[PATCH 6/9] Adding USB serial driver test cases
Thu Feb 9 20:58:03 UTC 2017
On 10/02/2017 00:09, Kirspel, Kevin wrote:
> We could probably create a tty test driver and convert usbserialXX test cases into termiosXX test cases.  This would delink the two and we would only have the one usbserial test case.
It would be good to do this.
> As far as the copyright, I can change it to whatever you want.  I based the test cases off Sebastian's test structure but I can make a generic RTEMs copyright if needed.
I cannot say without reviewing the original source and your changes so
this I feel is something you will need to handle. You can either replace
the copyright if the work in the file is all yours or you can add
yourself. If the work is yours or you have made reasonable changes a
copyright for you should be added.
