GSoC Mentors / Projects of Interest
Tanu Hari Dixit tokencolour at gmail.com
Wed Feb 1 03:55:25 UTC 2017
> * You removed the "Introduction" section. Any reason or just an oversight?
> * The 'status' field is gone too. But, I think the status is not
> needed in the ticket format.
I removed the "Introduction" section by mistake. I'll include it.
> Did you face any difficulties in making the transition? It would be
> good to document your workflow on the Open Projects page.
I wikiformatted the text myself. But it would have been better if I
had just copied the already formatted text that pops up when we try to
edit the project page
(https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP?action=edit).
No difficulties as such. I'll document the workflow on the open
projects page.
> We should convert all of the open projects to tickets eventually. And
> then generate a report in the Open Projects page based on the tickets.
> I have done this for the BSP ones and found the following changes
> should be made in the workflow:
Could you please direct me to the tickets you created? I couldn't find
them on Trac.
> I knew I had bought at least one so went to Amazon to see what we
> have here at OAR.
> https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-Support/dp/B004LBXO2A
> Other folks in the community may have alternatives. It is a pretty generic
> piece of hardware. But there was that issue with the FTDI driver refusing
> to work with cloned FTDI chips. So I would bet there are some out there
> you don't want.
I'll include the above hyperlink.
Thanks,
Tanu Hari Dixit.
On Wed, Feb 1, 2017 at 4:33 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit <tokencolour at gmail.com>
>> wrote:
>> > Hello,
>> > I created (https://devel.rtems.org/ticket/2891#ticket) on the lines of
>> > Gedare's advice for this open project
>> > (https://devel.rtems.org/wiki/Developer/Projects/Open/ImproveBeagleBSP).
>> Looks nice, a few minor things:
>> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page is
>> > probably broken. What should I replace it with? Please tell if some
>> See if you can find something appropriate on Google?
> have here at OAR.
> you don't want.
>> > edit is needed and whether I should follow this pattern. Furthermore,
>> > please indicate whether this project is of interest. Also which other
>> > open projects should be converted to tickets?
>> * Use only one keyword. I prefer "SoC" so it is generic to other
>> 'summer of code' style projects.
>> * Use the components field to further categorize. We have some obvious
>> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
>> Others should be identified or else we can create new components if
>> necessary. I'd like to stick with the current subheadings for this
>> year's GSoC, but we can revise later.
>> > Probably the community is interested in the idea to create simple
>> > examples or sanity tests for all RTEMS directives so that they can be
>> > included in the documentation (something that is user friendly). Also,
>> > there was a thread titled 'Desirable Application Stacks (Add-On
>> > Library Collections)' . Which ideas can be derived from there?
>> > Regards,
>> > Tanu Hari Dixit.
>> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org> wrote:
>> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit
>> >>> wrote:
>> >>> > I'll be glad to do it. Please guide me as to how to proceed.
>> >>> We will need to import each existing Open Project description into a
>> >>> new ticket. It would be best to start with one to "try it out". The
>> >>> project title should be the Summary of the ticket, the text of the
>> >>> project page should be converted into the Description of the ticket,
>> >>> type should be Enhancement, Milestone "Indefinite", and put GSoC into
>> >>> the keywords, and we might want to use some other keywords e.g. to
>> >>> define the project type (e.g. one of: testing, ecosystem, kernel,
>> >>> statistics, BSP, API, libbsd, languages, libraries). The owner should
>> >>> be assigned to one of the mentors if indicated, with others in CC if
>> >>> any, or else set blank.
>> >> I agree it would be nice to get all the Open Project ideas as tickets
>> >> and
>> >> off the Wiki. Some of the ideas are likely no longer interesting/valid
>> >> at
>> >> this point and could just be deleted.
>> >> FWIW I also want to move some of the Wiki content into Sphinx
>> >> documents.
>> >> I think being able to release them with RTEMS branches and use git
>> >> for revision control.
>> >> --joel
>> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom <gedare at rtems.org>
>> >>> > wrote:
>> >>> >> Yes that would be much nicer. Maybe we can get potential GSoC
>> >>> >> Students
>> >>> >> to do the work ;)
>> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
>> >>> >> <sebastian.huber at embedded-brains.de> wrote:
>> >>> >> > Maybe we should move all this open projects wiki stuff into
>> >>> >> > tickets
>> >>> >> > with
>> >>> >> > some sort of "GSoC" tag.
>> >>> >> > Sebastian Huber, embedded brains GmbH
>> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> >>> >> > Phone   : +49 89 189 47 41-16
>> >>> >> > Fax     : +49 89 189 47 41-09
>> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
>> >>> >> > PGP     : Public key available on request.
>> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
>> >>> >> > EHUG.
>> >>> >> _______________________________________________
>> >>> >> devel mailing list
>> >>> >> devel at rtems.org
>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
>> >>> devel mailing list
>> >>> devel at rtems.org
