version.cfg
> @@ -32,4 +32,4 @@
>  # RTEMS Version
> -%define rtems_version 4.12
> +%define rtems_version 4.10
> 2.7.4
