Need Help to Further Reduce bsp_specs
Fri Dec 22 08:09:06 UTC 2017
On 21/12/17 08:15, Chris Johns wrote:
> On 21/12/17 5:47 pm, Sebastian Huber wrote:
>> Hello,
>> we should try to understand better why the things are how they are currently.
> Agreed.
>> In Newlib we have this ctr0.c:
>> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=blob;f=newlib/libc/sys/rtems/crt0.c;h=9778b985a180ba68990b40b6e4423aa970ca5ec7;hb=HEAD
>> This is the default start file for the RTEMS GCC:
>> https://gcc.gnu.org/viewcvs/gcc/trunk/gcc/config/rtems.h?view=markup
>>       * Dummy start/end specification to let linker work as
>>       * needed by autoconf scripts using this compiler.
>>      #undef STARTFILE_SPEC
>>      #define STARTFILE_SPEC "crt0.o%s"
>> We use the bsp_specs to override this (we could also use -nostartfiles at the
>> command line):
>>              %rename startfile old_startfile
>>              *startfile:
>>              %{!qrtems: %(old_startfile)} \
>>              %{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
>> Why do we define a STARTFILE_SPEC in GCC which we don't use for real applications?
> I good question. The gcc defaults should be focused on a user and the closer
> this is to other platforms the better.
>> The purpose of the ctr0.o seems to be to make the Autoconf stuff happy during
>> GCC build, e.g. for libstdc++.
> Do other build system tests, ie autoconf, require an installed BSP?
If you do link-time checks then we support currently two variants.
1. Via the Newlib ctr0.o which promises that a BSP will provide a proper
implementation eventually (using other compiler/linker options).
2. You provide all options to link against the real BSP libraries.
The support for 1. is actually quite nice. You can build libraries per
multilib with it.
>> One option would be to do this:
>> 1. Change STARTFILE_SPEC:
>> #define STARTFILE_SPEC "start.o%s crti.o%s crtbegin.o"
> What does a list mean?
Several startfiles. We also have endfiles.
>> 2. Rename Newlib ctr0.o into start.o and do NOT install it. This way it is used
>> only during GCC build to make the GCC Autoconf happy.
> OK.
>> 3. Provide start.o in all BSPs.
>> How do we deal with other Autoconf (or other link-time feature detection) stuff?
>> This change could break all the third party library build scripts.
> I do not think this can be avoided or we can never change what we have. I do not
> like the use of -B on the gcc command line.
I think the -B switch is the only way to add search paths at the command
line for startfiles, see "add_prefix.*startfile" in gcc/gcc.c.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
