[PATCH 6/9] Adding USB serial driver test cases
Thu Feb 9 03:35:28 UTC 2017
On 09/02/2017 14:21, Kevin Kirspel wrote:
>  .../include/rtems/bsd/test/default-usb-init.h      | 158 +++++
>  testsuite/usbserial/init.c                         | 373 ++++++++++++
>  testsuite/usbserial01/test_main.c                  | 666 +++++++++++++++++++++
>  testsuite/usbserial02/test_main.c                  | 252 ++++++++
>  testsuite/usbserial03/test_main.c                  | 240 ++++++++
>  testsuite/usbserial04/test_main.c                  | 226 +++++++
>  testsuite/usbserial05/test_main.c                  | 303 ++++++++++
>  testsuite/usbserial06/test_main.c                  | 218 +++++++
>  8 files changed, 2436 insertions(+)
>  create mode 100755 testsuite/include/rtems/bsd/test/default-usb-init.h
>  create mode 100755 testsuite/usbserial/init.c
>  create mode 100755 testsuite/usbserial01/test_main.c
>  create mode 100755 testsuite/usbserial02/test_main.c
>  create mode 100755 testsuite/usbserial03/test_main.c
>  create mode 100755 testsuite/usbserial04/test_main.c
>  create mode 100755 testsuite/usbserial05/test_main.c
>  create mode 100755 testsuite/usbserial06/test_main.c
Can the new termios support in FreeBSD be tested without needing USB
serial support? In other words, is a separate test for termios possible
and does it make sense?
My concern is the basic termios functionality being added is not tested
without having USB serial support which links both parts.
> +++ b/testsuite/usbserial/init.c
> @@ -0,0 +1,373 @@
> + * Copyright (c) 2010, 2016 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
Is this copyright ok?
I see other places in other patches where this is happening.
