[PATCH] Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Wed Feb 1 14:30:00 UTC 2017
On 01/02/17 15:22, Joel Sherrill wrote:
> On Feb 1, 2017 8:02 AM, "Sebastian Huber"
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 01/02/17 14:53, Joel Sherrill wrote:
>         The inclusion of SMP categorizes the option. Many, if not
>         most, configure options have a second word which is the
>         category. All the POSIX options include POSIX in the name,
>         gnat, Go, etc.
>     This is the only CONFIGURE_SMP_* option left, a category should
>     consist of more than one member. The current pattern for the
>     maximum defines is CONFIGURE_MAXIMUM[_CATEGORY]_*. A
>     CONFIGURE_MAXIMUM_SMP_PROCESSORS is not really that great.
>         All of our services are rtems_CATEGORY.
>         It isn't about the shortest name with RTEMS. It is about the
>         clearest name with grouping.
>         I don't want to see this pattern violated and am opposed to
>         this change.
>         Otherwise, this would be CONF_MAX_CPUS or similar and we don't
>         want that.
>     In general I agree, however, SMP or non-SMP shouldn't be a
>     category for the configuration. I think its like
>     CONFIGURE_TICKS_PER_TIMESLICE or CONFIGURE_MICROSECONDS_PER_TICK a
>     configuration option that sets up your application environment.
> Are there any options without SMP which should have them?
> If not, I agree.
I update currently the SMP chapter in the user manual. I thought that
this would simplify the things a bit.
The clustered scheduler configuration uses the SCHEDULER category. I
don't think we added anything SMP-specific except
CONFIGURE_SMP_MAXIMUM_PROCESSORS (to be renamed) and
CONFIGURE_SMP_APPLICATION (to be removed).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
