[PATCH 1/9] Adding Prolific USB Serial driver
Kevin Kirspel
kevin-kirspel at idexx.com
Thu Feb 9 03:21:32 UTC 2017
freebsd/sys/dev/usb/serial/uplcom.c | 936 +++++++++++++++++
freebsd/sys/dev/usb/serial/usb_serial.c | 1719 +++++++++++++++++++++++++++++++
freebsd/sys/dev/usb/serial/usb_serial.h | 221 ++++
3 files changed, 2876 insertions(+)
create mode 100644 freebsd/sys/dev/usb/serial/uplcom.c
create mode 100644 freebsd/sys/dev/usb/serial/usb_serial.c
create mode 100644 freebsd/sys/dev/usb/serial/usb_serial.h
diff --git a/freebsd/sys/dev/usb/serial/uplcom.c b/freebsd/sys/dev/usb/serial/uplcom.c
new file mode 100644
index 0000000..31b5867
--- /dev/null
+++ b/freebsd/sys/dev/usb/serial/uplcom.c
@@ -0,0 +1,936 @@
+#include <machine/rtems-bsd-kernel-space.h>
+/* $NetBSD: uplcom.c,v 1.21 2001/11/13 06:24:56 lukem Exp $ */
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * Copyright (c) 2001-2003, 2005 Shunsuke Akiyama <akiyama at jp.FreeBSD.org>.
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * Copyright (c) 2001 The NetBSD Foundation, Inc.
+ * This code is derived from software contributed to The NetBSD Foundation
+ * by Ichiro FUKUHARA (ichiro at ichiro.org).
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
+ * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
+ * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * This driver supports several USB-to-RS232 serial adapters driven by
+ * Prolific PL-2303, PL-2303X and probably PL-2303HX USB-to-RS232
+ * bridge chip. The adapters are sold under many different brand
+ * names.
+ * Datasheets are available at Prolific www site at
+ * http://www.prolific.com.tw. The datasheets don't contain full
+ * programming information for the chip.
+ * PL-2303HX is probably programmed the same as PL-2303X.
+ * There are several differences between PL-2303 and PL-2303(H)X.
+ * PL-2303(H)X can do higher bitrate in bulk mode, has _probably_
+ * different command for controlling CRTSCTS and needs special
+ * sequence of commands for initialization which aren't also
+ * documented in the datasheet.
+#include <sys/stdint.h>
+#include <sys/stddef.h>
+#include <rtems/bsd/sys/param.h>
+#include <sys/queue.h>
+#include <sys/types.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/module.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/condvar.h>
+#include <sys/sysctl.h>
+#include <sys/sx.h>
+#include <rtems/bsd/sys/unistd.h>
+#include <sys/callout.h>
+#include <sys/malloc.h>
+#include <sys/priv.h>
+#include <dev/usb/usb.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usbdi_util.h>
+#include <dev/usb/usb_cdc.h>
+#include <rtems/bsd/local/usbdevs.h>
+#define USB_DEBUG_VAR uplcom_debug
+#include <dev/usb/usb_debug.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/serial/usb_serial.h>
+#ifdef USB_DEBUG
+static int uplcom_debug = 0;
+static SYSCTL_NODE(_hw_usb, OID_AUTO, uplcom, CTLFLAG_RW, 0, "USB uplcom");
+SYSCTL_INT(_hw_usb_uplcom, OID_AUTO, debug, CTLFLAG_RWTUN,
+ &uplcom_debug, 0, "Debug level");
+#endif
+#define UPLCOM_MODVER 1 /* module version */
+#define UPLCOM_CONFIG_INDEX 0
+#define UPLCOM_IFACE_INDEX 0
+#define UPLCOM_SECOND_IFACE_INDEX 1
+#ifndef UPLCOM_INTR_INTERVAL
+#define UPLCOM_INTR_INTERVAL 0 /* default */
+#endif
+#define UPLCOM_BULK_BUF_SIZE 1024 /* bytes */
+#define UPLCOM_SET_REQUEST 0x01
+#define UPLCOM_SET_CRTSCTS 0x41
+#define UPLCOM_SET_CRTSCTS_PL2303X 0x61
+#define RSAQ_STATUS_CTS 0x80
+#define RSAQ_STATUS_DSR 0x02
+#define RSAQ_STATUS_DCD 0x01
+#define TYPE_PL2303 0
+#define TYPE_PL2303HX 1
+enum {
+ UPLCOM_BULK_DT_WR,
+ UPLCOM_BULK_DT_RD,
+ UPLCOM_INTR_DT_RD,
+ UPLCOM_N_TRANSFER,
+struct uplcom_softc {
+ struct ucom_super_softc sc_super_ucom;
+ struct ucom_softc sc_ucom;
+ struct usb_xfer *sc_xfer[UPLCOM_N_TRANSFER];
+ struct usb_device *sc_udev;
+ struct mtx sc_mtx;
+ uint16_t sc_line;
+ uint8_t sc_lsr; /* local status register */
+ uint8_t sc_msr; /* uplcom status register */
+ uint8_t sc_chiptype; /* type of chip */
+ uint8_t sc_ctrl_iface_no;
+ uint8_t sc_data_iface_no;
+ uint8_t sc_iface_index[2];
+/* prototypes */
+static usb_error_t uplcom_reset(struct uplcom_softc *, struct usb_device *);
+static usb_error_t uplcom_pl2303_do(struct usb_device *, uint8_t, uint8_t,
+ uint16_t, uint16_t, uint16_t);
+static int uplcom_pl2303_init(struct usb_device *, uint8_t);
+static void uplcom_free(struct ucom_softc *);
+static void uplcom_cfg_set_dtr(struct ucom_softc *, uint8_t);
+static void uplcom_cfg_set_rts(struct ucom_softc *, uint8_t);
+static void uplcom_cfg_set_break(struct ucom_softc *, uint8_t);
+static int uplcom_pre_param(struct ucom_softc *, struct termios *);
+static void uplcom_cfg_param(struct ucom_softc *, struct termios *);
+static void uplcom_start_read(struct ucom_softc *);
+static void uplcom_stop_read(struct ucom_softc *);
+static void uplcom_start_write(struct ucom_softc *);
+static void uplcom_stop_write(struct ucom_softc *);
+static void uplcom_cfg_get_status(struct ucom_softc *, uint8_t *,
+ uint8_t *);
+static void uplcom_poll(struct ucom_softc *ucom);
+static device_probe_t uplcom_probe;
+static device_attach_t uplcom_attach;
+static device_detach_t uplcom_detach;
+static void uplcom_free_softc(struct uplcom_softc *);
+static usb_callback_t uplcom_intr_callback;
+static usb_callback_t uplcom_write_callback;
+static usb_callback_t uplcom_read_callback;
+static const struct usb_config uplcom_config_data[UPLCOM_N_TRANSFER] = {
+ [UPLCOM_BULK_DT_WR] = {
+ .type = UE_BULK,
+ .endpoint = UE_ADDR_ANY,
+ .direction = UE_DIR_OUT,
+ .bufsize = UPLCOM_BULK_BUF_SIZE,
+ .flags = {.pipe_bof = 1,.force_short_xfer = 1,},
+ .callback = &uplcom_write_callback,
+ .if_index = 0,
+ [UPLCOM_BULK_DT_RD] = {
+ .type = UE_BULK,
+ .direction = UE_DIR_IN,
+ .flags = {.pipe_bof = 1,.short_xfer_ok = 1,},
+ .callback = &uplcom_read_callback,
+ .if_index = 0,
+ [UPLCOM_INTR_DT_RD] = {
+ .type = UE_INTERRUPT,
+ .bufsize = 0, /* use wMaxPacketSize */
+ .callback = &uplcom_intr_callback,
+ .if_index = 1,
+static struct ucom_callback uplcom_callback = {
+ .ucom_cfg_get_status = &uplcom_cfg_get_status,
+ .ucom_cfg_set_dtr = &uplcom_cfg_set_dtr,
+ .ucom_cfg_set_rts = &uplcom_cfg_set_rts,
+ .ucom_cfg_set_break = &uplcom_cfg_set_break,
+ .ucom_cfg_param = &uplcom_cfg_param,
+ .ucom_pre_param = &uplcom_pre_param,
+ .ucom_start_read = &uplcom_start_read,
+ .ucom_stop_read = &uplcom_stop_read,
+ .ucom_start_write = &uplcom_start_write,
+ .ucom_stop_write = &uplcom_stop_write,
+ .ucom_poll = &uplcom_poll,
+ .ucom_free = &uplcom_free,
+#define UPLCOM_DEV(v,p) \
+ { USB_VENDOR(USB_VENDOR_##v), USB_PRODUCT(USB_PRODUCT_##v##_##p) }
+static const STRUCT_USB_HOST_ID uplcom_devs[] = {
+ UPLCOM_DEV(ACERP, S81), /* BenQ S81 phone */
+ UPLCOM_DEV(ADLINK, ND6530), /* ADLINK ND-6530 USB-Serial */
+ UPLCOM_DEV(ALCATEL, OT535), /* Alcatel One Touch 535/735 */
+ UPLCOM_DEV(ALCOR, AU9720), /* Alcor AU9720 USB 2.0-RS232 */
+ UPLCOM_DEV(ANCHOR, SERIAL), /* Anchor Serial adapter */
+ UPLCOM_DEV(ATEN, UC232A), /* PLANEX USB-RS232 URS-03 */
+ UPLCOM_DEV(BELKIN, F5U257), /* Belkin F5U257 USB to Serial */
+ UPLCOM_DEV(COREGA, CGUSBRS232R), /* Corega CG-USBRS232R */
+ UPLCOM_DEV(EPSON, CRESSI_EDY), /* Cressi Edy diving computer */
+ UPLCOM_DEV(EPSON, N2ITION3), /* Zeagle N2iTion3 diving computer */
+ UPLCOM_DEV(ELECOM, UCSGT), /* ELECOM UC-SGT Serial Adapter */
+ UPLCOM_DEV(ELECOM, UCSGT0), /* ELECOM UC-SGT Serial Adapter */
+ UPLCOM_DEV(HAL, IMR001), /* HAL Corporation Crossam2+USB */
+ UPLCOM_DEV(HP, LD220), /* HP LD220 POS Display */
+ UPLCOM_DEV(IODATA, USBRSAQ), /* I/O DATA USB-RSAQ */
+ UPLCOM_DEV(IODATA, USBRSAQ5), /* I/O DATA USB-RSAQ5 */
+ UPLCOM_DEV(ITEGNO, WM1080A), /* iTegno WM1080A GSM/GFPRS modem */
+ UPLCOM_DEV(ITEGNO, WM2080A), /* iTegno WM2080A CDMA modem */
+ UPLCOM_DEV(LEADTEK, 9531), /* Leadtek 9531 GPS */
+ UPLCOM_DEV(MICROSOFT, 700WX), /* Microsoft Palm 700WX */
+ UPLCOM_DEV(MOBILEACTION, MA620), /* Mobile Action MA-620 Infrared Adapter */
+ UPLCOM_DEV(NETINDEX, WS002IN), /* Willcom W-S002IN */
+ UPLCOM_DEV(NOKIA2, CA42), /* Nokia CA-42 cable */
+ UPLCOM_DEV(OTI, DKU5), /* OTI DKU-5 cable */
+ UPLCOM_DEV(PANASONIC, TYTP50P6S), /* Panasonic TY-TP50P6-S flat screen */
+ UPLCOM_DEV(PLX, CA42), /* PLX CA-42 clone cable */
+ UPLCOM_DEV(PROLIFIC, ALLTRONIX_GPRS), /* Alltronix ACM003U00 modem */
+ UPLCOM_DEV(PROLIFIC, ALDIGA_AL11U), /* AlDiga AL-11U modem */
+ UPLCOM_DEV(PROLIFIC, DCU11), /* DCU-11 Phone Cable */
+ UPLCOM_DEV(PROLIFIC, HCR331), /* HCR331 Card Reader */
+ UPLCOM_DEV(PROLIFIC, MICROMAX_610U), /* Micromax 610U modem */
+ UPLCOM_DEV(PROLIFIC, MOTOROLA), /* Motorola cable */
+ UPLCOM_DEV(PROLIFIC, PHAROS), /* Prolific Pharos */
+ UPLCOM_DEV(PROLIFIC, PL2303), /* Generic adapter */
+ UPLCOM_DEV(PROLIFIC, RSAQ2), /* I/O DATA USB-RSAQ2 */
+ UPLCOM_DEV(PROLIFIC, RSAQ3), /* I/O DATA USB-RSAQ3 */
+ UPLCOM_DEV(PROLIFIC, UIC_MSR206), /* UIC MSR206 Card Reader */
+ UPLCOM_DEV(PROLIFIC2, PL2303), /* Prolific adapter */
+ UPLCOM_DEV(RADIOSHACK, USBCABLE), /* Radio Shack USB Adapter */
+ UPLCOM_DEV(RATOC, REXUSB60), /* RATOC REX-USB60 */
+ UPLCOM_DEV(SAGEM, USBSERIAL), /* Sagem USB-Serial Controller */
+ UPLCOM_DEV(SAMSUNG, I330), /* Samsung I330 phone cradle */
+ UPLCOM_DEV(SANWA, KB_USB2), /* Sanwa KB-USB2 Multimeter cable */
+ UPLCOM_DEV(SIEMENS3, EF81), /* Siemens EF81 */
+ UPLCOM_DEV(SIEMENS3, SX1), /* Siemens SX1 */
+ UPLCOM_DEV(SIEMENS3, X65), /* Siemens X65 */
+ UPLCOM_DEV(SIEMENS3, X75), /* Siemens X75 */
+ UPLCOM_DEV(SITECOM, SERIAL), /* Sitecom USB to Serial */
+ UPLCOM_DEV(SMART, PL2303), /* SMART Technologies USB to Serial */
+ UPLCOM_DEV(SONY, QN3), /* Sony QN3 phone cable */
+ UPLCOM_DEV(SONYERICSSON, DATAPILOT), /* Sony Ericsson Datapilot */
+ UPLCOM_DEV(SONYERICSSON, DCU10), /* Sony Ericsson DCU-10 Cable */
+ UPLCOM_DEV(SOURCENEXT, KEIKAI8), /* SOURCENEXT KeikaiDenwa 8 */
+ UPLCOM_DEV(SOURCENEXT, KEIKAI8_CHG), /* SOURCENEXT KeikaiDenwa 8 with charger */
+ UPLCOM_DEV(SPEEDDRAGON, MS3303H), /* Speed Dragon USB-Serial */
+ UPLCOM_DEV(SYNTECH, CPT8001C), /* Syntech CPT-8001C Barcode scanner */
+ UPLCOM_DEV(TDK, UHA6400), /* TDK USB-PHS Adapter UHA6400 */
+ UPLCOM_DEV(TDK, UPA9664), /* TDK USB-PHS Adapter UPA9664 */
+ UPLCOM_DEV(TRIPPLITE, U209), /* Tripp-Lite U209-000-R USB to Serial */
+ UPLCOM_DEV(YCCABLE, PL2303), /* YC Cable USB-Serial */
+#undef UPLCOM_DEV
+static device_method_t uplcom_methods[] = {
+ DEVMETHOD(device_probe, uplcom_probe),
+ DEVMETHOD(device_attach, uplcom_attach),
+ DEVMETHOD(device_detach, uplcom_detach),
+ DEVMETHOD_END
+static devclass_t uplcom_devclass;
+static driver_t uplcom_driver = {
+ .name = "uplcom",
+ .methods = uplcom_methods,
+ .size = sizeof(struct uplcom_softc),
+DRIVER_MODULE(uplcom, uhub, uplcom_driver, uplcom_devclass, NULL, 0);
+MODULE_DEPEND(uplcom, ucom, 1, 1, 1);
+MODULE_DEPEND(uplcom, usb, 1, 1, 1);
+MODULE_VERSION(uplcom, UPLCOM_MODVER);
+USB_PNP_HOST_INFO(uplcom_devs);
+static int
+uplcom_probe(device_t dev)
+ struct usb_attach_arg *uaa = device_get_ivars(dev);
+ DPRINTFN(11, "\n");
+ if (uaa->usb_mode != USB_MODE_HOST) {
+ return (ENXIO);
+ if (uaa->info.bConfigIndex != UPLCOM_CONFIG_INDEX) {
+ return (ENXIO);
+ if (uaa->info.bIfaceIndex != UPLCOM_IFACE_INDEX) {
+ return (ENXIO);
+ return (usbd_lookup_id_by_uaa(uplcom_devs, sizeof(uplcom_devs), uaa));
+static int
+uplcom_attach(device_t dev)
+ struct uplcom_softc *sc = device_get_softc(dev);
+ struct usb_interface *iface;
+ struct usb_interface_descriptor *id;
+ struct usb_device_descriptor *dd;
+ int error;
+ device_set_usb_desc(dev);
+ mtx_init(&sc->sc_mtx, "uplcom", NULL, MTX_DEF);
+ ucom_ref(&sc->sc_super_ucom);
+ DPRINTF("sc = %p\n", sc);
+ sc->sc_udev = uaa->device;
+ /* Determine the chip type. This algorithm is taken from Linux. */
+ dd = usbd_get_device_descriptor(sc->sc_udev);
+ if (dd->bDeviceClass == 0x02)
+ sc->sc_chiptype = TYPE_PL2303;
+ else if (dd->bMaxPacketSize == 0x40)
+ sc->sc_chiptype = TYPE_PL2303HX;
+ else
+ DPRINTF("chiptype: %s\n",
+ (sc->sc_chiptype == TYPE_PL2303HX) ?
+ "2303X" : "2303");
+ * USB-RSAQ1 has two interface
+ * USB-RSAQ1 | USB-RSAQ2
+ * Interface 0 |Interface 0
+ * Interrupt(0x81) | Interrupt(0x81)
+ * -----------------+ BulkIN(0x02)
+ * Interface 1 | BulkOUT(0x83)
+ * BulkIN(0x02) |
+ * BulkOUT(0x83) |
+ sc->sc_ctrl_iface_no = uaa->info.bIfaceNum;
+ sc->sc_iface_index[1] = UPLCOM_IFACE_INDEX;
+ iface = usbd_get_iface(uaa->device, UPLCOM_SECOND_IFACE_INDEX);
+ if (iface) {
+ id = usbd_get_interface_descriptor(iface);
+ if (id == NULL) {
+ device_printf(dev, "no interface descriptor (2)\n");
+ goto detach;
+ sc->sc_data_iface_no = id->bInterfaceNumber;
+ sc->sc_iface_index[0] = UPLCOM_SECOND_IFACE_INDEX;
+ usbd_set_parent_iface(uaa->device,
+ UPLCOM_SECOND_IFACE_INDEX, uaa->info.bIfaceIndex);
+ } else {
+ sc->sc_data_iface_no = sc->sc_ctrl_iface_no;
+ sc->sc_iface_index[0] = UPLCOM_IFACE_INDEX;
+ error = usbd_transfer_setup(uaa->device,
+ sc->sc_iface_index, sc->sc_xfer, uplcom_config_data,
+ UPLCOM_N_TRANSFER, sc, &sc->sc_mtx);
+ if (error) {
+ DPRINTF("one or more missing USB endpoints, "
+ "error=%s\n", usbd_errstr(error));
+ goto detach;
+ error = uplcom_reset(sc, uaa->device);
+ if (error) {
+ device_printf(dev, "reset failed, error=%s\n",
+ usbd_errstr(error));
+ goto detach;
+ if (sc->sc_chiptype != TYPE_PL2303HX) {
+ /* HX variants seem to lock up after a clear stall request. */
+ mtx_lock(&sc->sc_mtx);
+ usbd_xfer_set_stall(sc->sc_xfer[UPLCOM_BULK_DT_WR]);
+ usbd_xfer_set_stall(sc->sc_xfer[UPLCOM_BULK_DT_RD]);
+ mtx_unlock(&sc->sc_mtx);
+ } else {
+ if (uplcom_pl2303_do(sc->sc_udev, UT_WRITE_VENDOR_DEVICE,
+ UPLCOM_SET_REQUEST, 8, 0, 0) ||
+ uplcom_pl2303_do(sc->sc_udev, UT_WRITE_VENDOR_DEVICE,
+ UPLCOM_SET_REQUEST, 9, 0, 0)) {
+ goto detach;
+ error = ucom_attach(&sc->sc_super_ucom, &sc->sc_ucom, 1, sc,
+ &uplcom_callback, &sc->sc_mtx);
+ if (error) {
+ goto detach;
+ * do the initialization during attach so that the system does not
+ * sleep during open:
+ if (uplcom_pl2303_init(uaa->device, sc->sc_chiptype)) {
+ device_printf(dev, "init failed\n");
+ goto detach;
+ ucom_set_pnpinfo_usb(&sc->sc_super_ucom, dev);
+ return (0);
+detach:
+ uplcom_detach(dev);
+ return (ENXIO);
+static int
+uplcom_detach(device_t dev)
+ DPRINTF("sc=%p\n", sc);
+ ucom_detach(&sc->sc_super_ucom, &sc->sc_ucom);
+ usbd_transfer_unsetup(sc->sc_xfer, UPLCOM_N_TRANSFER);
+ device_claim_softc(dev);
+ uplcom_free_softc(sc);
+ return (0);
+UCOM_UNLOAD_DRAIN(uplcom);
+static void
+uplcom_free_softc(struct uplcom_softc *sc)
+ if (ucom_unref(&sc->sc_super_ucom)) {
+ mtx_destroy(&sc->sc_mtx);
+ device_free_softc(sc);
+static void
+uplcom_free(struct ucom_softc *ucom)
+ uplcom_free_softc(ucom->sc_parent);
+static usb_error_t
+uplcom_reset(struct uplcom_softc *sc, struct usb_device *udev)
+ struct usb_device_request req;
+ req.bmRequestType = UT_WRITE_VENDOR_DEVICE;
+ req.bRequest = UPLCOM_SET_REQUEST;
+ USETW(req.wValue, 0);
+ req.wIndex[0] = sc->sc_data_iface_no;
+ req.wIndex[1] = 0;
+ USETW(req.wLength, 0);
+ return (usbd_do_request(udev, NULL, &req, NULL));
+static usb_error_t
+uplcom_pl2303_do(struct usb_device *udev, uint8_t req_type, uint8_t request,
+ uint16_t value, uint16_t index, uint16_t length)
+ usb_error_t err;
+ uint8_t buf[4];
+ req.bmRequestType = req_type;
+ req.bRequest = request;
+ USETW(req.wValue, value);
+ USETW(req.wIndex, index);
+ USETW(req.wLength, length);
+ err = usbd_do_request(udev, NULL, &req, buf);
+ if (err) {
+ DPRINTF("error=%s\n", usbd_errstr(err));
+ return (1);
+ return (0);
+static int
+uplcom_pl2303_init(struct usb_device *udev, uint8_t chiptype)
+ int err;
+ if (uplcom_pl2303_do(udev, UT_READ_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0x8484, 0, 1)
+ || uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0x0404, 0, 0)
+ || uplcom_pl2303_do(udev, UT_READ_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0x8484, 0, 1)
+ || uplcom_pl2303_do(udev, UT_READ_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0x8383, 0, 1)
+ || uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0x0404, 1, 0)
+ || uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 0, 1, 0)
+ || uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 1, 0, 0))
+ return (EIO);
+ if (chiptype == TYPE_PL2303HX)
+ err = uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 2, 0x44, 0);
+ else
+ err = uplcom_pl2303_do(udev, UT_WRITE_VENDOR_DEVICE, UPLCOM_SET_REQUEST, 2, 0x24, 0);
+ if (err)
+ return (EIO);
+ return (0);
+static void
+uplcom_cfg_set_dtr(struct ucom_softc *ucom, uint8_t onoff)
+ struct uplcom_softc *sc = ucom->sc_parent;
+ DPRINTF("onoff = %d\n", onoff);
+ if (onoff)
+ sc->sc_line |= UCDC_LINE_DTR;
+ else
+ sc->sc_line &= ~UCDC_LINE_DTR;
+ req.bmRequestType = UT_WRITE_CLASS_INTERFACE;
+ req.bRequest = UCDC_SET_CONTROL_LINE_STATE;
+ USETW(req.wValue, sc->sc_line);
+ ucom_cfg_do_request(sc->sc_udev, &sc->sc_ucom,
+ &req, NULL, 0, 1000);
+static void
+uplcom_cfg_set_rts(struct ucom_softc *ucom, uint8_t onoff)
+ if (onoff)
+ sc->sc_line |= UCDC_LINE_RTS;
+ else
+ sc->sc_line &= ~UCDC_LINE_RTS;
+static void
+uplcom_cfg_set_break(struct ucom_softc *ucom, uint8_t onoff)
+ uint16_t temp;
+ temp = (onoff ? UCDC_BREAK_ON : UCDC_BREAK_OFF);
+ req.bRequest = UCDC_SEND_BREAK;
+ USETW(req.wValue, temp);
+static const uint32_t uplcom_rates[] = {
+ 75, 150, 300, 600, 1200, 1800, 2400, 3600, 4800, 7200, 9600, 14400,
+ 19200, 28800, 38400, 57600, 115200,
+ * Higher speeds are probably possible. PL2303X supports up to
+ * 6Mb and can set any rate
+ 230400, 460800, 614400, 921600, 1228800
+#define N_UPLCOM_RATES nitems(uplcom_rates)
+static int
+uplcom_pre_param(struct ucom_softc *ucom, struct termios *t)
+ uint8_t i;
+ DPRINTF("\n");
+ * Check requested baud rate.
+ * The PL2303 can only set specific baud rates, up to 1228800 baud.
+ * The PL2303X can set any baud rate up to 6Mb.
+ * The PL2303HX rev. D can set any baud rate up to 12Mb.
+ * XXX: We currently cannot identify the PL2303HX rev. D, so treat
+ * it the same as the PL2303X.
+ for (i = 0; i < N_UPLCOM_RATES; i++) {
+ if (uplcom_rates[i] == t->c_ospeed)
+ return (0);
+ } else {
+ if (t->c_ospeed <= 6000000)
+ return (0);
+ DPRINTF("uplcom_param: bad baud rate (%d)\n", t->c_ospeed);
+ return (EIO);
+static void
+uplcom_cfg_param(struct ucom_softc *ucom, struct termios *t)
+ struct usb_cdc_line_state ls;
+ memset(&ls, 0, sizeof(ls));
+ USETDW(ls.dwDTERate, t->c_ospeed);
+ if (t->c_cflag & CSTOPB) {
+ ls.bCharFormat = UCDC_STOP_BIT_2;
+ } else {
+ ls.bCharFormat = UCDC_STOP_BIT_1;
+ if (t->c_cflag & PARENB) {
+ if (t->c_cflag & PARODD) {
+ ls.bParityType = UCDC_PARITY_ODD;
+ } else {
+ ls.bParityType = UCDC_PARITY_EVEN;
+ } else {
+ ls.bParityType = UCDC_PARITY_NONE;
+ switch (t->c_cflag & CSIZE) {
+ case CS5:
+ ls.bDataBits = 5;
+ break;
+ case CS6:
+ ls.bDataBits = 6;
+ break;
+ case CS7:
+ ls.bDataBits = 7;
+ break;
+ case CS8:
+ ls.bDataBits = 8;
+ break;
+ DPRINTF("rate=%d fmt=%d parity=%d bits=%d\n",
+ UGETDW(ls.dwDTERate), ls.bCharFormat,
+ ls.bParityType, ls.bDataBits);
+ req.bRequest = UCDC_SET_LINE_CODING;
+ USETW(req.wLength, UCDC_LINE_STATE_LENGTH);
+ &req, &ls, 0, 1000);
+ if (t->c_cflag & CRTSCTS) {
+ DPRINTF("crtscts = on\n");
+ if (sc->sc_chiptype == TYPE_PL2303HX)
+ USETW(req.wIndex, UPLCOM_SET_CRTSCTS_PL2303X);
+ else
+ USETW(req.wIndex, UPLCOM_SET_CRTSCTS);
+ } else {
+ USETW(req.wIndex, 0);
+static void
+uplcom_start_read(struct ucom_softc *ucom)
+ /* start interrupt endpoint */
+ usbd_transfer_start(sc->sc_xfer[UPLCOM_INTR_DT_RD]);
+ /* start read endpoint */
+ usbd_transfer_start(sc->sc_xfer[UPLCOM_BULK_DT_RD]);
+static void
+uplcom_stop_read(struct ucom_softc *ucom)
+ /* stop interrupt endpoint */
+ usbd_transfer_stop(sc->sc_xfer[UPLCOM_INTR_DT_RD]);
+ /* stop read endpoint */
+ usbd_transfer_stop(sc->sc_xfer[UPLCOM_BULK_DT_RD]);
+static void
+uplcom_start_write(struct ucom_softc *ucom)
+ usbd_transfer_start(sc->sc_xfer[UPLCOM_BULK_DT_WR]);
+static void
+uplcom_stop_write(struct ucom_softc *ucom)
+ usbd_transfer_stop(sc->sc_xfer[UPLCOM_BULK_DT_WR]);
+static void
+uplcom_cfg_get_status(struct ucom_softc *ucom, uint8_t *lsr, uint8_t *msr)
+ DPRINTF("\n");
+ /* XXX Note: sc_lsr is always zero */
+ *lsr = sc->sc_lsr;
+ *msr = sc->sc_msr;
+static void
+uplcom_intr_callback(struct usb_xfer *xfer, usb_error_t error)
+ struct uplcom_softc *sc = usbd_xfer_softc(xfer);
+ struct usb_page_cache *pc;
+ uint8_t buf[9];
+ int actlen;
+ usbd_xfer_status(xfer, &actlen, NULL, NULL, NULL);
+ switch (USB_GET_STATE(xfer)) {
+ case USB_ST_TRANSFERRED:
+ DPRINTF("actlen = %u\n", actlen);
+ if (actlen >= 9) {
+ pc = usbd_xfer_get_frame(xfer, 0);
+ usbd_copy_out(pc, 0, buf, sizeof(buf));
+ DPRINTF("status = 0x%02x\n", buf[8]);
+ sc->sc_lsr = 0;
+ sc->sc_msr = 0;
+ if (buf[8] & RSAQ_STATUS_CTS) {
+ sc->sc_msr |= SER_CTS;
+ if (buf[8] & RSAQ_STATUS_DSR) {
+ sc->sc_msr |= SER_DSR;
+ if (buf[8] & RSAQ_STATUS_DCD) {
+ sc->sc_msr |= SER_DCD;
+ ucom_status_change(&sc->sc_ucom);
+ case USB_ST_SETUP:
+tr_setup:
+ usbd_xfer_set_frame_len(xfer, 0, usbd_xfer_max_len(xfer));
+ usbd_transfer_submit(xfer);
+ return;
+ default: /* Error */
+ if (error != USB_ERR_CANCELLED) {
+ /* try to clear stall first */
+ usbd_xfer_set_stall(xfer);
+ goto tr_setup;
+ return;
+static void
+uplcom_write_callback(struct usb_xfer *xfer, usb_error_t error)
+ uint32_t actlen;
+tr_setup:
+ if (ucom_get_data(&sc->sc_ucom, pc, 0,
+ UPLCOM_BULK_BUF_SIZE, &actlen)) {
+ DPRINTF("actlen = %d\n", actlen);
+ usbd_xfer_set_frame_len(xfer, 0, actlen);
+ return;
+ goto tr_setup;
+ return;
+static void
+uplcom_read_callback(struct usb_xfer *xfer, usb_error_t error)
+ int actlen;
+ ucom_put_data(&sc->sc_ucom, pc, 0, actlen);
+tr_setup:
+ return;
+ goto tr_setup;
+ return;
+static void
+uplcom_poll(struct ucom_softc *ucom)
+ usbd_transfer_poll(sc->sc_xfer, UPLCOM_N_TRANSFER);
diff --git a/freebsd/sys/dev/usb/serial/usb_serial.c b/freebsd/sys/dev/usb/serial/usb_serial.c
index 0000000..f425a16
--- /dev/null
+++ b/freebsd/sys/dev/usb/serial/usb_serial.c
@@ -0,0 +1,1719 @@
+/* $NetBSD: ucom.c,v 1.40 2001/11/13 06:24:54 lukem Exp $ */
+ * Copyright (c) 2001-2003, 2005, 2008
+ * Shunsuke Akiyama <akiyama at jp.FreeBSD.org>.
+ * are met:
+ * SUCH DAMAGE.
+ * Copyright (c) 1998, 2000 The NetBSD Foundation, Inc.
+ * by Lennart Augustsson (lennart at augustsson.net) at
+ * Carlstedt Research & Technology.
+ * are met:
+#include <sys/cons.h>
+#include <dev/uart/uart_ppstypes.h>
+#define USB_DEBUG_VAR ucom_debug
+#include <dev/usb/usb_busdma.h>
+#include <rtems/bsd/local/opt_gdb.h>
+static SYSCTL_NODE(_hw_usb, OID_AUTO, ucom, CTLFLAG_RW, 0, "USB ucom");
+static int ucom_pps_mode;
+SYSCTL_INT(_hw_usb_ucom, OID_AUTO, pps_mode, CTLFLAG_RWTUN,
+ &ucom_pps_mode, 0,
+ "pulse capture mode: 0/1/2=disabled/CTS/DCD; add 0x10 to invert");
+#ifdef USB_DEBUG
+static int ucom_debug = 0;
+SYSCTL_INT(_hw_usb_ucom, OID_AUTO, debug, CTLFLAG_RWTUN,
+ &ucom_debug, 0, "ucom debug level");
+#endif
+#define UCOM_CONS_BUFSIZE 1024
+static uint8_t ucom_cons_rx_buf[UCOM_CONS_BUFSIZE];
+static uint8_t ucom_cons_tx_buf[UCOM_CONS_BUFSIZE];
+static unsigned int ucom_cons_rx_low = 0;
+static unsigned int ucom_cons_rx_high = 0;
+static unsigned int ucom_cons_tx_low = 0;
+static unsigned int ucom_cons_tx_high = 0;
+static int ucom_cons_unit = -1;
+static int ucom_cons_subunit = 0;
+static int ucom_cons_baud = 9600;
+static struct ucom_softc *ucom_cons_softc = NULL;
+SYSCTL_INT(_hw_usb_ucom, OID_AUTO, cons_unit, CTLFLAG_RWTUN,
+ &ucom_cons_unit, 0, "console unit number");
+SYSCTL_INT(_hw_usb_ucom, OID_AUTO, cons_subunit, CTLFLAG_RWTUN,
+ &ucom_cons_subunit, 0, "console subunit number");
+SYSCTL_INT(_hw_usb_ucom, OID_AUTO, cons_baud, CTLFLAG_RWTUN,
+ &ucom_cons_baud, 0, "console baud rate");
+static usb_proc_callback_t ucom_cfg_start_transfers;
+static usb_proc_callback_t ucom_cfg_open;
+static usb_proc_callback_t ucom_cfg_close;
+static usb_proc_callback_t ucom_cfg_line_state;
+static usb_proc_callback_t ucom_cfg_status_change;
+static usb_proc_callback_t ucom_cfg_param;
+static int ucom_unit_alloc(void);
+static void ucom_unit_free(int);
+static int ucom_attach_tty(struct ucom_super_softc *, struct ucom_softc *);
+static void ucom_detach_tty(struct ucom_super_softc *, struct ucom_softc *);
+static void ucom_queue_command(struct ucom_softc *,
+ usb_proc_callback_t *, struct termios *pt,
+ struct usb_proc_msg *t0, struct usb_proc_msg *t1);
+static void ucom_shutdown(struct ucom_softc *);
+static void ucom_ring(struct ucom_softc *, uint8_t);
+static void ucom_break(struct ucom_softc *, uint8_t);
+static void ucom_dtr(struct ucom_softc *, uint8_t);
+static void ucom_rts(struct ucom_softc *, uint8_t);
+static tsw_open_t ucom_open;
+static tsw_close_t ucom_close;
+static tsw_ioctl_t ucom_ioctl;
+static tsw_modem_t ucom_modem;
+static tsw_param_t ucom_param;
+static tsw_outwakeup_t ucom_outwakeup;
+static tsw_inwakeup_t ucom_inwakeup;
+static tsw_free_t ucom_free;
+static struct ttydevsw ucom_class = {
+ .tsw_flags = TF_INITLOCK | TF_CALLOUT,
+ .tsw_open = ucom_open,
+ .tsw_close = ucom_close,
+ .tsw_outwakeup = ucom_outwakeup,
+ .tsw_inwakeup = ucom_inwakeup,
+ .tsw_ioctl = ucom_ioctl,
+ .tsw_param = ucom_param,
+ .tsw_modem = ucom_modem,
+ .tsw_free = ucom_free,
+MODULE_DEPEND(ucom, usb, 1, 1, 1);
+MODULE_VERSION(ucom, 1);
+#define UCOM_UNIT_MAX 128 /* maximum number of units */
+#define UCOM_TTY_PREFIX "U"
+static struct unrhdr *ucom_unrhdr;
+static struct mtx ucom_mtx;
+static int ucom_close_refs;
+static void
+ucom_init(void *arg)
+ DPRINTF("\n");
+ ucom_unrhdr = new_unrhdr(0, UCOM_UNIT_MAX - 1, NULL);
+ mtx_init(&ucom_mtx, "UCOM MTX", NULL, MTX_DEF);
+SYSINIT(ucom_init, SI_SUB_KLD - 1, SI_ORDER_ANY, ucom_init, NULL);
+static void
+ucom_uninit(void *arg)
+ struct unrhdr *hdr;
+ hdr = ucom_unrhdr;
+ ucom_unrhdr = NULL;
+ DPRINTF("\n");
+ if (hdr != NULL)
+ delete_unrhdr(hdr);
+ mtx_destroy(&ucom_mtx);
+SYSUNINIT(ucom_uninit, SI_SUB_KLD - 3, SI_ORDER_ANY, ucom_uninit, NULL);
+ * Mark a unit number (the X in cuaUX) as in use.
+ * Note that devices using a different naming scheme (see ucom_tty_name()
+ * callback) still use this unit allocation.
+static int
+ucom_unit_alloc(void)
+ int unit;
+ /* sanity checks */
+ if (ucom_unrhdr == NULL) {
+ DPRINTF("ucom_unrhdr is NULL\n");
+ return (-1);
+ unit = alloc_unr(ucom_unrhdr);
+ DPRINTF("unit %d is allocated\n", unit);
+ return (unit);
+ * Mark the unit number as not in use.
+static void
+ucom_unit_free(int unit)
+ if (unit < 0 || unit >= UCOM_UNIT_MAX || ucom_unrhdr == NULL) {
+ DPRINTF("cannot free unit number\n");
+ return;
+ DPRINTF("unit %d is freed\n", unit);
+ free_unr(ucom_unrhdr, unit);
+ * Setup a group of one or more serial ports.
+ * The mutex pointed to by "mtx" is applied before all
+ * callbacks are called back. Also "mtx" must be applied
+ * before calling into the ucom-layer!
+int
+ucom_attach(struct ucom_super_softc *ssc, struct ucom_softc *sc,
+ int subunits, void *parent,
+ const struct ucom_callback *callback, struct mtx *mtx)
+ int subunit;
+ int error = 0;
+ if ((sc == NULL) ||
+ (subunits <= 0) ||
+ (callback == NULL) ||
+ (mtx == NULL)) {
+ return (EINVAL);
+ /* allocate a uniq unit number */
+ ssc->sc_unit = ucom_unit_alloc();
+ if (ssc->sc_unit == -1)
+ return (ENOMEM);
+ /* generate TTY name string */
+ snprintf(ssc->sc_ttyname, sizeof(ssc->sc_ttyname),
+ UCOM_TTY_PREFIX "%d", ssc->sc_unit);
+ /* create USB request handling process */
+ error = usb_proc_create(&ssc->sc_tq, mtx, "ucom", USB_PRI_MED);
+ if (error) {
+ ucom_unit_free(ssc->sc_unit);
+ return (error);
+ ssc->sc_subunits = subunits;
+ ssc->sc_flag = UCOM_FLAG_ATTACHED |
+ UCOM_FLAG_FREE_UNIT;
+ if (callback->ucom_free == NULL)
+ ssc->sc_flag |= UCOM_FLAG_WAIT_REFS;
+ /* increment reference count */
+ ucom_ref(ssc);
+ for (subunit = 0; subunit < ssc->sc_subunits; subunit++) {
+ sc[subunit].sc_subunit = subunit;
+ sc[subunit].sc_super = ssc;
+ sc[subunit].sc_mtx = mtx;
+ sc[subunit].sc_parent = parent;
+ sc[subunit].sc_callback = callback;
+ error = ucom_attach_tty(ssc, &sc[subunit]);
+ if (error) {
+ ucom_detach(ssc, &sc[0]);
+ return (error);
+ ucom_ref(ssc);
+ /* set subunit attached */
+ sc[subunit].sc_flag |= UCOM_FLAG_ATTACHED;
+ DPRINTF("tp = %p, unit = %d, subunits = %d\n",
+ sc->sc_tty, ssc->sc_unit, ssc->sc_subunits);
+ return (0);
+ * The following function will do nothing if the structure pointed to
+ * by "ssc" and "sc" is zero or has already been detached.
+void
+ucom_detach(struct ucom_super_softc *ssc, struct ucom_softc *sc)
+ int subunit;
+ if (!(ssc->sc_flag & UCOM_FLAG_ATTACHED))
+ return; /* not initialized */
+ if (ssc->sc_sysctl_ttyname != NULL) {
+ sysctl_remove_oid(ssc->sc_sysctl_ttyname, 1, 0);
+ ssc->sc_sysctl_ttyname = NULL;
+ if (ssc->sc_sysctl_ttyports != NULL) {
+ sysctl_remove_oid(ssc->sc_sysctl_ttyports, 1, 0);
+ ssc->sc_sysctl_ttyports = NULL;
+ usb_proc_drain(&ssc->sc_tq);
+ if (sc[subunit].sc_flag & UCOM_FLAG_ATTACHED) {
+ ucom_detach_tty(ssc, &sc[subunit]);
+ /* avoid duplicate detach */
+ sc[subunit].sc_flag &= ~UCOM_FLAG_ATTACHED;
+ usb_proc_free(&ssc->sc_tq);
+ ucom_unref(ssc);
+ if (ssc->sc_flag & UCOM_FLAG_WAIT_REFS)
+ ucom_drain(ssc);
+ /* make sure we don't detach twice */
+ ssc->sc_flag &= ~UCOM_FLAG_ATTACHED;
+void
+ucom_drain(struct ucom_super_softc *ssc)
+ mtx_lock(&ucom_mtx);
+ while (ssc->sc_refs > 0) {
+ printf("ucom: Waiting for a TTY device to close.\n");
+ usb_pause_mtx(&ucom_mtx, hz);
+ mtx_unlock(&ucom_mtx);
+void
+ucom_drain_all(void *arg)
+ while (ucom_close_refs > 0) {
+ printf("ucom: Waiting for all detached TTY "
+ "devices to have open fds closed.\n");
+static int
+ucom_attach_tty(struct ucom_super_softc *ssc, struct ucom_softc *sc)
+ struct tty *tp;
+ char buf[32]; /* temporary TTY device name buffer */
+ tp = tty_alloc_mutex(&ucom_class, sc, sc->sc_mtx);
+ if (tp == NULL)
+ return (ENOMEM);
+ /* Check if the client has a custom TTY name */
+ buf[0] = '\0';
+ if (sc->sc_callback->ucom_tty_name) {
+ sc->sc_callback->ucom_tty_name(sc, buf,
+ sizeof(buf), ssc->sc_unit, sc->sc_subunit);
+ if (buf[0] == 0) {
+ /* Use default TTY name */
+ if (ssc->sc_subunits > 1) {
+ /* multiple modems in one */
+ snprintf(buf, sizeof(buf), UCOM_TTY_PREFIX "%u.%u",
+ ssc->sc_unit, sc->sc_subunit);
+ } else {
+ /* single modem */
+ snprintf(buf, sizeof(buf), UCOM_TTY_PREFIX "%u",
+ ssc->sc_unit);
+ tty_makedev(tp, NULL, "%s", buf);
+ sc->sc_tty = tp;
+ sc->sc_pps.ppscap = PPS_CAPTUREBOTH;
+ sc->sc_pps.driver_abi = PPS_ABI_VERSION;
+ sc->sc_pps.driver_mtx = sc->sc_mtx;
+ pps_init_abi(&sc->sc_pps);
+ DPRINTF("ttycreate: %s\n", buf);
+ /* Check if this device should be a console */
+ if ((ucom_cons_softc == NULL) &&
+ (ssc->sc_unit == ucom_cons_unit) &&
+ (sc->sc_subunit == ucom_cons_subunit)) {
+ DPRINTF("unit %d subunit %d is console",
+ ucom_cons_softc = sc;
+ tty_init_console(tp, ucom_cons_baud);
+ UCOM_MTX_LOCK(ucom_cons_softc);
+ ucom_cons_rx_low = 0;
+ ucom_cons_rx_high = 0;
+ ucom_cons_tx_low = 0;
+ ucom_cons_tx_high = 0;
+ sc->sc_flag |= UCOM_FLAG_CONSOLE;
+ ucom_open(ucom_cons_softc->sc_tty);
+ ucom_param(ucom_cons_softc->sc_tty, &tp->t_termios_init_in);
+ UCOM_MTX_UNLOCK(ucom_cons_softc);
+ return (0);
+static void
+ucom_detach_tty(struct ucom_super_softc *ssc, struct ucom_softc *sc)
+ struct tty *tp = sc->sc_tty;
+ DPRINTF("sc = %p, tp = %p\n", sc, sc->sc_tty);
+ if (sc->sc_flag & UCOM_FLAG_CONSOLE) {
+ ucom_close(ucom_cons_softc->sc_tty);
+ sc->sc_flag &= ~UCOM_FLAG_CONSOLE;
+ ucom_cons_softc = NULL;
+ /* the config thread has been stopped when we get here */
+ UCOM_MTX_LOCK(sc);
+ sc->sc_flag |= UCOM_FLAG_GONE;
+ sc->sc_flag &= ~(UCOM_FLAG_HL_READY | UCOM_FLAG_LL_READY);
+ UCOM_MTX_UNLOCK(sc);
+ if (tp) {
+ ucom_close_refs++;
+ tty_lock(tp);
+ ucom_close(tp); /* close, if any */
+ tty_rel_gone(tp);
+ * make sure that read and write transfers are stopped
+ if (sc->sc_callback->ucom_stop_read)
+ (sc->sc_callback->ucom_stop_read) (sc);
+ if (sc->sc_callback->ucom_stop_write)
+ (sc->sc_callback->ucom_stop_write) (sc);
+void
+ucom_set_pnpinfo_usb(struct ucom_super_softc *ssc, device_t dev)
+ char buf[64];
+ uint8_t iface_index;
+ struct usb_attach_arg *uaa;
+ snprintf(buf, sizeof(buf), "ttyname=" UCOM_TTY_PREFIX
+ "%d ttyports=%d", ssc->sc_unit, ssc->sc_subunits);
+ /* Store the PNP info in the first interface for the device */
+ uaa = device_get_ivars(dev);
+ iface_index = uaa->info.bIfaceIndex;
+ if (usbd_set_pnpinfo(uaa->device, iface_index, buf) != 0)
+ device_printf(dev, "Could not set PNP info\n");
+ * The following information is also replicated in the PNP-info
+ * string which is registered above:
+ if (ssc->sc_sysctl_ttyname == NULL) {
+ ssc->sc_sysctl_ttyname = SYSCTL_ADD_STRING(NULL,
+ SYSCTL_CHILDREN(device_get_sysctl_tree(dev)),
+ OID_AUTO, "ttyname", CTLFLAG_RD, ssc->sc_ttyname, 0,
+ "TTY device basename");
+ if (ssc->sc_sysctl_ttyports == NULL) {
+ ssc->sc_sysctl_ttyports = SYSCTL_ADD_INT(NULL,
+ OID_AUTO, "ttyports", CTLFLAG_RD,
+ NULL, ssc->sc_subunits, "Number of ports");
+static void
+ucom_queue_command(struct ucom_softc *sc,
+ usb_proc_callback_t *fn, struct termios *pt,
+ struct ucom_super_softc *ssc = sc->sc_super;
+ struct ucom_param_task *task;
+ UCOM_MTX_ASSERT(sc, MA_OWNED);
+ if (usb_proc_is_gone(&ssc->sc_tq)) {
+ DPRINTF("proc is gone\n");
+ return; /* nothing to do */
+ * NOTE: The task cannot get executed before we drop the
+ * "sc_mtx" mutex. It is safe to update fields in the message
+ * structure after that the message got queued.
+ task = (struct ucom_param_task *)
+ usb_proc_msignal(&ssc->sc_tq, t0, t1);
+ /* Setup callback and softc pointers */
+ task->hdr.pm_callback = fn;
+ task->sc = sc;
+ * Make a copy of the termios. This field is only present if
+ * the "pt" field is not NULL.
+ if (pt != NULL)
+ task->termios_copy = *pt;
+ * Closing the device should be synchronous.
+ if (fn == ucom_cfg_close)
+ usb_proc_mwait(&ssc->sc_tq, t0, t1);
+ * In case of multiple configure requests,
+ * keep track of the last one!
+ if (fn == ucom_cfg_start_transfers)
+ sc->sc_last_start_xfer = &task->hdr;
+static void
+ucom_shutdown(struct ucom_softc *sc)
+ DPRINTF("\n");
+ * Hang up if necessary:
+ if (tp->t_termios.c_cflag & HUPCL) {
+ ucom_modem(tp, 0, SER_DTR);
+ * Return values:
+ * 0: normal
+ * else: taskqueue is draining or gone
+uint8_t
+ucom_cfg_is_gone(struct ucom_softc *sc)
+ return (usb_proc_is_gone(&ssc->sc_tq));
+static void
+ucom_cfg_start_transfers(struct usb_proc_msg *_task)
+ struct ucom_cfg_task *task =
+ (struct ucom_cfg_task *)_task;
+ struct ucom_softc *sc = task->sc;
+ if (!(sc->sc_flag & UCOM_FLAG_LL_READY)) {
+ return;
+ if (!(sc->sc_flag & UCOM_FLAG_HL_READY)) {
+ /* TTY device closed */
+ return;
+ if (_task == sc->sc_last_start_xfer)
+ sc->sc_flag |= UCOM_FLAG_GP_DATA;
+ if (sc->sc_callback->ucom_start_read) {
+ (sc->sc_callback->ucom_start_read) (sc);
+ if (sc->sc_callback->ucom_start_write) {
+ (sc->sc_callback->ucom_start_write) (sc);
+static void
+ucom_start_transfers(struct ucom_softc *sc)
+ return;
+ * Make sure that data transfers are started in both
+ * directions:
+static void
+ucom_cfg_open(struct usb_proc_msg *_task)
+ DPRINTF("\n");
+ if (sc->sc_flag & UCOM_FLAG_LL_READY) {
+ /* already opened */
+ } else {
+ sc->sc_flag |= UCOM_FLAG_LL_READY;
+ if (sc->sc_callback->ucom_cfg_open) {
+ (sc->sc_callback->ucom_cfg_open) (sc);
+ /* wait a little */
+ usb_pause_mtx(sc->sc_mtx, hz / 10);
+static int
+ucom_open(struct tty *tp)
+ struct ucom_softc *sc = tty_softc(tp);
+ int error;
+ if (sc->sc_flag & UCOM_FLAG_GONE) {
+ return (ENXIO);
+ if (sc->sc_flag & UCOM_FLAG_HL_READY) {
+ return (0);
+ DPRINTF("tp = %p\n", tp);
+ if (sc->sc_callback->ucom_pre_open) {
+ * give the lower layer a chance to disallow TTY open, for
+ * example if the device is not present:
+ error = (sc->sc_callback->ucom_pre_open) (sc);
+ if (error) {
+ return (error);
+ sc->sc_flag |= UCOM_FLAG_HL_READY;
+ /* Disable transfers */
+ sc->sc_flag &= ~UCOM_FLAG_GP_DATA;
+ sc->sc_lsr = 0;
+ sc->sc_msr = 0;
+ sc->sc_mcr = 0;
+ /* reset programmed line state */
+ sc->sc_pls_curr = 0;
+ sc->sc_pls_set = 0;
+ sc->sc_pls_clr = 0;
+ /* reset jitter buffer */
+ sc->sc_jitterbuf_in = 0;
+ sc->sc_jitterbuf_out = 0;
+ ucom_queue_command(sc, ucom_cfg_open, NULL,
+ &sc->sc_open_task[0].hdr,
+ &sc->sc_open_task[1].hdr);
+ /* Queue transfer enable command last */
+ ucom_queue_command(sc, ucom_cfg_start_transfers, NULL,
+ &sc->sc_start_task[0].hdr,
+ &sc->sc_start_task[1].hdr);
+ ucom_modem(tp, SER_DTR | SER_RTS, 0);
+ ucom_ring(sc, 0);
+ ucom_break(sc, 0);
+ ucom_status_change(sc);
+ return (0);
+static void
+ucom_cfg_close(struct usb_proc_msg *_task)
+ DPRINTF("\n");
+ sc->sc_flag &= ~UCOM_FLAG_LL_READY;
+ if (sc->sc_callback->ucom_cfg_close)
+ (sc->sc_callback->ucom_cfg_close) (sc);
+ } else {
+ /* already closed */
+static void
+ucom_close(struct tty *tp)
+ DPRINTF("tp=%p\n", tp);
+ DPRINTF("tp=%p already closed\n", tp);
+ return;
+ ucom_shutdown(sc);
+ ucom_queue_command(sc, ucom_cfg_close, NULL,
+ &sc->sc_close_task[0].hdr,
+ &sc->sc_close_task[1].hdr);
+ sc->sc_flag &= ~(UCOM_FLAG_HL_READY | UCOM_FLAG_RTS_IFLOW);
+ if (sc->sc_callback->ucom_stop_read) {
+static void
+ucom_inwakeup(struct tty *tp)
+ uint16_t pos;
+ if (sc == NULL)
+ return;
+ if (ttydisc_can_bypass(tp) != 0 ||
+ (sc->sc_flag & UCOM_FLAG_HL_READY) == 0 ||
+ (sc->sc_flag & UCOM_FLAG_INWAKEUP) != 0) {
+ return;
+ /* prevent recursion */
+ sc->sc_flag |= UCOM_FLAG_INWAKEUP;
+ pos = sc->sc_jitterbuf_out;
+ while (sc->sc_jitterbuf_in != pos) {
+ int c;
+ c = (char)sc->sc_jitterbuf[pos];
+ if (ttydisc_rint(tp, c, 0) == -1)
+ break;
+ pos++;
+ if (pos >= UCOM_JITTERBUF_SIZE)
+ pos -= UCOM_JITTERBUF_SIZE;
+ sc->sc_jitterbuf_out = pos;
+ /* clear RTS in async fashion */
+ if ((sc->sc_jitterbuf_in == pos) &&
+ (sc->sc_flag & UCOM_FLAG_RTS_IFLOW))
+ ucom_rts(sc, 0);
+ sc->sc_flag &= ~UCOM_FLAG_INWAKEUP;
+static int
+ucom_ioctl(struct tty *tp, u_long cmd, caddr_t data, struct thread *td)
+ int error;
+ return (EIO);
+ DPRINTF("cmd = 0x%08lx\n", cmd);
+ switch (cmd) {
+#if 0
+ case TIOCSRING:
+ ucom_ring(sc, 1);
+ error = 0;
+ break;
+ case TIOCCRING:
+ ucom_ring(sc, 0);
+ error = 0;
+ break;
+#endif
+ case TIOCSBRK:
+ ucom_break(sc, 1);
+ error = 0;
+ break;
+ case TIOCCBRK:
+ error = 0;
+ break;
+ default:
+ if (sc->sc_callback->ucom_ioctl) {
+ error = (sc->sc_callback->ucom_ioctl)
+ (sc, cmd, data, 0, td);
+ } else {
+ error = ENOIOCTL;
+ if (error == ENOIOCTL)
+ error = pps_ioctl(cmd, data, &sc->sc_pps);
+ break;
+ return (error);
+static int
+ucom_modem(struct tty *tp, int sigon, int sigoff)
+ uint8_t onoff;
+ return (0);
+ if ((sigon == 0) && (sigoff == 0)) {
+ if (sc->sc_mcr & SER_DTR) {
+ sigon |= SER_DTR;
+ if (sc->sc_mcr & SER_RTS) {
+ sigon |= SER_RTS;
+ if (sc->sc_msr & SER_CTS) {
+ sigon |= SER_CTS;
+ if (sc->sc_msr & SER_DCD) {
+ sigon |= SER_DCD;
+ if (sc->sc_msr & SER_DSR) {
+ sigon |= SER_DSR;
+ if (sc->sc_msr & SER_RI) {
+ sigon |= SER_RI;
+ return (sigon);
+ if (sigon & SER_DTR) {
+ sc->sc_mcr |= SER_DTR;
+ if (sigoff & SER_DTR) {
+ sc->sc_mcr &= ~SER_DTR;
+ if (sigon & SER_RTS) {
+ sc->sc_mcr |= SER_RTS;
+ if (sigoff & SER_RTS) {
+ sc->sc_mcr &= ~SER_RTS;
+ onoff = (sc->sc_mcr & SER_DTR) ? 1 : 0;
+ ucom_dtr(sc, onoff);
+ onoff = (sc->sc_mcr & SER_RTS) ? 1 : 0;
+ ucom_rts(sc, onoff);
+ return (0);
+static void
+ucom_cfg_line_state(struct usb_proc_msg *_task)
+ uint8_t notch_bits;
+ uint8_t any_bits;
+ uint8_t prev_value;
+ uint8_t last_value;
+ uint8_t mask;
+ return;
+ mask = 0;
+ /* compute callback mask */
+ if (sc->sc_callback->ucom_cfg_set_dtr)
+ mask |= UCOM_LS_DTR;
+ if (sc->sc_callback->ucom_cfg_set_rts)
+ mask |= UCOM_LS_RTS;
+ if (sc->sc_callback->ucom_cfg_set_break)
+ mask |= UCOM_LS_BREAK;
+ if (sc->sc_callback->ucom_cfg_set_ring)
+ mask |= UCOM_LS_RING;
+ /* compute the bits we are to program */
+ notch_bits = (sc->sc_pls_set & sc->sc_pls_clr) & mask;
+ any_bits = (sc->sc_pls_set | sc->sc_pls_clr) & mask;
+ prev_value = sc->sc_pls_curr ^ notch_bits;
+ last_value = sc->sc_pls_curr;
+ /* ensure that we don't lose any levels */
+ if (notch_bits & UCOM_LS_DTR)
+ sc->sc_callback->ucom_cfg_set_dtr(sc,
+ (prev_value & UCOM_LS_DTR) ? 1 : 0);
+ if (notch_bits & UCOM_LS_RTS)
+ sc->sc_callback->ucom_cfg_set_rts(sc,
+ (prev_value & UCOM_LS_RTS) ? 1 : 0);
+ if (notch_bits & UCOM_LS_BREAK)
+ sc->sc_callback->ucom_cfg_set_break(sc,
+ (prev_value & UCOM_LS_BREAK) ? 1 : 0);
+ if (notch_bits & UCOM_LS_RING)
+ sc->sc_callback->ucom_cfg_set_ring(sc,
+ (prev_value & UCOM_LS_RING) ? 1 : 0);
+ /* set last value */
+ if (any_bits & UCOM_LS_DTR)
+ (last_value & UCOM_LS_DTR) ? 1 : 0);
+ if (any_bits & UCOM_LS_RTS)
+ (last_value & UCOM_LS_RTS) ? 1 : 0);
+ if (any_bits & UCOM_LS_BREAK)
+ (last_value & UCOM_LS_BREAK) ? 1 : 0);
+ if (any_bits & UCOM_LS_RING)
+ (last_value & UCOM_LS_RING) ? 1 : 0);
+static void
+ucom_line_state(struct ucom_softc *sc,
+ uint8_t set_bits, uint8_t clear_bits)
+ return;
+ DPRINTF("on=0x%02x, off=0x%02x\n", set_bits, clear_bits);
+ /* update current programmed line state */
+ sc->sc_pls_curr |= set_bits;
+ sc->sc_pls_curr &= ~clear_bits;
+ sc->sc_pls_set |= set_bits;
+ sc->sc_pls_clr |= clear_bits;
+ /* defer driver programming */
+ ucom_queue_command(sc, ucom_cfg_line_state, NULL,
+ &sc->sc_line_state_task[0].hdr,
+ &sc->sc_line_state_task[1].hdr);
+static void
+ucom_ring(struct ucom_softc *sc, uint8_t onoff)
+ if (onoff)
+ ucom_line_state(sc, UCOM_LS_RING, 0);
+ else
+ ucom_line_state(sc, 0, UCOM_LS_RING);
+static void
+ucom_break(struct ucom_softc *sc, uint8_t onoff)
+ if (onoff)
+ ucom_line_state(sc, UCOM_LS_BREAK, 0);
+ else
+ ucom_line_state(sc, 0, UCOM_LS_BREAK);
+static void
+ucom_dtr(struct ucom_softc *sc, uint8_t onoff)
+ if (onoff)
+ ucom_line_state(sc, UCOM_LS_DTR, 0);
+ else
+ ucom_line_state(sc, 0, UCOM_LS_DTR);
+static void
+ucom_rts(struct ucom_softc *sc, uint8_t onoff)
+ if (onoff)
+ ucom_line_state(sc, UCOM_LS_RTS, 0);
+ else
+ ucom_line_state(sc, 0, UCOM_LS_RTS);
+static void
+ucom_cfg_status_change(struct usb_proc_msg *_task)
+ struct tty *tp;
+ int onoff;
+ uint8_t new_msr;
+ uint8_t new_lsr;
+ uint8_t msr_delta;
+ uint8_t lsr_delta;
+ uint8_t pps_signal;
+ tp = sc->sc_tty;
+ return;
+ if (sc->sc_callback->ucom_cfg_get_status == NULL) {
+ return;
+ /* get status */
+ new_msr = 0;
+ new_lsr = 0;
+ (sc->sc_callback->ucom_cfg_get_status) (sc, &new_lsr, &new_msr);
+ return;
+ msr_delta = (sc->sc_msr ^ new_msr);
+ lsr_delta = (sc->sc_lsr ^ new_lsr);
+ sc->sc_msr = new_msr;
+ sc->sc_lsr = new_lsr;
+ * Time pulse counting support.
+ switch(ucom_pps_mode & UART_PPS_SIGNAL_MASK) {
+ case UART_PPS_CTS:
+ pps_signal = SER_CTS;
+ break;
+ case UART_PPS_DCD:
+ pps_signal = SER_DCD;
+ break;
+ default:
+ pps_signal = 0;
+ break;
+ if ((sc->sc_pps.ppsparam.mode & PPS_CAPTUREBOTH) &&
+ (msr_delta & pps_signal)) {
+ pps_capture(&sc->sc_pps);
+ onoff = (sc->sc_msr & pps_signal) ? 1 : 0;
+ if (ucom_pps_mode & UART_PPS_INVERT_PULSE)
+ onoff = !onoff;
+ pps_event(&sc->sc_pps, onoff ? PPS_CAPTUREASSERT :
+ PPS_CAPTURECLEAR);
+ if (msr_delta & SER_DCD) {
+ onoff = (sc->sc_msr & SER_DCD) ? 1 : 0;
+ DPRINTF("DCD changed to %d\n", onoff);
+ ttydisc_modem(tp, onoff);
+ if ((lsr_delta & ULSR_BI) && (sc->sc_lsr & ULSR_BI)) {
+ DPRINTF("BREAK detected\n");
+ ttydisc_rint(tp, 0, TRE_BREAK);
+ ttydisc_rint_done(tp);
+ if ((lsr_delta & ULSR_FE) && (sc->sc_lsr & ULSR_FE)) {
+ DPRINTF("Frame error detected\n");
+ ttydisc_rint(tp, 0, TRE_FRAMING);
+ if ((lsr_delta & ULSR_PE) && (sc->sc_lsr & ULSR_PE)) {
+ DPRINTF("Parity error detected\n");
+ ttydisc_rint(tp, 0, TRE_PARITY);
+void
+ucom_status_change(struct ucom_softc *sc)
+ return; /* not supported */
+ return;
+ DPRINTF("\n");
+ ucom_queue_command(sc, ucom_cfg_status_change, NULL,
+ &sc->sc_status_task[0].hdr,
+ &sc->sc_status_task[1].hdr);
+static void
+ucom_cfg_param(struct usb_proc_msg *_task)
+ struct ucom_param_task *task =
+ (struct ucom_param_task *)_task;
+ return;
+ if (sc->sc_callback->ucom_cfg_param == NULL) {
+ return;
+ (sc->sc_callback->ucom_cfg_param) (sc, &task->termios_copy);
+static int
+ucom_param(struct tty *tp, struct termios *t)
+ uint8_t opened;
+ int error;
+ opened = 0;
+ error = 0;
+ /* XXX the TTY layer should call "open()" first! */
+ * Not quite: Its ordering is partly backwards, but
+ * some parameters must be set early in ttydev_open(),
+ * possibly before calling ttydevsw_open().
+ error = ucom_open(tp);
+ if (error)
+ goto done;
+ opened = 1;
+ /* Check requested parameters. */
+ if (t->c_ispeed && (t->c_ispeed != t->c_ospeed)) {
+ /* XXX c_ospeed == 0 is perfectly valid. */
+ DPRINTF("mismatch ispeed and ospeed\n");
+ error = EINVAL;
+ goto done;
+ t->c_ispeed = t->c_ospeed;
+ if (sc->sc_callback->ucom_pre_param) {
+ /* Let the lower layer verify the parameters */
+ error = (sc->sc_callback->ucom_pre_param) (sc, t);
+ if (error) {
+ DPRINTF("callback error = %d\n", error);
+ goto done;
+ /* Queue baud rate programming command first */
+ ucom_queue_command(sc, ucom_cfg_param, t,
+ &sc->sc_param_task[0].hdr,
+ &sc->sc_param_task[1].hdr);
+ if (t->c_cflag & CRTS_IFLOW) {
+ sc->sc_flag |= UCOM_FLAG_RTS_IFLOW;
+ } else if (sc->sc_flag & UCOM_FLAG_RTS_IFLOW) {
+ sc->sc_flag &= ~UCOM_FLAG_RTS_IFLOW;
+ ucom_modem(tp, SER_RTS, 0);
+done:
+ if (error) {
+ if (opened) {
+ ucom_close(tp);
+ return (error);
+static void
+ucom_outwakeup(struct tty *tp)
+ /* The higher layer is not ready */
+ return;
+ ucom_start_transfers(sc);
+ * ucom_get_data
+ * Return values:
+ * 0: No data is available.
+ * Else: Data is available.
+uint8_t
+ucom_get_data(struct ucom_softc *sc, struct usb_page_cache *pc,
+ uint32_t offset, uint32_t len, uint32_t *actlen)
+ struct usb_page_search res;
+ uint32_t cnt;
+ uint32_t offset_orig;
+ unsigned int temp;
+ /* get total TX length */
+ temp = ucom_cons_tx_high - ucom_cons_tx_low;
+ temp %= UCOM_CONS_BUFSIZE;
+ /* limit TX length */
+ if (temp > (UCOM_CONS_BUFSIZE - ucom_cons_tx_low))
+ temp = (UCOM_CONS_BUFSIZE - ucom_cons_tx_low);
+ if (temp > len)
+ temp = len;
+ /* copy in data */
+ usbd_copy_in(pc, offset, ucom_cons_tx_buf + ucom_cons_tx_low, temp);
+ /* update counters */
+ ucom_cons_tx_low += temp;
+ ucom_cons_tx_low %= UCOM_CONS_BUFSIZE;
+ /* store actual length */
+ *actlen = temp;
+ return (temp ? 1 : 0);
+ if (tty_gone(tp) ||
+ !(sc->sc_flag & UCOM_FLAG_GP_DATA)) {
+ actlen[0] = 0;
+ return (0); /* multiport device polling */
+ offset_orig = offset;
+ while (len != 0) {
+ usbd_get_page(pc, offset, &res);
+ if (res.length > len) {
+ res.length = len;
+ /* copy data directly into USB buffer */
+ cnt = ttydisc_getc(tp, res.buffer, res.length);
+ offset += cnt;
+ len -= cnt;
+ if (cnt < res.length) {
+ /* end of buffer */
+ break;
+ actlen[0] = offset - offset_orig;
+ DPRINTF("cnt=%d\n", actlen[0]);
+ if (actlen[0] == 0) {
+ return (0);
+ return (1);
+void
+ucom_put_data(struct ucom_softc *sc, struct usb_page_cache *pc,
+ uint32_t offset, uint32_t len)
+ char *buf;
+ uint32_t cnt;
+ /* get maximum RX length */
+ temp = (UCOM_CONS_BUFSIZE - 1) - ucom_cons_rx_high + ucom_cons_rx_low;
+ /* limit RX length */
+ if (temp > (UCOM_CONS_BUFSIZE - ucom_cons_rx_high))
+ temp = (UCOM_CONS_BUFSIZE - ucom_cons_rx_high);
+ if (temp > len)
+ temp = len;
+ /* copy out data */
+ usbd_copy_out(pc, offset, ucom_cons_rx_buf + ucom_cons_rx_high, temp);
+ ucom_cons_rx_high += temp;
+ ucom_cons_rx_high %= UCOM_CONS_BUFSIZE;
+ return;
+ if (tty_gone(tp))
+ return; /* multiport device polling */
+ if (len == 0)
+ return; /* no data */
+ /* set a flag to prevent recursation ? */
+ while (len > 0) {
+ res.length = len;
+ len -= res.length;
+ offset += res.length;
+ /* pass characters to tty layer */
+ buf = res.buffer;
+ cnt = res.length;
+ /* first check if we can pass the buffer directly */
+ if (ttydisc_can_bypass(tp)) {
+ /* clear any jitter buffer */
+ if (ttydisc_rint_bypass(tp, buf, cnt) != cnt) {
+ DPRINTF("tp=%p, data lost\n", tp);
+ continue;
+ /* need to loop */
+ for (cnt = 0; cnt != res.length; cnt++) {
+ if (sc->sc_jitterbuf_in != sc->sc_jitterbuf_out ||
+ ttydisc_rint(tp, buf[cnt], 0) == -1) {
+ uint16_t end;
+ uint16_t pos;
+ pos = sc->sc_jitterbuf_in;
+ end = sc->sc_jitterbuf_out +
+ UCOM_JITTERBUF_SIZE - 1;
+ if (end >= UCOM_JITTERBUF_SIZE)
+ end -= UCOM_JITTERBUF_SIZE;
+ for (; cnt != res.length; cnt++) {
+ if (pos == end)
+ break;
+ sc->sc_jitterbuf[pos] = buf[cnt];
+ pos++;
+ sc->sc_jitterbuf_in = pos;
+ /* set RTS in async fashion */
+ if (sc->sc_flag & UCOM_FLAG_RTS_IFLOW)
+ ucom_rts(sc, 1);
+ DPRINTF("tp=%p, lost %d "
+ "chars\n", tp, res.length - cnt);
+ break;
+static void
+ucom_free(void *xsc)
+ struct ucom_softc *sc = xsc;
+ if (sc->sc_callback->ucom_free != NULL)
+ sc->sc_callback->ucom_free(sc);
+ else
+ ucom_unref(sc->sc_super);
+ ucom_close_refs--;
+static cn_probe_t ucom_cnprobe;
+static cn_init_t ucom_cninit;
+static cn_term_t ucom_cnterm;
+static cn_getc_t ucom_cngetc;
+static cn_putc_t ucom_cnputc;
+static cn_grab_t ucom_cngrab;
+static cn_ungrab_t ucom_cnungrab;
+CONSOLE_DRIVER(ucom);
+static void
+ucom_cnprobe(struct consdev *cp)
+ if (ucom_cons_unit != -1)
+ cp->cn_pri = CN_NORMAL;
+ else
+ cp->cn_pri = CN_DEAD;
+ strlcpy(cp->cn_name, "ucom", sizeof(cp->cn_name));
+static void
+ucom_cninit(struct consdev *cp)
+static void
+ucom_cnterm(struct consdev *cp)
+static void
+ucom_cngrab(struct consdev *cp)
+static void
+ucom_cnungrab(struct consdev *cp)
+static int
+ucom_cngetc(struct consdev *cd)
+ struct ucom_softc *sc = ucom_cons_softc;
+ int c;
+ if (sc == NULL)
+ return (-1);
+ if (ucom_cons_rx_low != ucom_cons_rx_high) {
+ c = ucom_cons_rx_buf[ucom_cons_rx_low];
+ ucom_cons_rx_low ++;
+ ucom_cons_rx_low %= UCOM_CONS_BUFSIZE;
+ } else {
+ c = -1;
+ /* start USB transfers */
+ ucom_outwakeup(sc->sc_tty);
+ /* poll if necessary */
+ if (USB_IN_POLLING_MODE_FUNC() && sc->sc_callback->ucom_poll)
+ (sc->sc_callback->ucom_poll) (sc);
+ return (c);
+static void
+ucom_cnputc(struct consdev *cd, int c)
+ if (sc == NULL)
+ return;
+ repeat:
+ /* compute maximum TX length */
+ temp = (UCOM_CONS_BUFSIZE - 1) - ucom_cons_tx_high + ucom_cons_tx_low;
+ if (temp) {
+ ucom_cons_tx_buf[ucom_cons_tx_high] = c;
+ ucom_cons_tx_high ++;
+ ucom_cons_tx_high %= UCOM_CONS_BUFSIZE;
+ if (USB_IN_POLLING_MODE_FUNC() && sc->sc_callback->ucom_poll) {
+ /* simple flow control */
+ if (temp == 0)
+ goto repeat;
+ * ucom_ref
+ * This function will increment the super UCOM reference count.
+void
+ucom_ref(struct ucom_super_softc *ssc)
+ ssc->sc_refs++;
+ * ucom_free_unit
+ * This function will free the super UCOM's allocated unit
+ * number. This function can be called on a zero-initialized
+ * structure. This function can be called multiple times.
+static void
+ucom_free_unit(struct ucom_super_softc *ssc)
+ if (!(ssc->sc_flag & UCOM_FLAG_FREE_UNIT))
+ return;
+ ssc->sc_flag &= ~UCOM_FLAG_FREE_UNIT;
+ * ucom_unref
+ * This function will decrement the super UCOM reference count.
+ * Return values:
+ * 0: UCOM structures are still referenced.
+ * Else: UCOM structures are no longer referenced.
+int
+ucom_unref(struct ucom_super_softc *ssc)
+ int retval;
+ retval = (ssc->sc_refs < 2);
+ ssc->sc_refs--;
+ if (retval)
+ ucom_free_unit(ssc);
+ return (retval);
+#if defined(GDB)
+#include <gdb/gdb.h>
+static gdb_probe_f ucom_gdbprobe;
+static gdb_init_f ucom_gdbinit;
+static gdb_term_f ucom_gdbterm;
+static gdb_getc_f ucom_gdbgetc;
+static gdb_putc_f ucom_gdbputc;
+GDB_DBGPORT(sio, ucom_gdbprobe, ucom_gdbinit, ucom_gdbterm, ucom_gdbgetc, ucom_gdbputc);
+static int
+ucom_gdbprobe(void)
+ return ((ucom_cons_softc != NULL) ? 0 : -1);
+static void
+ucom_gdbinit(void)
+static void
+ucom_gdbterm(void)
+static void
+ucom_gdbputc(int c)
+ ucom_cnputc(NULL, c);
+static int
+ucom_gdbgetc(void)
+ return (ucom_cngetc(NULL));
+#endif
diff --git a/freebsd/sys/dev/usb/serial/usb_serial.h b/freebsd/sys/dev/usb/serial/usb_serial.h
index 0000000..9fbd373
--- /dev/null
+++ b/freebsd/sys/dev/usb/serial/usb_serial.h
@@ -0,0 +1,221 @@
+/* $NetBSD: ucomvar.h,v 1.9 2001/01/23 21:56:17 augustss Exp $ */
+/* $FreeBSD$ */
+ * Copyright (c) 2001-2002, Shunsuke Akiyama <akiyama at jp.FreeBSD.org>.
+ * are met:
+ * SUCH DAMAGE.
+ * Copyright (c) 1999 The NetBSD Foundation, Inc.
+ * are met:
+#ifndef _USB_SERIAL_H_
+#define _USB_SERIAL_H_
+#include <sys/tty.h>
+#include <sys/serial.h>
+#include <sys/fcntl.h>
+#include <sys/timepps.h>
+/* Module interface related macros */
+#define UCOM_MODVER 1
+#define UCOM_MINVER 1
+#define UCOM_PREFVER UCOM_MODVER
+#define UCOM_MAXVER 1
+#define UCOM_JITTERBUF_SIZE 128 /* bytes */
+struct usb_device;
+struct ucom_softc;
+struct usb_device_request;
+struct thread;
+ * NOTE: There is no guarantee that "ucom_cfg_close()" will
+ * be called after "ucom_cfg_open()" if the device is detached
+ * while it is open!
+struct ucom_callback {
+ void (*ucom_cfg_get_status) (struct ucom_softc *, uint8_t *plsr, uint8_t *pmsr);
+ void (*ucom_cfg_set_dtr) (struct ucom_softc *, uint8_t);
+ void (*ucom_cfg_set_rts) (struct ucom_softc *, uint8_t);
+ void (*ucom_cfg_set_break) (struct ucom_softc *, uint8_t);
+ void (*ucom_cfg_set_ring) (struct ucom_softc *, uint8_t);
+ void (*ucom_cfg_param) (struct ucom_softc *, struct termios *);
+ void (*ucom_cfg_open) (struct ucom_softc *);
+ void (*ucom_cfg_close) (struct ucom_softc *);
+ int (*ucom_pre_open) (struct ucom_softc *);
+ int (*ucom_pre_param) (struct ucom_softc *, struct termios *);
+ int (*ucom_ioctl) (struct ucom_softc *, uint32_t, caddr_t, int, struct thread *);
+ void (*ucom_start_read) (struct ucom_softc *);
+ void (*ucom_stop_read) (struct ucom_softc *);
+ void (*ucom_start_write) (struct ucom_softc *);
+ void (*ucom_stop_write) (struct ucom_softc *);
+ void (*ucom_tty_name) (struct ucom_softc *, char *pbuf, uint16_t buflen, uint16_t unit, uint16_t subunit);
+ void (*ucom_poll) (struct ucom_softc *);
+ void (*ucom_free) (struct ucom_softc *);
+/* Line status register */
+#define ULSR_RCV_FIFO 0x80
+#define ULSR_TSRE 0x40 /* Transmitter empty: byte sent */
+#define ULSR_TXRDY 0x20 /* Transmitter buffer empty */
+#define ULSR_BI 0x10 /* Break detected */
+#define ULSR_FE 0x08 /* Framing error: bad stop bit */
+#define ULSR_PE 0x04 /* Parity error */
+#define ULSR_OE 0x02 /* Overrun, lost incoming byte */
+#define ULSR_RXRDY 0x01 /* Byte ready in Receive Buffer */
+#define ULSR_RCV_MASK 0x1f /* Mask for incoming data or error */
+struct ucom_cfg_task {
+ struct usb_proc_msg hdr;
+ struct ucom_softc *sc;
+struct ucom_param_task {
+ struct termios termios_copy;
+struct ucom_super_softc {
+ struct usb_process sc_tq;
+ int sc_unit;
+ int sc_subunits;
+ int sc_refs;
+ int sc_flag; /* see UCOM_FLAG_XXX */
+ struct sysctl_oid *sc_sysctl_ttyname;
+ struct sysctl_oid *sc_sysctl_ttyports;
+ char sc_ttyname[16];
+struct ucom_softc {
+ * NOTE: To avoid losing level change information we use two
+ * tasks instead of one for all commands.
+ * Level changes are transitions like:
+ * ON->OFF
+ * OFF->ON
+ * OPEN->CLOSE
+ * CLOSE->OPEN
+ struct ucom_cfg_task sc_start_task[2];
+ struct ucom_cfg_task sc_open_task[2];
+ struct ucom_cfg_task sc_close_task[2];
+ struct ucom_cfg_task sc_line_state_task[2];
+ struct ucom_cfg_task sc_status_task[2];
+ struct ucom_param_task sc_param_task[2];
+ /* pulse capturing support, PPS */
+ struct pps_state sc_pps;
+ /* Used to set "UCOM_FLAG_GP_DATA" flag: */
+ struct usb_proc_msg *sc_last_start_xfer;
+ const struct ucom_callback *sc_callback;
+ struct ucom_super_softc *sc_super;
+ struct tty *sc_tty;
+ struct mtx *sc_mtx;
+ void *sc_parent;
+ int sc_subunit;
+ uint16_t sc_jitterbuf_in;
+ uint16_t sc_jitterbuf_out;
+ uint16_t sc_portno;
+ uint16_t sc_flag;
+#define UCOM_FLAG_RTS_IFLOW 0x01 /* use RTS input flow control */
+#define UCOM_FLAG_GONE 0x02 /* the device is gone */
+#define UCOM_FLAG_ATTACHED 0x04 /* set if attached */
+#define UCOM_FLAG_GP_DATA 0x08 /* set if get and put data is possible */
+#define UCOM_FLAG_LL_READY 0x20 /* set if low layer is ready */
+#define UCOM_FLAG_HL_READY 0x40 /* set if high layer is ready */
+#define UCOM_FLAG_CONSOLE 0x80 /* set if device is a console */
+#define UCOM_FLAG_WAIT_REFS 0x0100 /* set if we must wait for refs */
+#define UCOM_FLAG_FREE_UNIT 0x0200 /* set if we must free the unit */
+#define UCOM_FLAG_INWAKEUP 0x0400 /* set if we are in the tsw_inwakeup callback */
+ uint8_t sc_lsr;
+ uint8_t sc_msr;
+ uint8_t sc_mcr;
+ /* programmed line state bits */
+ uint8_t sc_pls_set; /* set bits */
+ uint8_t sc_pls_clr; /* cleared bits */
+ uint8_t sc_pls_curr; /* last state */
+#define UCOM_LS_DTR 0x01
+#define UCOM_LS_RTS 0x02
+#define UCOM_LS_BREAK 0x04
+#define UCOM_LS_RING 0x08
+ uint8_t sc_jitterbuf[UCOM_JITTERBUF_SIZE];
+#define UCOM_MTX_ASSERT(sc, what) USB_MTX_ASSERT((sc)->sc_mtx, what)
+#define UCOM_MTX_LOCK(sc) USB_MTX_LOCK((sc)->sc_mtx)
+#define UCOM_MTX_UNLOCK(sc) USB_MTX_UNLOCK((sc)->sc_mtx)
+#define UCOM_UNLOAD_DRAIN(x) \
+SYSUNINIT(var, SI_SUB_KLD - 2, SI_ORDER_ANY, ucom_drain_all, 0)
+#define ucom_cfg_do_request(udev,com,req,ptr,flags,timo) \
+ usbd_do_request_proc(udev,&(com)->sc_super->sc_tq,req,ptr,flags,NULL,timo)
+int ucom_attach(struct ucom_super_softc *,
+ struct ucom_softc *, int, void *,
+ const struct ucom_callback *callback, struct mtx *);
+void ucom_detach(struct ucom_super_softc *, struct ucom_softc *);
+void ucom_set_pnpinfo_usb(struct ucom_super_softc *, device_t);
+void ucom_status_change(struct ucom_softc *);
+uint8_t ucom_get_data(struct ucom_softc *, struct usb_page_cache *,
+ uint32_t, uint32_t, uint32_t *);
+void ucom_put_data(struct ucom_softc *, struct usb_page_cache *,
+ uint32_t, uint32_t);
+uint8_t ucom_cfg_is_gone(struct ucom_softc *);
+void ucom_drain(struct ucom_super_softc *);
+void ucom_drain_all(void *);
+void ucom_ref(struct ucom_super_softc *);
+int ucom_unref(struct ucom_super_softc *);
+#endif /* _USB_SERIAL_H_ */
1.9.1
