Using helper functions
Tanu Hari Dixit
tokencolour at gmail.com
Tue Feb 7 15:13:53 UTC 2017
Oh, yes. Thanks for the heads up. I'll rebuild it.
Regards,
Tanu Hari Dixit.
On Tue, Feb 7, 2017 at 8:14 PM, punit vara <punitvara at gmail.com> wrote:
> If you are trying to build my gpio sample then its just for arm
> architecture and specifically for beagle bone black. Sparc is
> completely different architecture so sample won't build in it.
> On Tue, Feb 7, 2017 at 7:12 PM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> > Hello Punit,
> > Thank you for the explanation. I did as you suggested. I copied the gpio
> > folder to testsuites/samples/ and edited configure.ac, ran bootstrap,
> > configure and make for the new build. It ran fine (without errors).
> However,
> > I could see all executables except for one in
> > /home/thd/development/rtems/src/builds/erc32_gpio/sparc-
> rtems4.12/c/erc32/testsuites/samples/gpio
> > for the gpio application. I am unable to figure out what might be the
> fault.
> > The bootstrap and configure are as below. The make output is attached.
> > Something strange that I observed in the make output is, that unlike
> other
> > subdirectories in samples, there never appears a line like:
> > make[6]: Entering directory
> > `/home/thd/development/rtems/src/builds/erc32_gpio/sparc-
> rtems4.12/c/erc32/testsuites/samples/gpio'
> > Also the gpio folder in
> > just has Makefile in it.
> > I (just experimenting) ran the Makefile and I got the following output:
> > thd at thd-Inspiron-5537:~/development/rtems/src/builds/
> erc32_gpio/sparc-rtems4.12/c/erc32/testsuites/samples/gpio$
> > make
> > sparc-rtems4.12-gcc -B../../../../../erc32/lib/ -specs bsp_specs -qrtems
> > -DHAVE_CONFIG_H -I.
> > -I../../../../../../../../rtems/c/src/../../testsuites/samples/gpio -I..
> > -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> > -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> > -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
> > ../../../../../../../../rtems/c/src/../../testsuites/samples/gpio/init.c
> samples/gpio/init.c:6:70:
> > fatal error: bsp/beagleboneblack.h: No such file or directory
> > #include <bsp/beagleboneblack.h> /* Calls the BBB specific library */
> > compilation terminated.
> > make: *** [init.o] Error 1
> > Maybe that is the error I am facing. I don't know how to rectify it. I
> > searched for similar errors but found no luck. Can you please help me
> with
> > this?
> > Also, now I am able to understand more and have a feeling that I'll soon
> > have a working application that is made by me. Thank you.
> > Regards,
> > Tanu Hari Dixit.
> > OUTPUT: ./bootstrap
> > ./cpukit
> > ./c
> > ./c/src/ada-tests
> > ./c/src
> > ./c/src/make
> > ./c/src/lib/libbsp/bfin/bf537Stamp
> > ./c/src/lib/libbsp/bfin/eZKit533
> > acinclude.m4 is unchanged
> > ./c/src/lib/libbsp/bfin/TLL6527M
> > ./c/src/lib/libbsp/mips/malta
> > ./c/src/lib/libbsp/mips/jmr3904
> > ./c/src/lib/libbsp/mips/csb350
> > ./c/src/lib/libbsp/mips/rbtx4925
> > ./c/src/lib/libbsp/mips/rbtx4938
> > ./c/src/lib/libbsp/mips/hurricane
> > ./c/src/lib/libbsp/epiphany
> > ./c/src/lib/libbsp/epiphany/epiphany_sim
> > ./c/src/lib/libbsp/sparc/leon2
> > ./c/src/lib/libbsp/sparc/erc32
> > ./c/src/lib/libbsp/sparc/leon3
> > ./c/src/lib/libbsp/no_cpu
> > ./c/src/lib/libbsp/no_cpu/no_bsp
> > ./c/src/lib/libbsp/sh/shsim
> > ./c/src/lib/libbsp/sh/gensh2
> > ./c/src/lib/libbsp/sh/gensh4
> > ./c/src/lib/libbsp/sh/gensh1
> > ./c/src/lib/libbsp/moxie
> > ./c/src/lib/libbsp/moxie/moxiesim
> > ./c/src/lib/libbsp/m32c/m32cbsp
> > ./c/src/lib/libbsp/nios2
> > ./c/src/lib/libbsp/nios2/nios2_iss
> > ./c/src/lib/libbsp/arm/altera-cyclone-v
> > ./c/src/lib/libbsp/arm/raspberrypi
> > ./c/src/lib/libbsp/arm/beagle
> > ./c/src/lib/libbsp/arm/edb7312
> > ./c/src/lib/libbsp/arm/gumstix
> > ./c/src/lib/libbsp/arm/stm32f4
> > ./c/src/lib/libbsp/arm/csb337
> > ./c/src/lib/libbsp/arm/lpc176x
> > ./c/src/lib/libbsp/arm/tms570
> > ./c/src/lib/libbsp/arm/xilinx-zynq
> > ./c/src/lib/libbsp/arm/csb336
> > ./c/src/lib/libbsp/arm/lm3s69xx
> > ./c/src/lib/libbsp/arm/smdk2410
> > ./c/src/lib/libbsp/arm/gdbarmsim
> > ./c/src/lib/libbsp/arm/lpc32xx
> > ./c/src/lib/libbsp/arm/rtl22xx
> > ./c/src/lib/libbsp/arm/lpc24xx
> > ./c/src/lib/libbsp/arm/realview-pbx-a9
> > ./c/src/lib/libbsp/arm/atsam
> > ./c/src/lib/libbsp/v850
> > ./c/src/lib/libbsp/v850/gdbv850sim
> > ./c/src/lib/libbsp/sparc64
> > ./c/src/lib/libbsp/sparc64/niagara
> > ./c/src/lib/libbsp/sparc64/usiii
> > ./c/src/lib/libbsp/m68k/av5282
> > ./c/src/lib/libbsp/m68k/genmcf548x
> > ./c/src/lib/libbsp/m68k/uC5282
> > ./c/src/lib/libbsp/m68k/mvme147s
> > ./c/src/lib/libbsp/m68k/mcf5329
> > ./c/src/lib/libbsp/m68k/mvme167
> > ./c/src/lib/libbsp/m68k/mcf5225x
> > ./c/src/lib/libbsp/m68k/mvme162
> > ./c/src/lib/libbsp/m68k/mcf5206elite
> > ./c/src/lib/libbsp/m68k/mcf5206elite/tools
> > ./c/src/lib/libbsp/m68k/gen68360
> > ./c/src/lib/libbsp/m68k/mcf52235
> > ./c/src/lib/libbsp/m68k/csb360
> > ./c/src/lib/libbsp/m68k/mrm332
> > ./c/src/lib/libbsp/m68k/mcf5235
> > ./c/src/lib/libbsp/m68k/gen68340
> > ./c/src/lib/libbsp/or1k
> > ./c/src/lib/libbsp/or1k/generic_or1k
> > ./c/src/lib/libbsp/powerpc/mpc55xxevb
> > ./c/src/lib/libbsp/powerpc/virtex4
> > ./c/src/lib/libbsp/powerpc/ss555
> > ./c/src/lib/libbsp/powerpc/mvme3100
> > ./c/src/lib/libbsp/powerpc/gen83xx
> > ./c/src/lib/libbsp/powerpc/mpc8260ads
> > ./c/src/lib/libbsp/powerpc/virtex5
> > ./c/src/lib/libbsp/powerpc/psim
> > ./c/src/lib/libbsp/powerpc/tqm8xx
> > ./c/src/lib/libbsp/powerpc/qemuppc
> > ./c/src/lib/libbsp/powerpc/beatnik
> > ./c/src/lib/libbsp/powerpc/t32mppc
> > ./c/src/lib/libbsp/powerpc/motorola_powerpc
> > ./c/src/lib/libbsp/powerpc/gen5200
> > ./c/src/lib/libbsp/powerpc/mvme5500
> > ./c/src/lib/libbsp/powerpc/qoriq
> > ./c/src/lib/libbsp/powerpc/haleakala
> > ./c/src/lib/libbsp/lm32
> > ./c/src/lib/libbsp/lm32/milkymist
> > ./c/src/lib/libbsp/lm32/lm32_evr
> > ./c/src/lib/libbsp/i386/pc386
> > ./c/src/lib/libbsp/i386/pc386/tools
> > ./c/src/lib/libcpu/bfin
> > ./c/src/lib/libcpu/mips
> > ./c/src/lib/libcpu/sparc
> > ./c/src/lib/libcpu/sh
> > ./c/src/lib/libcpu/nios2
> > ./c/src/lib/libcpu/arm
> > ./c/src/lib/libcpu/sparc64
> > ./c/src/lib/libcpu/m68k
> > ./c/src/lib/libcpu/or1k
> > ./c/src/lib/libcpu/powerpc
> > ./c/src/lib/libcpu/lm32
> > ./c/src/lib/libcpu/i386
> > ./tools/build
> > ./tools/cpu/sh
> > ./tools/cpu
> > ./tools/cpu/nios2
> > ./tools/cpu/generic
> > ./testsuites/psxtests
> > ./testsuites/psxtmtests
> > ./testsuites/mptests
> > ./testsuites/sptests
> > ./testsuites
> > ./testsuites/smptests
> > ./testsuites/tools
> > ./testsuites/tools/generic
> > ./testsuites/libtests
> > ./testsuites/fstests
> > ./testsuites/tmtests
> > ./testsuites/rhealstone
> > OUTPUT : configure
> > thd at thd-Inspiron-5537:~/development/rtems/src/builds/erc32_gpio$
> > ../../rtems/configure --target=sparc-rtems4.12 --enable-tests=samples
> > --enable-rtemsbsp=erc32 --prefix=/home/thd/
> development/rtems/install_path
> > checking for gmake... no
> > checking for make... make
> > checking for RTEMS Version... 4.11.99.0
> > checking build system type... x86_64-pc-linux-gnu
> > checking host system type... x86_64-pc-linux-gnu
> > checking target system type... sparc-unknown-rtems4.12
> > checking for a BSD-compatible install... /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking for a thread-safe mkdir -p... /bin/mkdir -p
> > checking for gawk... gawk
> > checking whether make sets $(MAKE)... yes
> > checking whether to enable maintainer-specific portions of Makefiles...
> no
> > checking that generated files are newer than configure... done
> > configure: creating ./config.status
> > configure: configuring in ./tools/build
> > configure: running /bin/sh '../../../../rtems/tools/build/configure'
> > '--prefix=/home/thd/development/rtems/install_path'
> > '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
> > '--enable-tests=samples' '--enable-rtemsbsp=erc32'
> > '--target=sparc-rtems4.12' '--cache-file=/dev/null'
> > '--srcdir=../../../../rtems/tools/build'
> no
> > checking for x86_64-pc-linux-gnu-gcc... no
> > checking for gcc... gcc
> > checking whether the C compiler works... yes
> > checking for C compiler default output file name... a.out
> > checking for suffix of executables...
> > checking whether we are cross compiling... no
> > checking for suffix of object files... o
> > checking whether we are using the GNU C compiler... yes
> > checking whether gcc accepts -g... yes
> > checking for gcc option to accept ISO C89... none needed
> > checking for style of include used by make... GNU
> > checking dependency style of gcc... gcc3
> > checking how to run the C preprocessor... gcc -E
> > checking for grep that handles long lines and -e... /bin/grep
> > checking for egrep... /bin/grep -E
> > checking for ANSI C header files... yes
> > checking for sys/types.h... yes
> > checking for sys/stat.h... yes
> > checking for stdlib.h... yes
> > checking for string.h... yes
> > checking for memory.h... yes
> > checking for strings.h... yes
> > checking for inttypes.h... yes
> > checking for stdint.h... yes
> > checking for unistd.h... yes
> > checking getopt.h usability... yes
> > checking getopt.h presence... yes
> > checking for getopt.h... yes
> > checking libgen.h usability... yes
> > checking libgen.h presence... yes
> > checking for libgen.h... yes
> > checking for strerror... yes
> > checking for strtol... yes
> > checking for basename... yes
> > checking for strnlen... yes
> > checking for bash... /bin/bash
> > config.status: creating Makefile
> > config.status: creating install-if-change
> > config.status: creating config.h
> > config.status: executing depfiles commands
> > configure: configuring in ./tools/cpu
> > configure: running /bin/sh '../../../../rtems/tools/cpu/configure'
> > '--srcdir=../../../../rtems/tools/cpu'
> > checking rtems target cpu... sparc
> no
> > === configuring in generic
> > (/home/thd/development/rtems/src/builds/erc32_gpio/tools/cpu/generic)
> > configure: running /bin/sh ../../../../../rtems/tools/
> cpu/generic/configure
> > --disable-option-checking
> > '--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu'
> > 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12'
> > --cache-file=/dev/null --srcdir=../../../../../rtems/tools/cpu/generic
> no
> > config.status: creating size_rtems
> > configure: configuring in ./testsuites/tools
> > configure: running /bin/sh '../../../../rtems/testsuites/
> tools/configure'
> > '--srcdir=../../../../rtems/testsuites/tools'
> no
> testsuites/tools/generic)
> > ../../../../../rtems/testsuites/tools/generic/configure
> > --srcdir=../../../../../rtems/testsuites/tools/generic
> no
> > config.status: creating difftest
> > config.status: creating sorttimes
> > configure: configuring in sparc-rtems4.12/c
> > configure: running /bin/sh '../../../../rtems/c/configure'
> '--host=sparc-rtems4.12'
> > '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12'
> > '--with-target-subdir=sparc-rtems4.12'
> > '--exec-prefix=/home/thd/development/rtems/install_path/sparc-rtems4.12'
> > '--includedir=/home/thd/development/rtems/install_
> path/sparc-rtems4.12/include'
> > '--cache-file=/dev/null' '--srcdir=../../../../rtems/c'
> > checking host system type... sparc-unknown-rtems4.12
> > checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
> no
> > target architecture: sparc.
> > available BSPs: erc32.
> > 'make all' will build the following BSPs: erc32.
> > other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170207/cc0e5c68/attachment-0001.html>
