[PATCH] Prefix confdefs.h internal def with an underscore
Sebastian Huber
Wed Feb 1 14:11:12 UTC 2017
Close #2895.
cpukit/sapi/include/confdefs.h | 803 ++++++++++++++++++-----------------------
1 file changed, 350 insertions(+), 453 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index fdfc7c0..eb121a8 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -55,6 +55,11 @@
extern "C" {
#endif
+ * Internal defines must be prefixed with _CONFIGURE to distinguish them from
+ * user-provided options which use a CONFIGURE prefix.
* @defgroup Configuration RTEMS Configuration
@@ -107,9 +112,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#if (defined(RTEMS_NEWLIB) && !defined(CONFIGURE_DISABLE_NEWLIB_REENTRANCY))
- #define CONFIGURE_NEWLIB_EXTENSION 1
+ #define _CONFIGURE_NEWLIB_EXTENSION 1
#else
- #define CONFIGURE_NEWLIB_EXTENSION 0
+ #define _CONFIGURE_NEWLIB_EXTENSION 0
#endif
#ifndef RTEMS_SCHEDSIM
@@ -135,23 +140,23 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 3
#endif
* Semaphore count used by the IO library.
-#define CONFIGURE_LIBIO_SEMAPHORES 1
+#define _CONFIGURE_LIBIO_SEMAPHORES 1
* POSIX key count used by the IO library.
-#define CONFIGURE_LIBIO_POSIX_KEYS 1
+#define _CONFIGURE_LIBIO_POSIX_KEYS 1
* Driver Manager Configuration
#ifdef RTEMS_DRVMGR_STARTUP
- #define CONFIGURE_DRVMGR_SEMAPHORES 1
+ #define _CONFIGURE_DRVMGR_SEMAPHORES 1
#else
- #define CONFIGURE_DRVMGR_SEMAPHORES 0
+ #define _CONFIGURE_DRVMGR_SEMAPHORES 0
#endif
#ifdef CONFIGURE_INIT
@@ -164,13 +169,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
const uint32_t rtems_libio_number_iops = RTEMS_ARRAY_SIZE(rtems_libio_iops);
#endif
* This macro determines if termios is disabled by this application.
* This only means that resources will not be reserved. If you end
* up using termios, it will fail.
#ifdef CONFIGURE_TERMIOS_DISABLED
- #define CONFIGURE_TERMIOS_SEMAPHORES 0
+ #define _CONFIGURE_TERMIOS_SEMAPHORES 0
#else
* This macro specifies the number of serial or PTY ports that will
@@ -180,11 +185,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_NUMBER_OF_TERMIOS_PORTS 1
#endif
* This macro reserves the number of semaphores required by termios
* based upon the number of communication ports that will use it.
- #define CONFIGURE_TERMIOS_SEMAPHORES \
+ #define _CONFIGURE_TERMIOS_SEMAPHORES \
((CONFIGURE_NUMBER_OF_TERMIOS_PORTS * 4) + 1)
#endif
@@ -245,30 +250,26 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_PIPES 0
#endif
* This specifies the number of barriers required for the configured
* number of FIFOs and named pipes.
- * This is an internal parameter.
#if CONFIGURE_MAXIMUM_FIFOS > 0 || CONFIGURE_MAXIMUM_PIPES > 0
- #define CONFIGURE_BARRIERS_FOR_FIFOS \
+ #define _CONFIGURE_BARRIERS_FOR_FIFOS \
(2 * (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES))
#else
- #define CONFIGURE_BARRIERS_FOR_FIFOS 0
+ #define _CONFIGURE_BARRIERS_FOR_FIFOS 0
#endif
* This specifies the number of semaphores required for the configured
- #define CONFIGURE_SEMAPHORES_FOR_FIFOS \
+ #define _CONFIGURE_SEMAPHORES_FOR_FIFOS \
(1 + (CONFIGURE_MAXIMUM_FIFOS + CONFIGURE_MAXIMUM_PIPES))
#else
- #define CONFIGURE_SEMAPHORES_FOR_FIFOS 0
+ #define _CONFIGURE_SEMAPHORES_FOR_FIFOS 0
#endif
@@ -439,9 +440,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#define CONFIGURE_FILESYSTEM_ENTRY_NFS \
{ RTEMS_FILESYSTEM_TYPE_NFS, rtems_nfs_initialize }
- #define CONFIGURE_SEMAPHORES_FOR_NFS ((CONFIGURE_MAXIMUM_NFS_MOUNTS * 2) + 1)
+ #define _CONFIGURE_SEMAPHORES_FOR_NFS ((CONFIGURE_MAXIMUM_NFS_MOUNTS * 2) + 1)
#else
- #define CONFIGURE_SEMAPHORES_FOR_NFS 0
+ #define _CONFIGURE_SEMAPHORES_FOR_NFS 0
#endif
@@ -455,9 +456,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#define CONFIGURE_FILESYSTEM_ENTRY_DOSFS \
{ RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize }
- #define CONFIGURE_SEMAPHORES_FOR_DOSFS CONFIGURE_MAXIMUM_DOSFS_MOUNTS
+ #define _CONFIGURE_SEMAPHORES_FOR_DOSFS CONFIGURE_MAXIMUM_DOSFS_MOUNTS
#else
- #define CONFIGURE_SEMAPHORES_FOR_DOSFS 0
+ #define _CONFIGURE_SEMAPHORES_FOR_DOSFS 0
#endif
@@ -471,9 +472,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#define CONFIGURE_FILESYSTEM_ENTRY_RFS \
{ RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise }
- #define CONFIGURE_SEMAPHORES_FOR_RFS CONFIGURE_MAXIMUM_RFS_MOUNTS
+ #define _CONFIGURE_SEMAPHORES_FOR_RFS CONFIGURE_MAXIMUM_RFS_MOUNTS
#else
- #define CONFIGURE_SEMAPHORES_FOR_RFS 0
+ #define _CONFIGURE_SEMAPHORES_FOR_RFS 0
#endif
@@ -487,23 +488,21 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#define CONFIGURE_FILESYSTEM_ENTRY_JFFS2 \
{ RTEMS_FILESYSTEM_TYPE_JFFS2, rtems_jffs2_initialize }
- #define CONFIGURE_SEMAPHORES_FOR_JFFS2 CONFIGURE_MAXIMUM_JFFS2_MOUNTS
+ #define _CONFIGURE_SEMAPHORES_FOR_JFFS2 CONFIGURE_MAXIMUM_JFFS2_MOUNTS
#else
- #define CONFIGURE_SEMAPHORES_FOR_JFFS2 0
+ #define _CONFIGURE_SEMAPHORES_FOR_JFFS2 0
#endif
* This computes the number of semaphores required for the various
* file systems including the FIFO plugin to the IMFS.
-#define CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS \
- (CONFIGURE_SEMAPHORES_FOR_FIFOS + \
- CONFIGURE_SEMAPHORES_FOR_NFS + \
- CONFIGURE_SEMAPHORES_FOR_DOSFS + \
- CONFIGURE_SEMAPHORES_FOR_RFS + \
- CONFIGURE_SEMAPHORES_FOR_JFFS2)
+#define _CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS \
+ (_CONFIGURE_SEMAPHORES_FOR_FIFOS + \
+ _CONFIGURE_SEMAPHORES_FOR_NFS + \
+ _CONFIGURE_SEMAPHORES_FOR_DOSFS + \
+ _CONFIGURE_SEMAPHORES_FOR_RFS + \
+ _CONFIGURE_SEMAPHORES_FOR_JFFS2)
@@ -722,9 +721,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This configures the stack checker user extension.
#ifdef CONFIGURE_STACK_CHECKER_ENABLED
- #define CONFIGURE_STACK_CHECKER_EXTENSION 1
+ #define _CONFIGURE_STACK_CHECKER_EXTENSION 1
#else
- #define CONFIGURE_STACK_CHECKER_EXTENSION 0
+ #define _CONFIGURE_STACK_CHECKER_EXTENSION 0
#endif
@@ -1029,106 +1028,106 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#if defined(CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS)
#else
- #define CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT \
+ #define _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT \
RTEMS_SCHEDULER_ASSIGN( \
0, \
RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
- CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+ _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
#if CONFIGURE_MAXIMUM_PROCESSORS >= 2
- , CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+ , _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 3
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 4
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 5
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 6
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 7
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 8
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 9
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 10
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 11
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 12
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 13
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 14
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 15
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 16
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 17
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 18
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 19
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 20
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 21
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 22
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 23
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 24
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 25
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 26
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 27
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 28
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 29
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 30
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 31
#endif
#if CONFIGURE_MAXIMUM_PROCESSORS >= 32
#endif
- #undef CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
+ #undef _CONFIGURE_SMP_SCHEDULER_ASSIGN_OPT
#endif
@@ -1248,9 +1247,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* memory from the Workspace.
#if (CPU_ALLOCATE_INTERRUPT_STACK == 0)
- #define CONFIGURE_INTERRUPT_STACK_MEMORY 0
+ #define _CONFIGURE_INTERRUPT_STACK_MEMORY 0
#else
- #define CONFIGURE_INTERRUPT_STACK_MEMORY \
+ #define _CONFIGURE_INTERRUPT_STACK_MEMORY \
_Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE )
#endif
@@ -1376,7 +1375,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define _Configure_Align_up(_val, _align) \
(((_val) + (_align) - 1) - ((_val) + (_align) - 1) % (_align))
-#define CONFIGURE_HEAP_MIN_BLOCK_SIZE \
+#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
_Configure_Align_up(sizeof(Heap_Block), CPU_HEAP_ALIGNMENT)
@@ -1388,7 +1387,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define _Configure_From_workspace(_size) \
(ssize_t) (_Configure_Zero_or_One(_size) * \
_Configure_Align_up(_size + HEAP_BLOCK_HEADER_SIZE, \
- CONFIGURE_HEAP_MIN_BLOCK_SIZE))
+ _CONFIGURE_HEAP_MIN_BLOCK_SIZE))
* This is a helper macro used in stack space calculations in this file. It
@@ -1535,41 +1534,31 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This is the name of the Initialization Tasks Table generated.
-#define CONFIGURE_INIT_TASK_TABLE Initialization_tasks
+#define _CONFIGURE_INIT_TASK_TABLE Initialization_tasks
* This is the size of the Initialization Tasks Table generated.
-#define CONFIGURE_INIT_TASK_TABLE_SIZE \
- RTEMS_ARRAY_SIZE(CONFIGURE_INIT_TASK_TABLE)
+#define _CONFIGURE_INIT_TASK_TABLE_SIZE \
+ RTEMS_ARRAY_SIZE(_CONFIGURE_INIT_TASK_TABLE)
#endif /* CONFIGURE_HAS_OWN_INIT_TASK_TABLE */
#else /* CONFIGURE_RTEMS_INIT_TASKS_TABLE */
* This is the name of the Initialization Task when none is configured.
-#define CONFIGURE_INIT_TASK_TABLE NULL
+#define _CONFIGURE_INIT_TASK_TABLE NULL
* This is the size of the Initialization Task when none is configured.
-#define CONFIGURE_INIT_TASK_TABLE_SIZE 0
+#define _CONFIGURE_INIT_TASK_TABLE_SIZE 0
* This is the stack size of the Initialization Task when none is configured.
#define CONFIGURE_INIT_TASK_STACK_SIZE 0
@@ -1804,12 +1793,12 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
- #define CONFIGURE_LIBBLOCK_TASKS \
+ #define _CONFIGURE_LIBBLOCK_TASKS \
(1 + CONFIGURE_SWAPOUT_WORKER_TASKS + \
(CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS != 0))
- #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS \
- (CONFIGURE_LIBBLOCK_TASKS * \
+ #define _CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS \
+ (_CONFIGURE_LIBBLOCK_TASKS * \
(CONFIGURE_BDBUF_TASK_STACK_SIZE <= CONFIGURE_MINIMUM_TASK_STACK_SIZE ? \
0 : CONFIGURE_BDBUF_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE))
@@ -1817,7 +1806,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Semaphores:
* o disk lock
- #define CONFIGURE_LIBBLOCK_SEMAPHORES 1
+ #define _CONFIGURE_LIBBLOCK_SEMAPHORES 1
#if defined(CONFIGURE_HAS_OWN_BDBUF_TABLE) || \
defined(CONFIGURE_BDBUF_BUFFER_SIZE) || \
@@ -1826,11 +1815,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#else
/** This specifies the number of libblock tasks. */
- #define CONFIGURE_LIBBLOCK_TASKS 0
+ #define _CONFIGURE_LIBBLOCK_TASKS 0
/** This specifies the extra stack space configured for libblock tasks. */
- #define CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS 0
+ #define _CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS 0
/** This specifies the number of Classic API semaphores needed by libblock. */
- #define CONFIGURE_LIBBLOCK_SEMAPHORES 0
+ #define _CONFIGURE_LIBBLOCK_SEMAPHORES 0
#endif /* CONFIGURE_APPLICATION_NEEDS_LIBBLOCK */
@@ -1859,8 +1848,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This defines the timers required for the shared memory driver in
* a multiprocessing configuration.
-#ifndef CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER
- #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 0
+#ifndef _CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER
+ #define _CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 0
#endif
@@ -1872,7 +1861,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifdef CONFIGURE_MP_APPLICATION
- #define CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 1
+ #define _CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER 1
#ifndef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
@@ -1887,7 +1876,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS 32
#endif
- #define CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
+ #define _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
_Configure_From_workspace( \
(_global_objects) * sizeof(Objects_MP_Control) \
@@ -1895,7 +1884,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifndef CONFIGURE_MP_MAXIMUM_PROXIES
#define CONFIGURE_MP_MAXIMUM_PROXIES 32
#endif
- #define CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \
+ #define _CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \
_Configure_From_workspace((_proxies) \
* (sizeof(Thread_Proxy_control) \
+ THREAD_QUEUE_HEADS_SIZE(CONFIGURE_SCHEDULER_COUNT)))
@@ -1918,7 +1907,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MULTIPROCESSING_TABLE &Multiprocessing_configuration
- #define CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
+ #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
#endif /* CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE */
@@ -1926,11 +1915,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MULTIPROCESSING_TABLE NULL
- #define CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
+ #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
#endif /* CONFIGURE_MP_APPLICATION */
#else
#endif /* RTEMS_MULTIPROCESSING */
/**@}*/ /* end of Multiprocessing Configuration */
@@ -2060,27 +2049,23 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_TASKS 0
#endif
* This is calculated to account for the maximum number of Classic API
* tasks used by the application and configured RTEMS capabilities.
- #define CONFIGURE_TASKS \
- (CONFIGURE_MAXIMUM_TASKS + CONFIGURE_LIBBLOCK_TASKS)
+ #define _CONFIGURE_TASKS \
+ (CONFIGURE_MAXIMUM_TASKS + _CONFIGURE_LIBBLOCK_TASKS)
#ifndef CONFIGURE_MAXIMUM_TIMERS
/** This specifies the maximum number of Classic API timers. */
#define CONFIGURE_MAXIMUM_TIMERS 0
* This macro is calculated to specify the memory required for
* Classic API timers.
- #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) 0
+ #define _CONFIGURE_MEMORY_FOR_TIMERS(_timers) 0
#else
- #define CONFIGURE_MEMORY_FOR_TIMERS(_timers) \
+ #define _CONFIGURE_MEMORY_FOR_TIMERS(_timers) \
_Configure_Object_RAM(_timers, sizeof(Timer_Control) )
#endif
@@ -2089,63 +2074,55 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_SEMAPHORES 0
#endif
* This specifies the number of Classic API semaphores required
#ifdef RTEMS_NETWORKING
- #define CONFIGURE_NETWORKING_SEMAPHORES 1
+ #define _CONFIGURE_NETWORKING_SEMAPHORES 1
#else
- #define CONFIGURE_NETWORKING_SEMAPHORES 0
+ #define _CONFIGURE_NETWORKING_SEMAPHORES 0
#endif
* This macro is calculated to specify the number of Classic API
* semaphores required by the application and configured RTEMS
* capabilities.
- #define CONFIGURE_SEMAPHORES \
- (CONFIGURE_MAXIMUM_SEMAPHORES + CONFIGURE_LIBIO_SEMAPHORES + \
- CONFIGURE_TERMIOS_SEMAPHORES + CONFIGURE_LIBBLOCK_SEMAPHORES + \
- CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
- CONFIGURE_NETWORKING_SEMAPHORES + CONFIGURE_DRVMGR_SEMAPHORES)
+ #define _CONFIGURE_SEMAPHORES \
+ (CONFIGURE_MAXIMUM_SEMAPHORES + _CONFIGURE_LIBIO_SEMAPHORES + \
+ _CONFIGURE_TERMIOS_SEMAPHORES + _CONFIGURE_LIBBLOCK_SEMAPHORES + \
+ _CONFIGURE_SEMAPHORES_FOR_FILE_SYSTEMS + \
+ _CONFIGURE_NETWORKING_SEMAPHORES + _CONFIGURE_DRVMGR_SEMAPHORES)
* Classic API Semaphores using MRSP. This is only available in
* SMP configurations.
#if !defined(RTEMS_SMP) || \
!defined(CONFIGURE_MAXIMUM_MRSP_SEMAPHORES)
- #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0
+ #define _CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES 0
#else
- #define CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES \
+ #define _CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES \
CONFIGURE_MAXIMUM_MRSP_SEMAPHORES * \
RTEMS_ARRAY_SIZE(_Scheduler_Table) * sizeof(Priority_Control) \
#endif
* Classic API Semaphores.
* If there are no user or support semaphores defined, then we can assume
* that no memory need be allocated at all for semaphores.
- #if CONFIGURE_SEMAPHORES == 0
- #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) 0
+ #if _CONFIGURE_SEMAPHORES == 0
+ #define _CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) 0
#else
- #define CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) \
+ #define _CONFIGURE_MEMORY_FOR_SEMAPHORES(_semaphores) \
_Configure_Object_RAM(_semaphores, sizeof(Semaphore_Control) ) + \
- CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES
+ _CONFIGURE_MEMORY_FOR_MRSP_SEMAPHORES
#endif
#ifndef CONFIGURE_MAXIMUM_MESSAGE_QUEUES
@@ -2154,15 +2131,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API Message Queues.
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 0
* This macro is calculated to specify the RTEMS Workspace required for
* the Classic API Message Queues.
- #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) 0
+ #define _CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) 0
#else
- #define CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) \
+ #define _CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(_queues) \
_Configure_Object_RAM(_queues, sizeof(Message_queue_Control) )
#endif
@@ -2172,15 +2147,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API Partitions.
#define CONFIGURE_MAXIMUM_PARTITIONS 0
* Classic API
- #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) 0
+ #define _CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) 0
#else
- #define CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) \
+ #define _CONFIGURE_MEMORY_FOR_PARTITIONS(_partitions) \
_Configure_Object_RAM(_partitions, sizeof(Partition_Control) )
#endif
@@ -2190,15 +2163,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API Regions.
#define CONFIGURE_MAXIMUM_REGIONS 0
- #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) 0
+ #define _CONFIGURE_MEMORY_FOR_REGIONS(_regions) 0
#else
- #define CONFIGURE_MEMORY_FOR_REGIONS(_regions) \
+ #define _CONFIGURE_MEMORY_FOR_REGIONS(_regions) \
_Configure_Object_RAM(_regions, sizeof(Region_Control) )
#endif
@@ -2211,12 +2182,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API Dual-Ported Memory Ports.
- #define CONFIGURE_MEMORY_FOR_PORTS(_ports) 0
+ #define _CONFIGURE_MEMORY_FOR_PORTS(_ports) 0
#else
- #define CONFIGURE_MEMORY_FOR_PORTS(_ports) \
+ #define _CONFIGURE_MEMORY_FOR_PORTS(_ports) \
_Configure_Object_RAM(_ports, sizeof(Dual_ported_memory_Control) )
#endif
@@ -2226,15 +2195,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API Rate Monotonic Periods.
#define CONFIGURE_MAXIMUM_PERIODS 0
- #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) 0
+ #define _CONFIGURE_MEMORY_FOR_PERIODS(_periods) 0
#else
- #define CONFIGURE_MEMORY_FOR_PERIODS(_periods) \
+ #define _CONFIGURE_MEMORY_FOR_PERIODS(_periods) \
_Configure_Object_RAM(_periods, sizeof(Rate_monotonic_Control) )
#endif
@@ -2246,25 +2213,21 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_BARRIERS 0
#endif
* Barriers required by the application and configured capabilities.
- #define CONFIGURE_BARRIERS \
- (CONFIGURE_MAXIMUM_BARRIERS + CONFIGURE_BARRIERS_FOR_FIFOS)
+ #define _CONFIGURE_BARRIERS \
+ (CONFIGURE_MAXIMUM_BARRIERS + _CONFIGURE_BARRIERS_FOR_FIFOS)
* Classic API Barriers.
- #if CONFIGURE_BARRIERS == 0
- #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) 0
+ #if _CONFIGURE_BARRIERS == 0
+ #define _CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) 0
#else
- #define CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) \
+ #define _CONFIGURE_MEMORY_FOR_BARRIERS(_barriers) \
_Configure_Object_RAM(_barriers, sizeof(Barrier_Control) )
#endif
@@ -2274,15 +2237,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* Classic API User Extensions.
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 0
- #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) 0
+ #define _CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) 0
#else
- #define CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) \
+ #define _CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(_extensions) \
_Configure_Object_RAM(_extensions, sizeof(Extension_Control) )
#endif
/**@}*/ /* end of Classic API Configuration */
@@ -2340,7 +2301,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_INITIAL_EXTENSION_TABLE Configuration_Initial_Extensions
- #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
+ #define _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
RTEMS_ARRAY_SIZE(Configuration_Initial_Extensions)
RTEMS_SYSINIT_ITEM(
@@ -2350,7 +2311,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#else
#define CONFIGURE_INITIAL_EXTENSION_TABLE NULL
- #define CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0
+ #define _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0
#endif
#if defined(RTEMS_NEWLIB)
@@ -2386,11 +2347,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_KEYS 0
#endif
* POSIX API key/value pairs.
#ifndef CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
@@ -2398,23 +2357,19 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
(CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_TASKS))
#endif
* This macro is calculated to specify the total number of
* POSIX API keys required by the application and configured
* system capabilities.
-#define CONFIGURE_POSIX_KEYS \
- (CONFIGURE_MAXIMUM_POSIX_KEYS + CONFIGURE_LIBIO_POSIX_KEYS)
+#define _CONFIGURE_POSIX_KEYS \
+ (CONFIGURE_MAXIMUM_POSIX_KEYS + _CONFIGURE_LIBIO_POSIX_KEYS)
* POSIX API keys.
-#define CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \
+#define _CONFIGURE_MEMORY_FOR_POSIX_KEYS(_keys, _key_value_pairs) \
(_Configure_Object_RAM(_keys, sizeof(POSIX_Keys_Control) ) \
+ _Configure_From_workspace( \
_key_value_pairs * sizeof(POSIX_Keys_Key_value_pair)))
@@ -2440,11 +2395,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#include <rtems/posix/threadsup.h>
#include <rtems/posix/timer.h>
* Account for the object control structures plus the name
* of the object to be duplicated.
- * This is an internal macro.
#define _Configure_POSIX_Named_Object_RAM(_number, _size) \
(_Configure_Object_RAM(_number, _size) \
@@ -2467,13 +2420,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 0
#endif
* POSIX API mutexes.
- #define CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_mutexes) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_mutexes) \
_Configure_Object_RAM(_mutexes, sizeof(POSIX_Mutex_Control) )
@@ -2484,13 +2435,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 0
#endif
* POSIX API condition variables.
- #define CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(_condvars) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES(_condvars) \
_Configure_Object_RAM(_condvars, \
sizeof(POSIX_Condition_variables_Control) )
@@ -2502,13 +2451,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_TIMERS 0
#endif
* POSIX API timers.
- #define CONFIGURE_MEMORY_FOR_POSIX_TIMERS(_timers) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_TIMERS(_timers) \
_Configure_Object_RAM(_timers, sizeof(POSIX_Timer_Control) )
@@ -2519,13 +2466,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 0
#endif
* POSIX API queued signals.
- #define CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(_queued_signals) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS(_queued_signals) \
(_queued_signals) * (sizeof(POSIX_signals_Siginfo_node)) )
@@ -2537,13 +2482,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES 0
#endif
* POSIX API message queues.
- #define CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(_message_queues) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES(_message_queues) \
_Configure_POSIX_Named_Object_RAM( \
_message_queues, sizeof(POSIX_Message_queue_Control) )
@@ -2555,13 +2498,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES 0
#endif
* POSIX API semaphores.
- #define CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES(_semaphores) \
_semaphores, sizeof(POSIX_Semaphore_Control) )
@@ -2573,13 +2514,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_BARRIERS 0
#endif
* POSIX API barriers.
- #define CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(_barriers) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(_barriers) \
_Configure_Object_RAM(_barriers, sizeof(POSIX_Barrier_Control) )
@@ -2590,13 +2529,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_POSIX_RWLOCKS 0
#endif
* POSIX API rwlocks.
- #define CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS(_rwlocks) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS(_rwlocks) \
_Configure_Object_RAM(_rwlocks, sizeof(POSIX_RWLock_Control) )
@@ -2617,13 +2554,11 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#endif
* POSIX API shared memory.
- #define CONFIGURE_MEMORY_FOR_POSIX_SHMS(_shms) \
+ #define _CONFIGURE_MEMORY_FOR_POSIX_SHMS(_shms) \
_Configure_POSIX_Named_Object_RAM(_shms, sizeof(POSIX_Shm_Control) )
@@ -2703,7 +2638,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* The GNAT run-time needs something less than (10) POSIX mutexes.
* We may be able to get by with less but why bother.
- #define CONFIGURE_GNAT_MUTEXES 10
+ #define _CONFIGURE_GNAT_MUTEXES 10
* This is the maximum number of Ada tasks which can be concurrently
@@ -2723,7 +2658,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#else
/** This defines he number of POSIX mutexes GNAT needs. */
- #define CONFIGURE_GNAT_MUTEXES 0
+ #define _CONFIGURE_GNAT_MUTEXES 0
/** This defines he number of Ada tasks needed by the application. */
#define CONFIGURE_MAXIMUM_ADA_TASKS 0
@@ -2755,8 +2690,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_MAXIMUM_CONDITION_VARIABLES 1
#endif
- #define CONFIGURE_GO_INIT_MUTEXES 77
- #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 4
+ #define _CONFIGURE_GO_INIT_MUTEXES 77
+ #define _CONFIGURE_GO_INIT_CONDITION_VARIABLES 4
#ifndef CONFIGURE_MAXIMUM_GOROUTINES
#define CONFIGURE_MAXIMUM_GOROUTINES 400
@@ -2767,21 +2702,17 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#else
* This specifies the number of mutexes required by the Go run-time
* for its own use.
- #define CONFIGURE_GO_INIT_MUTEXES 0
+ #define _CONFIGURE_GO_INIT_MUTEXES 0
* This specifies the number of condition variables required by the Go
* run-time for its own use.
- #define CONFIGURE_GO_INIT_CONDITION_VARIABLES 0
+ #define _CONFIGURE_GO_INIT_CONDITION_VARIABLES 0
/** This specifies the maximum number of Go co-routines. */
#define CONFIGURE_MAXIMUM_GOROUTINES 0
@@ -2802,7 +2733,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This macro provides a summation of the various POSIX thread requirements.
-#define CONFIGURE_POSIX_THREADS \
+#define _CONFIGURE_POSIX_THREADS \
(CONFIGURE_MAXIMUM_POSIX_THREADS + \
CONFIGURE_MAXIMUM_ADA_TASKS + \
CONFIGURE_MAXIMUM_GOROUTINES)
@@ -2811,56 +2742,50 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This macro provides summation of the POSIX Mutexes.
- #define CONFIGURE_POSIX_MUTEXES \
+ #define _CONFIGURE_POSIX_MUTEXES \
(CONFIGURE_MAXIMUM_POSIX_MUTEXES + \
- CONFIGURE_GNAT_MUTEXES + \
+ _CONFIGURE_GNAT_MUTEXES + \
CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + \
- CONFIGURE_GO_INIT_MUTEXES + \
+ _CONFIGURE_GO_INIT_MUTEXES + \
CONFIGURE_MAXIMUM_GO_CHANNELS)
* This macro provides summation of the POSIX Condition Variables.
- #define CONFIGURE_POSIX_CONDITION_VARIABLES \
+ #define _CONFIGURE_POSIX_CONDITION_VARIABLES \
(CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \
- CONFIGURE_GO_INIT_CONDITION_VARIABLES + \
+ _CONFIGURE_GO_INIT_CONDITION_VARIABLES + \
* the POSIX API in its entirety.
- #define CONFIGURE_MEMORY_FOR_POSIX \
- (CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(CONFIGURE_POSIX_MUTEXES) + \
- CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
- CONFIGURE_POSIX_CONDITION_VARIABLES) + \
- CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS( \
+ #define _CONFIGURE_MEMORY_FOR_POSIX \
+ (_CONFIGURE_MEMORY_FOR_POSIX_MUTEXES(_CONFIGURE_POSIX_MUTEXES) + \
+ _CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
+ _CONFIGURE_POSIX_CONDITION_VARIABLES) + \
+ _CONFIGURE_MEMORY_FOR_POSIX_QUEUED_SIGNALS( \
CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS) + \
- CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \
+ _CONFIGURE_MEMORY_FOR_POSIX_MESSAGE_QUEUES( \
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES) + \
- CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
+ _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( \
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES) + \
- CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \
- CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
+ _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS(CONFIGURE_MAXIMUM_POSIX_BARRIERS) + \
+ _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( \
CONFIGURE_MAXIMUM_POSIX_RWLOCKS) + \
- CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
+ _CONFIGURE_MEMORY_FOR_POSIX_SHMS( \
CONFIGURE_MAXIMUM_POSIX_SHMS) + \
- CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
+ _CONFIGURE_MEMORY_FOR_POSIX_TIMERS(CONFIGURE_MAXIMUM_POSIX_TIMERS))
#else
- #define CONFIGURE_MEMORY_FOR_POSIX 0
+ #define _CONFIGURE_MEMORY_FOR_POSIX 0
#endif
@@ -2868,7 +2793,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* into two parts so that we have a free block for the last allocation. See
* _Heap_Block_split().
-#define CONFIGURE_HEAP_HANDLER_OVERHEAD \
+#define _CONFIGURE_HEAP_HANDLER_OVERHEAD \
_Configure_Align_up( HEAP_BLOCK_HEADER_SIZE, CPU_HEAP_ALIGNMENT )
@@ -2876,15 +2801,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#ifndef CONFIGURE_EXECUTIVE_RAM_SIZE
* Account for allocating the following per object
* + array of object control structures
* + local pointer table -- pointer per object plus a zero'th
* entry in the local pointer table.
-#define CONFIGURE_MEMORY_FOR_TASKS(_tasks, _number_FP_tasks) \
+#define _CONFIGURE_MEMORY_FOR_TASKS(_tasks, _number_FP_tasks) \
_Configure_Object_RAM(_tasks, sizeof(Configuration_Thread_control)) \
+ _Configure_From_workspace(_Configure_Max_Objects(_tasks) \
@@ -2893,18 +2816,16 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* _Configure_From_workspace(CONTEXT_FP_SIZE) \
* This defines the amount of memory configured for the multiprocessing
* support required by this application.
- #define CONFIGURE_MEMORY_FOR_MP \
- (CONFIGURE_MEMORY_FOR_PROXIES(CONFIGURE_MP_MAXIMUM_PROXIES) + \
- CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS))
+ #define _CONFIGURE_MEMORY_FOR_MP \
+ (_CONFIGURE_MEMORY_FOR_PROXIES(CONFIGURE_MP_MAXIMUM_PROXIES) + \
+ _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS))
#else
- #define CONFIGURE_MEMORY_FOR_MP 0
+ #define _CONFIGURE_MEMORY_FOR_MP 0
#endif
@@ -2917,12 +2838,10 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
(_messages) * (_Configure_Align_up(_size, sizeof(uintptr_t)) \
+ sizeof(CORE_message_queue_Buffer_control)))
* This macro is set to the amount of memory required for pending message
* buffers in bytes. It should be constructed by adding together a
* set of values determined by CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE.
#ifndef CONFIGURE_MESSAGE_BUFFER_MEMORY
#define CONFIGURE_MESSAGE_BUFFER_MEMORY 0
@@ -2948,7 +2867,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* RTEMS uses two instance of an internal mutex class. This accounts
* for these mutexes.
-#define CONFIGURE_API_MUTEX_MEMORY \
+#define _CONFIGURE_API_MUTEX_MEMORY \
_Configure_Object_RAM(2, sizeof(API_Mutex_Control))
@@ -2956,9 +2875,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* In an SMP system, each CPU core has its own idle task.
#if defined(RTEMS_SMP)
- #define CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_MAXIMUM_PROCESSORS
+ #define _CONFIGURE_IDLE_TASKS_COUNT CONFIGURE_MAXIMUM_PROCESSORS
#else
- #define CONFIGURE_IDLE_TASKS_COUNT 1
+ #define _CONFIGURE_IDLE_TASKS_COUNT 1
#endif
@@ -2966,36 +2885,36 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* reserved for internal task control structures.
#if CPU_IDLE_TASK_IS_FP == TRUE
- #define CONFIGURE_MEMORY_FOR_INTERNAL_TASKS \
- CONFIGURE_MEMORY_FOR_TASKS( \
- CONFIGURE_IDLE_TASKS_COUNT + CONFIGURE_MPCI_RECEIVE_SERVER_COUNT, \
- CONFIGURE_IDLE_TASKS_COUNT + CONFIGURE_MPCI_RECEIVE_SERVER_COUNT \
+ #define _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS \
+ _CONFIGURE_MEMORY_FOR_TASKS( \
+ _CONFIGURE_IDLE_TASKS_COUNT + _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT, \
+ _CONFIGURE_IDLE_TASKS_COUNT + _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT \
#else
- CONFIGURE_MPCI_RECEIVE_SERVER_COUNT \
#endif
* This macro accounts for general RTEMS system overhead.
-#define CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \
- ( CONFIGURE_MEMORY_FOR_INTERNAL_TASKS + \
- CONFIGURE_INTERRUPT_STACK_MEMORY + \
- CONFIGURE_API_MUTEX_MEMORY \
+#define _CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \
+ ( _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS + \
+ _CONFIGURE_INTERRUPT_STACK_MEMORY + \
+ _CONFIGURE_API_MUTEX_MEMORY \
* This macro reserves the memory required by the statically configured
* user extensions.
-#define CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS \
- (CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS == 0 ? 0 : \
+#define _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS \
+ (_CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS == 0 ? 0 : \
- CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
+ _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
* sizeof(User_extensions_Switch_control) \
@@ -3003,31 +2922,29 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This macro provides a summation of the memory required by the
* Classic API as configured.
-#define CONFIGURE_MEMORY_FOR_CLASSIC \
- (CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
- CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \
- CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES) + \
- CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
- CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS) + \
- CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ) + \
- CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS) + \
- CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS) + \
- CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS) + \
- CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS) \
+#define _CONFIGURE_MEMORY_FOR_CLASSIC \
+ (_CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS + \
+ _CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER ) + \
+ _CONFIGURE_MEMORY_FOR_SEMAPHORES(_CONFIGURE_SEMAPHORES) + \
+ _CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES) + \
+ _CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS) + \
+ _CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ) + \
+ _CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS) + \
+ _CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS) + \
+ _CONFIGURE_MEMORY_FOR_BARRIERS(_CONFIGURE_BARRIERS) + \
+ _CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS) \
* This macro provides a summation of the memory required by SMP as configured.
- #define CONFIGURE_MEMORY_FOR_SMP \
+ #define _CONFIGURE_MEMORY_FOR_SMP \
(CONFIGURE_MAXIMUM_PROCESSORS * \
_Configure_From_workspace( CONFIGURE_INTERRUPT_STACK_SIZE ) \
#else
- #define CONFIGURE_MEMORY_FOR_SMP 0
+ #define _CONFIGURE_MEMORY_FOR_SMP 0
#endif
@@ -3037,22 +2954,22 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#define CONFIGURE_EXECUTIVE_RAM_SIZE \
- CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD + \
- CONFIGURE_TASKS, CONFIGURE_TASKS) + \
- CONFIGURE_POSIX_THREADS, CONFIGURE_POSIX_THREADS) + \
- CONFIGURE_MEMORY_FOR_CLASSIC + \
- CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
- CONFIGURE_POSIX_KEYS, \
+ _CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD + \
+ _CONFIGURE_TASKS, _CONFIGURE_TASKS) + \
+ _CONFIGURE_POSIX_THREADS, _CONFIGURE_POSIX_THREADS) + \
+ _CONFIGURE_MEMORY_FOR_CLASSIC + \
+ _CONFIGURE_MEMORY_FOR_POSIX_KEYS( \
+ _CONFIGURE_POSIX_KEYS, \
CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ) + \
- CONFIGURE_MEMORY_FOR_POSIX + \
- CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
- CONFIGURE_MEMORY_FOR_MP + \
- CONFIGURE_MEMORY_FOR_SMP + \
+ _CONFIGURE_MEMORY_FOR_POSIX + \
+ _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS + \
+ _CONFIGURE_MEMORY_FOR_MP + \
+ _CONFIGURE_MEMORY_FOR_SMP + \
CONFIGURE_MESSAGE_BUFFER_MEMORY + \
(CONFIGURE_MEMORY_OVERHEAD * 1024) + \
- CONFIGURE_HEAP_HANDLER_OVERHEAD \
+ _CONFIGURE_HEAP_HANDLER_OVERHEAD \
@@ -3060,114 +2977,96 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* may have requested.
* This accounts for any extra memory required by the Classic API
* Initialization Task.
#if (CONFIGURE_INIT_TASK_STACK_SIZE > CONFIGURE_MINIMUM_TASK_STACK_SIZE)
- #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART \
+ #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART \
(CONFIGURE_INIT_TASK_STACK_SIZE - CONFIGURE_MINIMUM_TASK_STACK_SIZE)
#else
- #define CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART 0
+ #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART 0
#endif
* This accounts for any extra memory required by the POSIX API
* Initialization Thread.
#if defined(RTEMS_POSIX_API) && \
(CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE > \
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE)
- #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \
+ #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART \
(CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE - \
#else
- #define CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART 0
+ #define _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART 0
#endif
* This macro provides a summation of the various initialization task
* and thread stack requirements.
-#define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \
- (CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \
- CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
+#define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS \
+ (_CONFIGURE_INITIALIZATION_THREADS_STACKS_CLASSIC_PART + \
+ _CONFIGURE_INITIALIZATION_THREADS_STACKS_POSIX_PART)
* the Idle tasks(s) stack.
-#define CONFIGURE_IDLE_TASKS_STACK \
- (CONFIGURE_IDLE_TASKS_COUNT * \
+#define _CONFIGURE_IDLE_TASKS_STACK \
+ (_CONFIGURE_IDLE_TASKS_COUNT * \
_Configure_From_stackspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) )
* This macro is calculated to specify the stack memory required for the MPCI
* task.
-#define CONFIGURE_MPCI_RECEIVE_SERVER_STACK \
- (CONFIGURE_MPCI_RECEIVE_SERVER_COUNT * \
+#define _CONFIGURE_MPCI_RECEIVE_SERVER_STACK \
+ (_CONFIGURE_MPCI_RECEIVE_SERVER_COUNT * \
_Configure_From_stackspace(CONFIGURE_MINIMUM_TASK_STACK_SIZE))
* the stacks of all tasks.
-#define CONFIGURE_TASKS_STACK \
- (_Configure_Max_Objects( CONFIGURE_TASKS ) * \
+#define _CONFIGURE_TASKS_STACK \
+ (_Configure_Max_Objects( _CONFIGURE_TASKS ) * \
_Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) )
* the stacks of all POSIX threads.
-#define CONFIGURE_POSIX_THREADS_STACK \
+#define _CONFIGURE_POSIX_THREADS_STACK \
(_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
_Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
* the stacks of all Ada tasks.
-#define CONFIGURE_ADA_TASKS_STACK \
+#define _CONFIGURE_ADA_TASKS_STACK \
(_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \
* the stacks of all Go routines.
-#define CONFIGURE_GOROUTINES_STACK \
+#define _CONFIGURE_GOROUTINES_STACK \
(_Configure_Max_Objects( CONFIGURE_MAXIMUM_GOROUTINES ) * \
#else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
-#define CONFIGURE_IDLE_TASKS_STACK 0
-#define CONFIGURE_MPCI_RECEIVE_SERVER_STACK 0
-#define CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
-#define CONFIGURE_TASKS_STACK 0
-#define CONFIGURE_POSIX_THREADS_STACK 0
-#define CONFIGURE_GOROUTINES_STACK 0
-#define CONFIGURE_ADA_TASKS_STACK 0
+#define _CONFIGURE_IDLE_TASKS_STACK 0
+#define _CONFIGURE_MPCI_RECEIVE_SERVER_STACK 0
+#define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
+#define _CONFIGURE_TASKS_STACK 0
+#define _CONFIGURE_POSIX_THREADS_STACK 0
+#define _CONFIGURE_GOROUTINES_STACK 0
+#define _CONFIGURE_ADA_TASKS_STACK 0
#if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0
#error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK"
@@ -3179,25 +3078,23 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif /* CONFIGURE_EXECUTIVE_RAM_SIZE */
* all tasks and threads of all varieties.
-#define CONFIGURE_STACK_SPACE_SIZE \
+#define _CONFIGURE_STACK_SPACE_SIZE \
- CONFIGURE_IDLE_TASKS_STACK + \
- CONFIGURE_MPCI_RECEIVE_SERVER_STACK + \
- CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
- CONFIGURE_TASKS_STACK + \
- CONFIGURE_POSIX_THREADS_STACK + \
- CONFIGURE_GOROUTINES_STACK + \
- CONFIGURE_ADA_TASKS_STACK + \
+ _CONFIGURE_IDLE_TASKS_STACK + \
+ _CONFIGURE_MPCI_RECEIVE_SERVER_STACK + \
+ _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
+ _CONFIGURE_TASKS_STACK + \
+ _CONFIGURE_POSIX_THREADS_STACK + \
+ _CONFIGURE_GOROUTINES_STACK + \
+ _CONFIGURE_ADA_TASKS_STACK + \
CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK + \
- CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
+ _CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
CONFIGURE_EXTRA_TASK_STACKS + \
#ifndef CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
@@ -3307,17 +3204,17 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This is the Classic API Configuration Table.
rtems_api_configuration_table Configuration_RTEMS_API = {
- CONFIGURE_TASKS,
- CONFIGURE_MAXIMUM_TIMERS + CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER,
- CONFIGURE_SEMAPHORES,
+ _CONFIGURE_TASKS,
+ CONFIGURE_MAXIMUM_TIMERS + _CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER,
+ _CONFIGURE_SEMAPHORES,
CONFIGURE_MAXIMUM_MESSAGE_QUEUES,
CONFIGURE_MAXIMUM_PARTITIONS,
CONFIGURE_MAXIMUM_REGIONS,
CONFIGURE_MAXIMUM_PORTS,
CONFIGURE_MAXIMUM_PERIODS,
- CONFIGURE_BARRIERS,
- CONFIGURE_INIT_TASK_TABLE_SIZE,
+ _CONFIGURE_BARRIERS,
+ _CONFIGURE_INIT_TASK_TABLE_SIZE,
#ifdef RTEMS_POSIX_API
@@ -3325,9 +3222,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
* This is the POSIX API Configuration Table.
posix_api_configuration_table Configuration_POSIX_API = {
- CONFIGURE_POSIX_MUTEXES,
- CONFIGURE_POSIX_CONDITION_VARIABLES,
+ _CONFIGURE_POSIX_MUTEXES,
+ _CONFIGURE_POSIX_CONDITION_VARIABLES,
CONFIGURE_MAXIMUM_POSIX_TIMERS,
CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS,
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES,
@@ -3356,9 +3253,9 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
const rtems_configuration_table Configuration = {
CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
- CONFIGURE_STACK_SPACE_SIZE, /* required stack space */
+ _CONFIGURE_STACK_SPACE_SIZE, /* required stack space */
CONFIGURE_MAXIMUM_USER_EXTENSIONS, /* maximum dynamic extensions */
- CONFIGURE_POSIX_KEYS, /* POSIX keys are always */
+ _CONFIGURE_POSIX_KEYS, /* POSIX keys are always */
CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS, /* enabled */
CONFIGURE_MICROSECONDS_PER_TICK, /* microseconds per clock tick */
1000 * CONFIGURE_MICROSECONDS_PER_TICK, /* nanoseconds per clock tick */
@@ -3382,7 +3279,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#else
false,
#endif
- CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS, /* number of static extensions */
+ _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS, /* number of static extensions */
CONFIGURE_INITIAL_EXTENSION_TABLE, /* pointer to static extensions */
#if defined(RTEMS_MULTIPROCESSING)
CONFIGURE_MULTIPROCESSING_TABLE, /* pointer to MP config table */
@@ -3559,55 +3456,55 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
Configuration_Debug_t Configuration_Memory_Debug = {
/* General Information */
- CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD,
- CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS,
- CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS,
- CONFIGURE_MEMORY_FOR_TASKS(1, 0),
- CONFIGURE_MEMORY_FOR_TASKS(0, 1),
- CONFIGURE_MEMORY_FOR_CLASSIC,
- CONFIGURE_MEMORY_FOR_POSIX,
+ _CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD,
+ _CONFIGURE_MEMORY_FOR_STATIC_EXTENSIONS,
+ _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS,
+ _CONFIGURE_MEMORY_FOR_TASKS(1, 0),
+ _CONFIGURE_MEMORY_FOR_TASKS(0, 1),
+ _CONFIGURE_MEMORY_FOR_CLASSIC,
+ _CONFIGURE_MEMORY_FOR_POSIX,
/* System overhead pieces */
- CONFIGURE_INTERRUPT_STACK_MEMORY,
- CONFIGURE_MEMORY_FOR_INTERNAL_TASKS,
+ _CONFIGURE_INTERRUPT_STACK_MEMORY,
+ _CONFIGURE_MEMORY_FOR_INTERNAL_TASKS,
/* Classic API Pieces */
- CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_MAXIMUM_TASKS, 0),
- CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS),
- CONFIGURE_MEMORY_FOR_SEMAPHORES(CONFIGURE_SEMAPHORES),
- CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES),
- CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS),
- CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ),
- CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS),
- CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS),
- CONFIGURE_MEMORY_FOR_BARRIERS(CONFIGURE_BARRIERS),
- CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS),
- CONFIGURE_MEMORY_FOR_POSIX_KEYS( CONFIGURE_POSIX_KEYS, \
+ _CONFIGURE_MEMORY_FOR_TASKS(CONFIGURE_MAXIMUM_TASKS, 0),
+ _CONFIGURE_MEMORY_FOR_TIMERS(CONFIGURE_MAXIMUM_TIMERS),
+ _CONFIGURE_MEMORY_FOR_SEMAPHORES(_CONFIGURE_SEMAPHORES),
+ _CONFIGURE_MEMORY_FOR_MESSAGE_QUEUES(CONFIGURE_MAXIMUM_MESSAGE_QUEUES),
+ _CONFIGURE_MEMORY_FOR_PARTITIONS(CONFIGURE_MAXIMUM_PARTITIONS),
+ _CONFIGURE_MEMORY_FOR_REGIONS( CONFIGURE_MAXIMUM_REGIONS ),
+ _CONFIGURE_MEMORY_FOR_PORTS(CONFIGURE_MAXIMUM_PORTS),
+ _CONFIGURE_MEMORY_FOR_PERIODS(CONFIGURE_MAXIMUM_PERIODS),
+ _CONFIGURE_MEMORY_FOR_BARRIERS(_CONFIGURE_BARRIERS),
+ _CONFIGURE_MEMORY_FOR_USER_EXTENSIONS(CONFIGURE_MAXIMUM_USER_EXTENSIONS),
+ _CONFIGURE_MEMORY_FOR_POSIX_KEYS( _CONFIGURE_POSIX_KEYS, \
CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS ),
/* POSIX API Pieces */
- CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( CONFIGURE_POSIX_MUTEXES ),
- CONFIGURE_POSIX_CONDITION_VARIABLES ),
+ _CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( _CONFIGURE_POSIX_MUTEXES ),
+ _CONFIGURE_POSIX_CONDITION_VARIABLES ),
CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS ),
CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES ),
- CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
- CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
- CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
- CONFIGURE_MEMORY_FOR_POSIX_SHMS( CONFIGURE_MAXIMUM_POSIX_SHMS ),
- CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
+ _CONFIGURE_MEMORY_FOR_POSIX_SEMAPHORES( CONFIGURE_MAXIMUM_POSIX_SEMAPHORES ),
+ _CONFIGURE_MEMORY_FOR_POSIX_BARRIERS( CONFIGURE_MAXIMUM_POSIX_BARRIERS ),
+ _CONFIGURE_MEMORY_FOR_POSIX_RWLOCKS( CONFIGURE_MAXIMUM_POSIX_RWLOCKS ),
+ _CONFIGURE_MEMORY_FOR_POSIX_SHMS( CONFIGURE_MAXIMUM_POSIX_SHMS ),
+ _CONFIGURE_MEMORY_FOR_POSIX_TIMERS( CONFIGURE_MAXIMUM_POSIX_TIMERS ),
#endif
/* Stack space sizes */
- CONFIGURE_IDLE_TASKS_STACK,
- CONFIGURE_TASKS_STACK,
- CONFIGURE_POSIX_THREADS_STACK,
- CONFIGURE_GOROUTINES_STACK,
- CONFIGURE_ADA_TASKS_STACK,
+ _CONFIGURE_IDLE_TASKS_STACK,
+ _CONFIGURE_TASKS_STACK,
+ _CONFIGURE_POSIX_THREADS_STACK,
+ _CONFIGURE_GOROUTINES_STACK,
+ _CONFIGURE_ADA_TASKS_STACK,
CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK,
1.8.4.5
