Using helper functions
punit vara punitvara at gmail.com
Mon Feb 6 15:20:30 UTC 2017
On Mon, Feb 6, 2017 at 8:31 PM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hello Punit, Gedare,
> I cloned the repo you linked to in your previous mail. However, I am unable
> to figure out how to run the application. I have kept it outside the rtems
> tree. I know how executables for tests are made i.e. by the configure script
> at the top. But I don't know how I will be able to run an application
> outside of testsuites. For example, my question is rtems_gsoc16/gpio has no
> configure.ac file.
You don't have to create separate configure.ac. In case of
rtems_gsoc16/gpio copy gpio directory under samples. To execute that
testcase you need to add one line
gpio/Makefile
in configure.ac at testsuits/samples/configure.ac
Then do bootstrap
$ ./bootstrap; ./bootstrap -p
I hope you know where to do it.
> What example did you take to learn how to make an application (and run it)?
I wasn't able to find any app at that time so I have figured out own
my own and created this simple app to test GPIO. Carefully follow my
testcase I think you will understand once you compile.
> On Thu, Feb 2, 2017 at 11:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> see rtems.git/testsuites/fstests for examples of some filesystem usage.
>> On Thu, Feb 2, 2017 at 12:03 PM, punit vara <punitvara at gmail.com> wrote:
>> > Hi
>> > Which file system API you are talking about ? Can you please send me
>> > the file location ?
>> > I have used some of GPIO APIs for BBB board. Have a look at this example
>> > https://github.com/punitvara/rtems_gsoc16/blob/master/gpio/init.c
>> > Similarly you can create application for any APIs.
>> > P.S. Always add devel mailing list as CC so that other person also can
>> > help you :)
>> > Thanks
>> > PV
>> > On Wed, Feb 1, 2017 at 11:25 PM, Tanu Hari Dixit <tokencolour at gmail.com>
>> > wrote:
>> >> Hello Punit,
>> >> I have been reading the docs as you suggested. But I want to execute
>> >> the various directives and helper functions and test for myself in an
>> >> isolated example. For example I want to test the various API functions
>> >> available for the filesystem (In memory Filesystem) in RTEMS. How do I
>> >> go about doing that?
>> >> Thanks,
>> >> Tanu Hari Dixit.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
