Regarding running one test
Tanu Hari Dixit tokencolour at gmail.com
Mon Feb 6 13:38:25 UTC 2017
Hello Gedare, Joel,
I was able to re-build and execute the samples following your advice. Thank you.
Regards,
Tanu Hari Dixit.
On Sun, Feb 5, 2017 at 3:03 AM, Gedare Bloom <gedare at rtems.org> wrote:
> After you do a git-pull you should usually re-run bootstrap, delete
> your build, and re-run configure and make. This is especially true if
> you re-build a toolchain, at least to get started.
> On Sat, Feb 4, 2017 at 10:26 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
>> Hi Kevin, Kuan-Hsun,
>> Thank you for the answer.
>> I have run into a problem before trying the above solutions for myself,
>> while updating my local copy of the rtems repository with upstream with "git
>> pull".
>> After I updated the local copy, I built the sparc toolset with
>> ../source-builder/sb-set-builder --log=l-sparc-test.txt
>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
>> Then I ran  ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
>> bootstrap.
>> Then from  builds/erc32_test(subdirectory) I ran
>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ ../../rtems/configure
>> --target=sparc-rtems4.12 --enable-rtemsbsp=erc32 --enable-tests
>> --prefix=${HOME}/development/rtems/install_path_test
>> And when I ran make, It showed the following error;
>> make[2]: Leaving directory
>> `/home/thd/development/rtems/src/builds/erc32_test/tools/build'
>> make[1]: Leaving directory
>> Making all in tools/cpu
>> make[1]: Entering directory
>> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu'
>> Making all in generic
>> make[2]: Entering directory
>> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu/generic'
>> make[2]: Nothing to be done for `all'.
>> make[2]: Nothing to be done for `all-am'.
>> Making all in testsuites/tools
>> `/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools'
>> `/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools/generic'
>> Making all in sparc-rtems4.12/c
>> `/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c'
>> Making all in .
>> Making all in erc32
>> `/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c/erc32'
>> make[2]: *** No rule to make target `all'.  Stop.
>> make[1]: *** [all-recursive] Error 1
>> make: *** [all-recursive] Error 1
>> I have ran into this problem more than once. When last time this happened, I
>> thought I must have messed up somewhere in the git (or rtems) workflow and
>> hence decided to make a clean clone of the rtems repo and continue with it.
>> I also tried git reset --hard <hash-number> last time and had no luck.
>> Right now, I did not do a hard reset and currently git reflog shows the
>> following output:
>> 239dd35 HEAD@{0}: pull: Fast-forward
>> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
>> git status shows
>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
>> On branch master
>> Your branch is up-to-date with 'origin/master'.
>> Changes not staged for commit:
>>   (use "git add <file>..." to update what will be committed)
>>   (use "git checkout -- <file>..." to discard changes in working directory)
>>     modified:   c/src/lib/libbsp/powerpc/acinclude.m4
>> no changes added to commit (use "git add" and/or "git commit -a")
>> I don't know what I am missing. Do I need to do something before pulling
>> from upstream? How do I rectify this? Please help me with this.
>> Thank you,
>> Tanu Hari Dixit.
>> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen
>> <kuan-hsun.chen at tu-dortmund.de> wrote:
>>> Or alternatively you can prepare simulator like qemu to executed each of
>>> it after compiling the source tree.
>>> Like this in testsuites/hello/:
>>> qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel \
>>> hello.exe -smp 4
>>> Best,
>>> Kuan-Hsun
>>> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
>>>> I use the rtems tester.
>>>> ftp://ftp.rtems.org/pub/rtems/people/chrisj/rtems-tester/rtems-tester.html
>>>> Kevin Kirspel
>>>> Electrical Engineer - Sr. Staff
>>>> Idexx Roswell
>>>> 235 Hembree Park Drive
>>>> Roswell GA 30076
>>>> Tel: (770)-510-4444 ext. 81642
>>>> Direct: (770)-688-1642
>>>> Fax: (770)-510-4445
>>>> -----Original Message-----
>>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit
>>>> Sent: Saturday, February 04, 2017 12:23 AM
>>>> To: rtems-devel at rtems.org <devel at rtems.org>
>>>> Subject: Regarding running one test
>>>> Hello all,
>>>> How do I run a single test from the testsuites? I want to run one test
>>>> from the rtems/testsuites/fstests. How do I go about doing that?
>>>> Regards,
>>>> Tanu Hari Dixit.
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=zH4W9XS8-wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94eNhQoI76FuuhiadOCFEoiJ3HdxyrrQ&e=
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> M.Sc. Kuan-Hsun Chen
>>> TU Dortmund
>>> Department of Computer Science 12
>>> Design Automation of Embedded Systems
>>> Otto-Hahn-Strasse 16, Room 102
>>> 44227 Dortmund
>>> Germany
>>> Phone:  +49 231 755 6124
>>> Mail:   kuan-hsun.chen at tu-dortmund.de
>> devel mailing list
>> devel at rtems.org
