Build error on rtems master
Thu Feb 2 19:52:53 UTC 2017
Maybe the default-configuration.c should set max processors to 1?
On Thu, Feb 2, 2017 at 2:51 PM, Joel Sherrill <joel at rtems.org> wrote:
> That sounds like a reasonable error and fix. Please send a patch
> to the mailing list.
> I assume the build of all BSPs I just started is likely to fail if
> I didn't enable SMP. :)
> --joel
> On Thu, Feb 2, 2017 at 1:07 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> wrote:
>> I’m getting a build error with the latest master due to the changes
>> removing CONFIGURE_SMP_APPLICATION.  The default-configuration.c file sets
>> CONFIGURE_SMP_MAXIMUM_PROCESSORS to 32 thus enabling the internal
>> _CONFIGURE_SMP_APPLICATION define on targets without SMP.  I had to add a
>> #if defined(RTEMS_SMP)
>> guard around
>> #if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
>>   #define _CONFIGURE_SMP_APPLICATION
>> #endif
>> to get it to compile.  I was building for the xilinx_zynq_a9_qemu BSP.
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642
>> Direct: (770)-688-1642
>> Fax: (770)-510-4445
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
