[PATCH 2/2] score: Introduce new monotonic clock
    Sebastian Huber
    Fri Dec 22 12:30:53 UTC 2017
Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS.  Add new
PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured
by timecounter).
Close #3264.
 cpukit/posix/src/alarm.c                        |   4 +-
 cpukit/posix/src/nanosleep.c                    |   6 +-
 cpukit/posix/src/pthread.c                      |   4 +-
 cpukit/posix/src/pthreadsetschedparam.c         |   2 +-
 cpukit/posix/src/timerdelete.c                  |   2 +-
 cpukit/posix/src/timersettime.c                 |   4 +-
 cpukit/posix/src/ualarm.c                       |   4 +-
 cpukit/rtems/src/ratemoncancel.c                |   2 +-
 cpukit/rtems/src/timercreate.c                  |   2 +-
 cpukit/rtems/src/timerreset.c                   |   2 +-
 cpukit/sapi/include/confdefs.h                  |   3 -
 cpukit/score/include/rtems/score/percpu.h       |  18 +++-
 cpukit/score/include/rtems/score/threadimpl.h   |  13 +--
 cpukit/score/include/rtems/score/watchdog.h     |   9 --
 cpukit/score/include/rtems/score/watchdogimpl.h |  92 +++--------------
 cpukit/score/src/threadqtimeout.c               | 128 ++++++++++--------------
 cpukit/score/src/watchdogtick.c                 |  16 ++-
 testsuites/sptests/spintrcritical08/init.c      |   4 +-
 testsuites/sptests/spintrcritical09/init.c      |   2 +-
 testsuites/sptests/spwatchdog/init.c            |   1 -
 20 files changed, 119 insertions(+), 199 deletions(-)
diff --git a/cpukit/posix/src/alarm.c b/cpukit/posix/src/alarm.c
index fcf8c1569a..bbfc96d31d 100644
--- a/cpukit/posix/src/alarm.c
+++ b/cpukit/posix/src/alarm.c
@@ -77,14 +77,14 @@ unsigned int alarm(
   now = cpu->Watchdog.ticks;
   remaining = (unsigned long) _Watchdog_Cancel(
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ],
+    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ],
     the_watchdog,
     now
   if ( ticks != 0 ) {
     _Watchdog_Insert(
       the_watchdog,
       now + ticks
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 5bd1b00aa9..7613df92d1 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -25,7 +25,7 @@
 #include <rtems/score/timespec.h>
-#include <rtems/score/todimpl.h>
+#include <rtems/score/timecounter.h>
 #include <rtems/posix/posixapi.h>
 #include <rtems/seterr.h>
@@ -93,7 +93,7 @@ int clock_nanosleep(
   } else {
-    _TOD_Get_zero_based_uptime_as_timespec( &uptime );
+    _Timecounter_Nanouptime( &uptime );
     end = _Watchdog_Future_timespec( &uptime, rqtp );
     _Thread_queue_Context_set_enqueue_timeout_monotonic_timespec(
       &queue_context,
@@ -119,7 +119,7 @@ int clock_nanosleep(
     if ( eno == EINTR ) {
       struct timespec actual_end;
-      _TOD_Get_zero_based_uptime_as_timespec( &actual_end );
+      _Timecounter_Nanouptime( &actual_end );
       if ( _Timespec_Less_than( &actual_end, end ) ) {
         _Timespec_Subtract( &actual_end, end, rmtp );
diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
index 43ed140b11..e05d4f3d19 100644
--- a/cpukit/posix/src/pthread.c
+++ b/cpukit/posix/src/pthread.c
@@ -69,7 +69,7 @@ void _POSIX_Threads_Sporadic_timer( Watchdog_Control *watchdog )
     _Priority_Node_set_inactive( &api->Sporadic.Low_priority );
-  _Watchdog_Per_CPU_remove_monotonic( &api->Sporadic.Timer );
+  _Watchdog_Per_CPU_remove_ticks( &api->Sporadic.Timer );
   _POSIX_Threads_Sporadic_timer_insert( the_thread, api );
   _Thread_Wait_release( the_thread, &queue_context );
@@ -141,7 +141,7 @@ static void _POSIX_Threads_Terminate_extension( Thread_Control *executing )
   api = executing->API_Extensions[ THREAD_API_POSIX ];
   _Thread_State_acquire( executing, &lock_context );
   _Thread_State_release( executing, &lock_context );
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index 77e0ecaf48..b6854a080c 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -69,7 +69,7 @@ static int _POSIX_Set_sched_param(
   api = the_thread->API_Extensions[ THREAD_API_POSIX ];
   _Priority_Node_set_priority( &the_thread->Real_priority, core_normal_prio );
diff --git a/cpukit/posix/src/timerdelete.c b/cpukit/posix/src/timerdelete.c
index 5c21e1e80d..7670838ac2 100644
--- a/cpukit/posix/src/timerdelete.c
+++ b/cpukit/posix/src/timerdelete.c
@@ -56,7 +56,7 @@ int timer_delete(
     cpu = _POSIX_Timer_Acquire_critical( ptimer, &lock_context );
     ptimer->state = POSIX_TIMER_STATE_FREE;
     _Watchdog_Remove(
       &ptimer->Timer
     _POSIX_Timer_Release( cpu, &lock_context );
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 381e5002ce..9212e49740 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -42,7 +42,7 @@ static void _POSIX_Timer_Insert(
   _TOD_Get( &ptimer->time );
   _Watchdog_Insert(
     &ptimer->Timer,
     cpu->Watchdog.ticks + ticks
@@ -152,7 +152,7 @@ int timer_settime(
     /* Stop the timer */
     _Watchdog_Remove(
       &ptimer->Timer
diff --git a/cpukit/posix/src/ualarm.c b/cpukit/posix/src/ualarm.c
index ead14d4469..371a961c94 100644
--- a/cpukit/posix/src/ualarm.c
+++ b/cpukit/posix/src/ualarm.c
@@ -107,7 +107,7 @@ useconds_t ualarm(
   remaining = (useconds_t) _Watchdog_Cancel(
     the_watchdog,
     now
@@ -118,7 +118,7 @@ useconds_t ualarm(
     cpu = _Per_CPU_Get();
     _Watchdog_Set_CPU( the_watchdog, cpu );
     _Watchdog_Insert(
       the_watchdog,
       now + ticks_initial
diff --git a/cpukit/rtems/src/ratemoncancel.c b/cpukit/rtems/src/ratemoncancel.c
index 0a88310d09..ee556a3153 100644
--- a/cpukit/rtems/src/ratemoncancel.c
+++ b/cpukit/rtems/src/ratemoncancel.c
@@ -32,7 +32,7 @@ void _Rate_monotonic_Cancel(
   _Rate_monotonic_Acquire_critical( the_period, lock_context );
-  _Watchdog_Per_CPU_remove_monotonic( &the_period->Timer );
+  _Watchdog_Per_CPU_remove_ticks( &the_period->Timer );
   the_period->state = RATE_MONOTONIC_INACTIVE;
   _Scheduler_Cancel_job(
     the_period->owner,
diff --git a/cpukit/rtems/src/timercreate.c b/cpukit/rtems/src/timercreate.c
index 444b07cfa5..0fff3d54cf 100644
--- a/cpukit/rtems/src/timercreate.c
+++ b/cpukit/rtems/src/timercreate.c
@@ -72,7 +72,7 @@ rtems_status_code _Timer_Fire(
     if ( _Timer_Is_interval_class( the_class ) ) {
       _Watchdog_Insert(
         &the_timer->Ticker,
         cpu->Watchdog.ticks + interval
diff --git a/cpukit/rtems/src/timerreset.c b/cpukit/rtems/src/timerreset.c
index 3718fffa66..6357160cf3 100644
--- a/cpukit/rtems/src/timerreset.c
+++ b/cpukit/rtems/src/timerreset.c
@@ -37,7 +37,7 @@ rtems_status_code rtems_timer_reset(
     if ( _Timer_Is_interval_class( the_timer->the_class ) ) {
       _Timer_Cancel( cpu, the_timer );
       _Watchdog_Insert(
         &the_timer->Ticker,
         cpu->Watchdog.ticks + the_timer->initial
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index b63d8937d4..75ea1427f7 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -3002,9 +3002,6 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   const uint32_t _Watchdog_Ticks_per_second = _CONFIGURE_TICKS_PER_SECOND;
-  const uint64_t _Watchdog_Monotonic_max_seconds =
-    UINT64_MAX / _CONFIGURE_TICKS_PER_SECOND;
    * This is the Classic API Configuration Table.
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 00528b5ce3..7d0a6c06bf 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -248,14 +248,13 @@ typedef struct {
 typedef enum {
-   * @brief Index for monotonic clock per-CPU watchdog header.
+   * @brief Index for tick clock per-CPU watchdog header.
-   * The reference time point for the monotonic clock is the system start.  The
+   * The reference time point for the tick clock is the system start.  The
    * clock resolution is one system clock tick.  It is used for the system
-   * clock tick based time services and the POSIX services using
-   * CLOCK_MONOTONIC.
+   * clock tick based time services.
-  PER_CPU_WATCHDOG_MONOTONIC,
+  PER_CPU_WATCHDOG_TICKS,
    * @brief Index for realtime clock per-CPU watchdog header.
@@ -267,6 +266,15 @@ typedef enum {
   PER_CPU_WATCHDOG_REALTIME,
+   * @brief Index for monotonic clock per-CPU watchdog header.
+   * The reference time point for the monotonic clock is the system start.  The
+   * clock resolution is one nanosecond.  It is used for the POSIX services
+   * using CLOCK_MONOTONIC.
+  PER_CPU_WATCHDOG_MONOTONIC,
    * @brief Count of per-CPU watchdog headers.
   PER_CPU_WATCHDOG_COUNT
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index b6722fae19..777158b77a 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1864,7 +1864,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Timer_initialize(
   _ISR_lock_Initialize( &timer->Lock, "Thread Timer" );
-  timer->header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+  timer->header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
   _Watchdog_Preinitialize( &timer->Watchdog, cpu );
@@ -1879,7 +1879,7 @@ RTEMS_INLINE_ROUTINE void _Thread_Add_timeout_ticks(
   _ISR_lock_ISR_disable_and_acquire( &the_thread->Timer.Lock, &lock_context );
   the_thread->Timer.header =
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
   the_thread->Timer.Watchdog.routine = _Thread_Timeout;
   _Watchdog_Per_CPU_insert_ticks( &the_thread->Timer.Watchdog, cpu, ticks );
@@ -1893,14 +1893,15 @@ RTEMS_INLINE_ROUTINE void _Thread_Timer_insert_realtime(
   uint64_t                        expire
-  ISR_lock_Context lock_context;
+  ISR_lock_Context  lock_context;
+  Watchdog_Header  *header;
-  the_thread->Timer.header =
-    &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
+  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
+  the_thread->Timer.header = header;
   the_thread->Timer.Watchdog.routine = routine;
-  _Watchdog_Per_CPU_insert_realtime( &the_thread->Timer.Watchdog, cpu, expire );
+  _Watchdog_Per_CPU_insert( &the_thread->Timer.Watchdog, cpu, header, expire );
   _ISR_lock_Release_and_ISR_enable( &the_thread->Timer.Lock, &lock_context );
diff --git a/cpukit/score/include/rtems/score/watchdog.h b/cpukit/score/include/rtems/score/watchdog.h
index dbb092bbef..71126d3508 100644
--- a/cpukit/score/include/rtems/score/watchdog.h
+++ b/cpukit/score/include/rtems/score/watchdog.h
@@ -147,15 +147,6 @@ extern const uint32_t _Watchdog_Nanoseconds_per_tick;
 extern const uint32_t _Watchdog_Ticks_per_second;
- * @brief The maximum number of seconds representable in the monotonic watchdog
- * format.
- * This constant is defined by the application configuration via
- * <rtems/confdefs.h>.
-extern const uint64_t _Watchdog_Monotonic_max_seconds;
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 9701fb772f..6fe9d5acf5 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -303,19 +303,19 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Next_first(
  * @brief The bits necessary to store 1000000000
  * (= WATCHDOG_NANOSECONDS_PER_SECOND) nanoseconds.
- * The expiration time is an unsigned 64-bit integer.  To store absolute
+ * The expiration time is an unsigned 64-bit integer.  To store nanoseconds
  * timeouts we use 30 bits (2**30 == 1073741824) for the nanoseconds and 34
  * bits for the seconds since UNIX Epoch.  This leads to a year 2514 problem.
 #define WATCHDOG_BITS_FOR_1E9_NANOSECONDS 30
- * @brief The maximum number of seconds representable in the realtime watchdog
- * format.
+ * @brief The maximum number of seconds representable in the nanoseconds
+ * watchdog format.
  * We have 2**34 bits for the seconds part.
-#define WATCHDOG_REALTIME_MAX_SECONDS 0x3ffffffff
+#define WATCHDOG_MAX_SECONDS 0x3ffffffff
 RTEMS_INLINE_ROUTINE bool _Watchdog_Is_valid_timespec(
   const struct timespec *ts
@@ -362,34 +362,11 @@ RTEMS_INLINE_ROUTINE const struct timespec * _Watchdog_Future_timespec(
   return now;
-RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_monotonic_timespec(
+RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_timespec(
-  return ts->tv_sec >= _Watchdog_Monotonic_max_seconds;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Monotonic_from_timespec(
-  const struct timespec *ts
-  uint64_t ticks;
-  _Assert( _Watchdog_Is_valid_timespec( ts ) );
-  _Assert( ts->tv_sec >= 0 );
-  _Assert( !_Watchdog_Is_far_future_monotonic_timespec( ts ) );
-  ticks = (uint64_t) ts->tv_sec * _Watchdog_Ticks_per_second;
-  ticks += (unsigned long) ts->tv_nsec / _Watchdog_Nanoseconds_per_tick;
-  return ticks;
-RTEMS_INLINE_ROUTINE bool _Watchdog_Is_far_future_realtime_timespec(
-  return ts->tv_sec > WATCHDOG_REALTIME_MAX_SECONDS;
+  return ts->tv_sec > WATCHDOG_MAX_SECONDS;
 RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_seconds(
@@ -411,7 +388,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Ticks_from_timespec(
-  _Assert( !_Watchdog_Is_far_future_realtime_timespec( ts ) );
+  _Assert( !_Watchdog_Is_far_future_timespec( ts ) );
   ticks = (uint64_t) ts->tv_sec;
   ticks <<= WATCHDOG_BITS_FOR_1E9_NANOSECONDS;
@@ -457,7 +434,7 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks(
   uint64_t          expire;
-  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
@@ -468,46 +445,19 @@ RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_ticks(
   return expire;
-RTEMS_INLINE_ROUTINE bool _Watchdog_Per_CPU_lazy_insert_monotonic(
-  Watchdog_Control *the_watchdog,
-  Per_CPU_Control  *cpu,
-  uint64_t          expire
-  Watchdog_Header  *header;
-  bool              insert;
-  _Watchdog_Set_CPU( the_watchdog, cpu );
-  _Watchdog_Per_CPU_acquire_critical( cpu, &lock_context );
-  insert = ( expire > cpu->Watchdog.ticks );
-  if ( insert ) {
-    _Watchdog_Insert(header, the_watchdog, expire);
-  _Watchdog_Per_CPU_release_critical( cpu, &lock_context );
-  return insert;
-RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert_realtime(
+RTEMS_INLINE_ROUTINE uint64_t _Watchdog_Per_CPU_insert(
+  Watchdog_Header  *header,
   uint64_t          expire
-  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
+  _Watchdog_Insert( header, the_watchdog, expire );
   return expire;
@@ -528,21 +478,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove(
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_monotonic(
-  Per_CPU_Control *cpu;
-  cpu = _Watchdog_Get_CPU( the_watchdog );
-  _Watchdog_Per_CPU_remove(
-    the_watchdog,
-    cpu,
-RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_realtime(
+RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_ticks(
@@ -552,7 +488,7 @@ RTEMS_INLINE_ROUTINE void _Watchdog_Per_CPU_remove_realtime(
     the_watchdog,
     cpu,
diff --git a/cpukit/score/src/threadqtimeout.c b/cpukit/score/src/threadqtimeout.c
index 691f643493..0993fd4fe7 100644
--- a/cpukit/score/src/threadqtimeout.c
+++ b/cpukit/score/src/threadqtimeout.c
@@ -34,50 +34,13 @@ void _Thread_queue_Add_timeout_ticks(
-static bool _Thread_queue_Lazy_insert_monotonic_timespec(
+static void _Thread_queue_Add_timeout_timespec(
+  Thread_queue_Queue    *queue,
   Thread_Control        *the_thread,
   Per_CPU_Control       *cpu_self,
-  const struct timespec *abstime
-  uint64_t         expire;
-  bool             insert;
-  if ( abstime->tv_sec < 0 ) {
-    expire = 0;
-  } else if ( _Watchdog_Is_far_future_monotonic_timespec( abstime ) ) {
-    expire = WATCHDOG_MAXIMUM_TICKS;
-  } else {
-    expire = _Watchdog_Monotonic_from_timespec( abstime );
-  _ISR_lock_ISR_disable_and_acquire(
-    &the_thread->Timer.Lock,
-    &lock_context
-    &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
-  the_thread->Timer.Watchdog.routine = _Thread_Timeout;
-  insert = _Watchdog_Per_CPU_lazy_insert_monotonic(
-    &the_thread->Timer.Watchdog,
-    cpu_self,
-    expire
-  _ISR_lock_Release_and_ISR_enable(
-    &lock_context
-  return insert;
-void _Thread_queue_Add_timeout_monotonic_timespec(
-  Thread_queue_Queue   *queue,
-  Thread_Control       *the_thread,
-  Per_CPU_Control      *cpu_self,
-  Thread_queue_Context *queue_context
+  Thread_queue_Context  *queue_context,
+  const struct timespec *now
   const struct timespec *abstime;
@@ -85,46 +48,17 @@ void _Thread_queue_Add_timeout_monotonic_timespec(
   abstime = queue_context->Timeout.arg;
   if ( _Watchdog_Is_valid_timespec( abstime ) ) {
-    if (
-      !_Thread_queue_Lazy_insert_monotonic_timespec(
-        the_thread,
-        cpu_self,
-        abstime
-      _Thread_Continue( the_thread, STATUS_TIMEOUT );
-  } else {
-    _Thread_Continue( the_thread, STATUS_INVALID_NUMBER );
-void _Thread_queue_Add_timeout_realtime_timespec(
-  const struct timespec *abstime;
-  abstime = queue_context->Timeout.arg;
-  if ( _Watchdog_Is_valid_timespec( abstime ) ) {
-    uint64_t        expire;
-    struct timespec now;
+    uint64_t expire;
       expire = 0;
-    } else if ( _Watchdog_Is_far_future_realtime_timespec( abstime ) ) {
+    } else if ( _Watchdog_Is_far_future_timespec( abstime ) ) {
     } else {
       expire = _Watchdog_Ticks_from_timespec( abstime );
-    _Timecounter_Getnanotime( &now );
-    if ( expire > _Watchdog_Ticks_from_timespec( &now ) ) {
+    if ( expire > _Watchdog_Ticks_from_timespec( now ) ) {
@@ -132,12 +66,12 @@ void _Thread_queue_Add_timeout_realtime_timespec(
         &lock_context
-        &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ];
         cpu_self,
+        header,
         expire
@@ -152,3 +86,43 @@ void _Thread_queue_Add_timeout_realtime_timespec(
+void _Thread_queue_Add_timeout_monotonic_timespec(
+  Thread_Control       *the_thread,
+  Per_CPU_Control      *cpu_self,
+  struct timespec now;
+  _Timecounter_Getnanouptime( &now );
+  _Thread_queue_Add_timeout_timespec(
+    queue,
+    the_thread,
+    cpu_self,
+    queue_context,
+    &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ],
+    &now
+void _Thread_queue_Add_timeout_realtime_timespec(
+  _Timecounter_Getnanotime( &now );
+    queue,
+    the_thread,
+    cpu_self,
+    queue_context,
+    &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_REALTIME ],
+    &now
diff --git a/cpukit/score/src/watchdogtick.c b/cpukit/score/src/watchdogtick.c
index e9160f2ea1..2f11357019 100644
--- a/cpukit/score/src/watchdogtick.c
+++ b/cpukit/score/src/watchdogtick.c
@@ -70,7 +70,7 @@ void _Watchdog_Tick( Per_CPU_Control *cpu )
   ++ticks;
   cpu->Watchdog.ticks = ticks;
   first = _Watchdog_Header_first( header );
   if ( first != NULL ) {
@@ -83,6 +83,20 @@ void _Watchdog_Tick( Per_CPU_Control *cpu )
+  header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+  first = _Watchdog_Header_first( header );
+  if ( first != NULL ) {
+    _Watchdog_Tickle(
+      header,
+      first,
+      _Watchdog_Ticks_from_timespec( &now ),
+      &cpu->Watchdog.Lock,
+      &lock_context
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index 559a1e421d..aab5701ed4 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -45,7 +45,7 @@ static rtems_timer_service_routine test_release_from_isr(
   Per_CPU_Control *cpu = _Per_CPU_Get();
-  Watchdog_Header *header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+  Watchdog_Header *header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
   Watchdog_Control *watchdog = (Watchdog_Control *) header->first;
   if (
@@ -55,7 +55,7 @@ static rtems_timer_service_routine test_release_from_isr(
     Thread_Wait_flags flags = _Thread_Wait_flags_get( thread );
-    _Watchdog_Per_CPU_remove_monotonic( watchdog );
+    _Watchdog_Per_CPU_remove_ticks( watchdog );
     rtems_test_assert( getState() == RATE_MONOTONIC_ACTIVE );
diff --git a/testsuites/sptests/spintrcritical09/init.c b/testsuites/sptests/spintrcritical09/init.c
index dc5b985ce7..63cfa2b5fb 100644
--- a/testsuites/sptests/spintrcritical09/init.c
+++ b/testsuites/sptests/spintrcritical09/init.c
@@ -39,7 +39,7 @@ static rtems_timer_service_routine test_release_from_isr(
   Per_CPU_Control *cpu_self = _Per_CPU_Get();
-  Watchdog_Header *header = &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_MONOTONIC ];
+  Watchdog_Header *header = &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
   if (
diff --git a/testsuites/sptests/spwatchdog/init.c b/testsuites/sptests/spwatchdog/init.c
index 5b6266d033..7b844d790a 100644
--- a/testsuites/sptests/spwatchdog/init.c
+++ b/testsuites/sptests/spwatchdog/init.c
@@ -59,7 +59,6 @@ static void test_watchdog_config( void )
   rtems_test_assert( _Watchdog_Nanoseconds_per_tick == 10000000 );
   rtems_test_assert( _Watchdog_Ticks_per_second == 100 );
-  rtems_test_assert( _Watchdog_Monotonic_max_seconds == 184467440737095516 );
   rtems_test_assert( rtems_clock_get_ticks_per_second() == 100 );
   #undef rtems_clock_get_ticks_per_second
2.12.3
