[PATCH] 4.10: fix version number
Fri Dec 22 16:04:24 UTC 2017
On Thu, Dec 21, 2017 at 5:59 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 22/12/2017 08:21, Joel Sherrill wrote:
>> Gedare posted a patch about GNU inlines as I recall. It was needed with newer
>> GCC version compiling the old cross version. Just wanted to make sure it got
>> reviewed and pushed also
> Is this https://devel.rtems.org/ticket/2724 or https://devel.rtems.org/ticket/3262?
> If #3262 please read my comments in the ticket. This patch needs to be tested on
> more than RedHat Linux. For example is clang effected?
I agree with Chris. What I posted was a quick work-around so I can
make progress. I don't know about other hosts, FWIW this was on Ubuntu
16.04 LTS, I just found the referenced RHEL issue as the solution to
the same problem.
> Chris
