[PATCH] Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS
Fri Feb 3 16:04:07 UTC 2017
On Fri, Feb 3, 2017 at 7:40 AM, Sebastian Huber
> On 01/02/17 14:16, Sebastian Huber wrote:
>> Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
>> since the SMP part is superfluous.
> I still think its worth to rename this configuration option. I would like to
> move it (CONFIGURE_MAXIMUM_PROCESSORS) to
I'm OK with it, since the MP variants are distinct. I do wonder about
the use of MP with SMP (i.e. asymmetric/clustered multiprocessing),
but that is a problem for another year.
In my view, processors == cores, and CPU is only relevant to
uniprocessor systems.
> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#basic-system-information
> and delete
> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#smp-specific-configuration-parameters
> which is then empty.
> devel mailing list
> devel at rtems.org
