[PATCH] c-user: Add self-contained objects chapter
Sebastian Huber
Wed Feb 1 10:17:57 UTC 2017
Update #2843.
c-user/index.rst | 1 +
c-user/self_contained_objects.rst | 337 ++++++++++++++++++++++++++++++++++++++
2 files changed, 338 insertions(+)
create mode 100644 c-user/self_contained_objects.rst
diff --git a/c-user/index.rst b/c-user/index.rst
index 7937042..4b7fe22 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -62,6 +62,7 @@ to the Community Project hosted at http://www.rtems.org/.
board_support_packages
user_extensions
configuring_a_system
+ self_contained_objects
multiprocessing
symmetric_multiprocessing_services
pci_library
diff --git a/c-user/self_contained_objects.rst b/c-user/self_contained_objects.rst
new file mode 100644
index 0000000..76c2a64
--- /dev/null
+++ b/c-user/self_contained_objects.rst
@@ -0,0 +1,337 @@
+.. comment SPDX-License-Identifier: CC-BY-SA-4.0
+.. COMMENT: Copyright (c) 2014, 2017.
+.. COMMENT: embedded brains GmbH.
+.. COMMENT: All rights reserved.
+Self-Contained Objects
+Introduction
+One of the original design goals of RTEMS was the support for heterogeneous
+computing based on message passing. This was realized by synchronization
+objects with an architecture-independent identifier provided by the system
+during object creation (a 32-bit unsigned integer used as a bitfield) and a
+user-defined four character name. This approach in the so called Classic API
+has some weaknesses:
+* Dynamic memory (the workspace) is used to allocate object pools. This
+ requires a complex configuration with heavy use of the C pre-processor.
+ Dynamic memory is forbidden by some coding standards, e.g. MISRA C:2012
+ :cite:`MISRA:2012:C`.
+* Objects are created via function calls which return an object identifier.
+ The object operations use this identifier and map it internally to an object
+ representation.
+* The object identifier is only known at run-time. This hinders compiler
+ optimizations and static analysis.
+* The objects reside in a table, e.g. they are suspect to false sharing of
+ cache lines :cite:`Drepper:2007:Memory`.
+* The object operations use a rich set of options and attributes. For each
+ object operation these parameters must be evaluated and validated at run-time
+ to figure out what to do exactly for this operation.
+For applications that use fine grained locking the mapping of the identifier to
+the object representation and the parameter evaluation are a significant
+overhead that may degrade the performance dramatically. An example is the `new
+network stack (libbsd) <https://git.rtems.org/rtems-libbsd>`_ which uses
+hundreds of locks in a basic setup and the OpenMP support.
+To overcome these issues new self-contained objects are available in RTEMS 4.12
+via the Newlib supplied :file:`<threads.h>`, :file:`<pthread.h>` and
+:file:`<sys/lock.h>` header files. The following synchronization objects are
+provided
+* POSIX spinlocks,
+* mutexes,
+* recursive mutexes,
+* condition variables,
+* counting semaphores,
+* binary semaphores, and
+* Futex synchronization :cite:`Franke:2002:Futex`.
+This allows much better performance in SMP configurations as well as in
+uni-processor configurations. The application configuration is significantly
+simplified, since it is no longer necessary to account for lock objects used by
+Newlib and GCC. The Newlib defined self-contained objects can be a statically
+initialized and reside in the ``.bss`` section. Destruction is a no-operation.
+Self-Contained Objects API
+To give the RTEMS users access to self-contained objects an API is necessary.
+One option is to use the POSIX threads API (pthreads) and change its
+implementation to use self-contained objects. However, there are some other
+things to consider. Users of the Classic API may want to run their
+applications with different RTEMS versions. Since the POSIX threads API is
+optional it may be not available at all, for example in a stripped down space
+qualified version. The POSIX threads API has a lot of options that need
+run-time evaluation, so that optimal performance is not achievable. There are
+a variety of error conditions. This is a problem in combination with some
+coding standards, e.g. MISRA C:2012. APIs used by Linux (e.g.
+`<linux/mutex.h>
+<http://lxr.free-electrons.com/source/include/linux/mutex.h>`_) or the FreeBSD
+kernel (e.g.
+`MUTEX(9) <https://www.freebsd.org/cgi/man.cgi?query=mutex&sektion=9>`_) are
+better suited as a template for high-performance synchronization objects.
+The API defined in the following sections should be implementable via the
+Classic API, the self-contained objects present in RTEMS 4.12 and the POSIX
+API. Timed operations are not available since the timeout semantics of the
+Classic API and the POSIX threads API are quite different.
+Mutual Exclusion
+The :c:type:`rtems_mutex` provides mutual-exclusion synchronization using the
+:ref:`PriorityInheritance` in uni-processor configurations or the :ref:`OMIP`
+in SMP configurations. Recursive locking is not supported
+:cite:`Williams:2012:CA`.
+.. c:type:: rtems_mutex
+The ``rtems_mutex`` is the type of a mutual-exclusion synchronization object.
+The storage space for this object must be provided by the user. There are no
+defined comparison or assignment operators for this type. Only the object
+itself may be used for performing synchronization. The result of referring to
+copies of the object in calls to :c:func:`rtems_mutex_lock`,
+:c:func:`rtems_mutex_unlock`, and :c:func:`rtems_mutex_destroy` is undefined.
+Objects of this type must be initialized via :c:func:`RTEMS_MUTEX_INITIALIZER`
+or :c:func:`rtems_mutex_init` and must be destroyed via
+:c:func:`rtems_mutex_destroy`.
+.. c:function:: RTEMS_MUTEX_INITIALIZER(name)
+An initializer for static initialization. It is equivalent to a call to
+:c:func:`rtems_mutex_init`. Global mutexes without a name may reside in the
+``.bss`` section.
+.. c:function:: void rtems_mutex_init(rtems_mutex *mutex, const char *name)
+Initializes the ``mutex`` with the specified ``name``. The ``name`` must be
+persistent throughout the life-time of the mutex. The mutex is unlocked after
+initialization.
+.. c:function:: void rtems_mutex_lock(rtems_mutex *mutex)
+Locks the ``mutex``. In case the mutex is currently locked, then the thread is
+blocked until it becomes the mutex owner. Threads wait in priority order.
+This function must be called from thread context with interrupts enabled.
+.. c:function:: void rtems_mutex_unlock(rtems_mutex *mutex)
+Unlocks the ``mutex``. In case the currently executing thread is not the owner
+of the ``mutex``, then the result is unpredictable.
+.. c:function:: void rtems_mutex_destroy(rtems_mutex *mutex)
+Destroys the ``mutex``. In case the ``mutex`` is locked or still in use, then
+the result is unpredictable.
+Condition Variables
+The :c:type:`rtems_condition` provides a condition variable synchronization
+object.
+.. c:type:: rtems_condition
+The ``rtems_condition`` is the type of a condition variable object. The
+storage space for this object must be provided by the user. There are no
+copies of the object in calls to :c:func:`rtems_condition_wait`,
+:c:func:`rtems_condition_signal`, :c:func:`rtems_condition_broadcast`, and
+:c:func:`rtems_condition_destroy` is undefined. Objects of this type must be
+initialized via :c:func:`RTEMS_CONDITION_INITIALIZER` or
+:c:func:`rtems_condition_init` and must be destroyed via
+:c:func:`rtems_condition_destroy`.
+.. c:function:: RTEMS_CONDITION_INITIALIZER(name)
+:c:func:`rtems_condition_init`. Global condition variables without a name may
+reside in the ``.bss`` section.
+.. c:function:: void rtems_condition_init(rtems_condition *condition, const char *name)
+Initializes the ``condition`` with the specified ``name``. The ``name`` must
+be persistent throughout the life-time of the condition variable.
+.. c:function:: void rtems_condition_wait(rtems_condition *condition, rtems_mutex *mutex)
+Atomically waits for the condition and unlocks the mutex. Once the condition
+is signalled to the thread it wakes up and locks the mutex. Threads wait in
+priority order.
+.. c:function:: void rtems_condition_signal(rtems_condition *condition)
+Signals the condition to the highest priority waiting thread. If no threads
+wait currently for the condition, then nothing happens.
+.. c:function:: void rtems_condition_broadcast(rtems_condition *condition)
+Signals the condition to all waiting threads. If no threads wait currently for
+the condition, then nothing happens.
+.. c:function:: void rtems_condition_destroy(rtems_condition *condition)
+Destroys the ``condition``. In case the ``condition`` still in use, then the
+result is unpredictable.
+Counting Semaphores
+The :c:type:`rtems_counting_semaphore` provides a counting semaphore
+synchronization object.
+.. c:type:: rtems_counting_semaphore
+The ``rtems_counting_semaphore`` is the type of a counting semaphore object.
+copies of the object in calls to :c:func:`rtems_counting_semaphore_wait`,
+:c:func:`rtems_counting_semaphore_post`, and
+:c:func:`rtems_counting_semaphore_destroy` is undefined. Objects of this type
+must be initialized via :c:func:`RTEMS_COUNTING_SEMAPHORE_INITIALIZER` or
+:c:func:`rtems_counting_semaphore_init` and must be destroyed via
+:c:func:`rtems_counting_semaphore_destroy`.
+.. c:function:: RTEMS_COUNTING_SEMAPHORE_INITIALIZER(name, value)
+:c:func:`rtems_counting_semaphore_init`. Global counting semaphores without a
+name may reside in the ``.bss`` section.
+.. c:function:: void rtems_counting_semaphore_init(rtems_counting_semaphore *semaphore, const char *name, unsigned int count)
+Initializes the ``semaphore`` with the specified ``name`` and ``count``. The
+``name`` must be persistent throughout the life-time of the counting semaphore.
+The initial value is set to ``count``.
+.. c:function:: void rtems_counting_semaphore_wait(rtems_counting_semaphore *semaphore)
+Waits for the counting semaphore. In case the current semaphore count is
+positive, then the count is decremented and the function returns immediately,
+otherwise the thread is blocked waiting for a semaphore post. Threads wait in
+priority order.
+.. c:function:: void rtems_counting_semaphore_post(rtems_counting_semaphore *semaphore)
+Posts the counting semaphore. In case at least one thread is waiting on the
+counting semaphore, then the highest priority thread is woken up, otherwise the
+current count is incremented.
+This function may be called from interrupt context. In case it is called from
+thread context, then interrupts must be enabled.
+.. c:function:: void rtems_counting_semaphore_destroy(rtems_counting_semaphore *semaphore)
+Destroys the ``semaphore``. In case the ``semaphore`` still in use, then the
+Binary Semaphores
+The :c:type:`rtems_binary_semaphore` provides a binary semaphore
+.. c:type:: rtems_binary_semaphore
+The ``rtems_binary_semaphore`` is the type of a binary semaphore object. The
+copies of the object in calls to :c:func:`rtems_binary_semaphore_wait`,
+:c:func:`rtems_binary_semaphore_post`, and
+:c:func:`rtems_binary_semaphore_destroy` is undefined. Objects of this type
+must be initialized via :c:func:`RTEMS_BINARY_SEMAPHORE_INITIALIZER` or
+:c:func:`rtems_binary_semaphore_init` and must be destroyed via
+:c:func:`rtems_binary_semaphore_destroy`.
+.. c:function:: RTEMS_BINARY_SEMAPHORE_INITIALIZER(name)
+:c:func:`rtems_binary_semaphore_init`. Global binary semaphores without a name
+may reside in the ``.bss`` section.
+.. c:function:: void rtems_binary_semaphore_init(rtems_binary_semaphore *semaphore, const char *name)
+Initializes the ``semaphore`` with the specified ``name``. The ``name`` must
+be persistent throughout the life-time of the binary semaphore. The initial
+value is set to zero.
+.. c:function:: void rtems_binary_semaphore_wait(rtems_binary_semaphore *semaphore)
+Waits for the binary semaphore. In case the current semaphore count is
+priority order.
+.. c:function:: void rtems_binary_semaphore_post(rtems_binary_semaphore *semaphore)
+Posts the binary semaphore. In case at least one thread is waiting on the
+binary semaphore, then the highest priority thread is woken up, otherwise the
+current count is set to one.
+.. c:function:: void rtems_binary_semaphore_destroy(rtems_binary_semaphore *semaphore)
+Threads
+.. warning::
+ The self-contained threads support is work in progress. In contrast to the
+ synchronization objects the self-contained thread support is not just an API
+ glue layer to already existing implementations.
+The :c:type:`rtems_thread` provides a thread of execution.
+.. c:type:: rtems_thread
+The ``rtems_thread`` is the type of a thread object.
+.. c:function:: RTEMS_THREAD_INITIALIZER(name, stack_size, priority, flags, entry, arg)
+.. c:function:: void rtems_thread_start(rtems_thread *thread, const char *name, size_t stack_size, uint32_t priority, uint32_t flags, void (*entry)(void *), void *arg)
+.. c:function:: void rtems_thread_restart(rtems_thread *thread, void *arg)
+.. c:function:: void rtems_thread_event_send(rtems_thread *thread, uint32_t events)
+.. c:function:: void rtems_thread_event_poll(rtems_thread *thread, uint32_t events_of_interest, uint32_t *actual_events)
+.. c:function:: void rtems_thread_event_wait_all(rtems_thread *thread, uint32_t events_of_interest, uint32_t *actual_events)
+.. c:function:: void rtems_thread_event_wait_any(rtems_thread *thread, uint32_t events_of_interest, uint32_t *actual_events)
+.. c:function:: void rtems_thread_destroy(rtems_thread *thread)
+.. c:function:: void rtems_thread_self_destroy(void)
1.8.4.5
