Using helper functions
Tanu Hari Dixit
tokencolour at gmail.com
Mon Feb 6 15:01:55 UTC 2017
Hello Punit, Gedare,
Thanks for the answer.
Which file system API you are talking about ? Can you please send me
> the file location ?
The file system I am talking about is In-Memory FileSystem (imfs). The file
location is:
/home/thd/development/rtems/src/rtems/cpukit/libfs/src/imfs
I cloned the repo you linked to in your previous mail. However, I am unable
to figure out how to run the application. I have kept it outside the rtems
tree. I know how executables for tests are made i.e. by the configure
script at the top. But I don't know how I will be able to run an
application outside of testsuites. For example, my question is
rtems_gsoc16/gpio has no configure.ac file. I don't understand how to
generate make file in this case. Please help me with this.
What example did you take to learn how to make an application (and run it)?
Thank you so much.
Tanu Hari Dixit.
On Thu, Feb 2, 2017 at 11:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> see rtems.git/testsuites/fstests for examples of some filesystem usage.
> On Thu, Feb 2, 2017 at 12:03 PM, punit vara <punitvara at gmail.com> wrote:
> > Hi
> > the file location ?
> > I have used some of GPIO APIs for BBB board. Have a look at this example
> > https://github.com/punitvara/rtems_gsoc16/blob/master/gpio/init.c
> > Similarly you can create application for any APIs.
> > P.S. Always add devel mailing list as CC so that other person also can
> > help you :)
> > Thanks
> > PV
> > On Wed, Feb 1, 2017 at 11:25 PM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> >> Hello Punit,
> >> I have been reading the docs as you suggested. But I want to execute
> >> the various directives and helper functions and test for myself in an
> >> isolated example. For example I want to test the various API functions
> >> available for the filesystem (In memory Filesystem) in RTEMS. How do I
> >> go about doing that?
> >> Thanks,
> >> Tanu Hari Dixit.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170206/8246da87/attachment.html>
