[rtems commit] taskmode.c: Ensure all error checking is done before modifying executing
Joel Sherrill
joel at rtems.org
Thu Dec 7 11:42:50 UTC 2017
Other than fixing those tests for smp, is it bad to just say the interrupt
disable part of task mode isn't supported in smp?
That could be the first step to deprecating that part of the task mode.
On Dec 7, 2017 2:01 AM, "Sebastian Huber" <
> This breaks tm04 and tm20 with --enable-smp.
> On 06/12/17 19:49, Joel Sherrill wrote:
>> Module: rtems
>> Branch: master
>> Commit: d2711c37f1f189863bd679064cd37a7b0f700494
>> Changeset: http://git.rtems.org/rtems/commit/?id=d2711c37f1f189863bd679
>> 064cd37a7b0f700494
>> Author: Joel Sherrill <joel at rtems.org>
>> Date: Tue Dec 5 09:54:56 2017 -0600
>> Also use single conditional expressions to simplify error checking.
>> Combined, this all resulted in a block of SMP enabled error checking.
>> Updates #3000.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171207/61e8adf0/attachment-0002.html>
