[PATCH 04/12] av5282: Simplify bsp_specs
Joel Sherrill
joel at rtems.org
Tue Dec 19 18:27:39 UTC 2017
Updates #3520.
c/src/lib/libbsp/m68k/av5282/bsp_specs | 6 +-----
c/src/lib/libbsp/m68k/av5282/startup/linkcmds | 2 ++
c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash | 2 ++
c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram | 2 ++
4 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/av5282/bsp_specs b/c/src/lib/libbsp/m68k/av5282/bsp_specs
index 5154de8..87638cc 100644
--- a/c/src/lib/libbsp/m68k/av5282/bsp_specs
+++ b/c/src/lib/libbsp/m68k/av5282/bsp_specs
@@ -1,13 +1,9 @@
%rename endfile old_endfile
%rename startfile old_startfile
-%rename link old_link
*startfile:
%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
*endfile:
%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/m68k/av5282/startup/linkcmds b/c/src/lib/libbsp/m68k/av5282/startup/linkcmds
index 01ba1c5..ff0fdda 100644
--- a/c/src/lib/libbsp/m68k/av5282/startup/linkcmds
+++ b/c/src/lib/libbsp/m68k/av5282/startup/linkcmds
@@ -31,6 +31,8 @@ __SRAMBASE = DEFINED(__SRAMBASE) ? __SRAMBASE : 0x20000000 ;
ENTRY(start)
+STARTUP(start.o)
MEMORY
ram : ORIGIN = 0, LENGTH = 16M
diff --git a/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash b/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash
index 45841ff..e194add 100644
--- a/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash
+++ b/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsflash
@@ -30,6 +30,8 @@ __IPSBAR = DEFINED(__IPSBAR) ? __IPSBAR : 0x40000000 ;
ENTRY(start)
+STARTUP(start.o)
MEMORY
diff --git a/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram b/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram
index c93ba85..976c08a 100644
--- a/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram
+++ b/c/src/lib/libbsp/m68k/av5282/startup/linkcmdsram
ENTRY(start)
+STARTUP(start.o)
MEMORY
1.8.3.1
