C++ thread library
Stavros Passas stavros.passas at movidius.com
Wed Feb 8 11:22:52 UTC 2017
Hello all,
I would like to know which is the proper way configuring our tool chain for
gnu threads support.
Currently if RTEMS thread compatibility is selected, gthr-rtems.h is used,
which enables
#define __GTHREADS 1
If instead of RTEMS, POSIX thread compatibility is selected, gthr-posix.h
is used, which defines:
#define __GTHREADS_CXX0X 1
The problem I face is that if __GTHREADS_CXX0X is not defined, the
toolchain does not build any C++ support for threads or mutexes, so
applications that use that interface fail to run properly.
Thus the question here is: how easy would it be to add/provide
__GTHREADS_CXX0X  in the RTEMS header? Is it just a matter of adding it
into the toolchain and providing some wrapper functions/stubs to existing
RTEMS functionality, or this functionality is not there at the moment,
which is the reason __GTHREADS_CXX0X  is not currently defined?
Best Regards,
  Stavros
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170208/4d506fc8/attachment.html>
