Building toolset for Beaglebone with RSB fails (for me).
Tanu Hari Dixit tokencolour at gmail.com
Fri Feb 10 20:04:09 UTC 2017
Hello Devs,
I wanted to build the toolset for Beaglebone following the blog (
http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
However, the build failed.
I got the following message.
download:
ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2 ->
sources/gcc-6-20160526.tar.bz2
download:
ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2:
error: <urlopen error ftp error: 550 pub/gcc/snapshots/6-20160526: No such
file or directory>
error: downloading
ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2: all
paths have failed, giving up
Build FAILED
  See error report:
rsb-report-arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1.txt
error: downloading
Build Set: Time 0:01:46.366099
Build FAILED
Probably, the link is broken.
It is probably using
rtems-source-builder/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
which sets this url which ultimately is used by
rtems-source-builder/source-builder/config/gcc-common-1.cfg . Please
correct me if I am wrong.
How do I fix this? Is there something I am missing?
Thanks,
Tanu Hari Dixit.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170211/5894885c/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
 Build: error: downloading ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2: all paths have failed, giving up
 Command Line: ../source-builder/sb-set-builder --log=beagle.txt --prefix=/home/thd/development/rtems/4.12 devel/beagle.bset
 Python: 2.7.6 (default, Jun 22 2015, 17:58:13) [GCC 4.8.2]
 https://github.com/bengras/rtems-source-builder.git/origin/c4db36683559bdb9facf6ea918ea1ba098aa11c6
 Linux thd-Inspiron-5537 3.19.0-68-generic #76~14.04.1-Ubuntu SMP Fri Aug 12 11:46:25 UTC 2016 x86_64
Tail of the build log:
test -z "/home/thd/development/rtems/4.12/bin" || /bin/mkdir -p "/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin"
  /bin/sh ./libtool   --mode=install /usr/bin/install -c gprof '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/./arm-rtems4.12-gprof'
libtool: install: /usr/bin/install -c gprof /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/./arm-rtems4.12-gprof
test -z "/home/thd/development/rtems/4.12/share/info" || /bin/mkdir -p "/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info"
 /usr/bin/install -c -m 644 ../../binutils-2.26/gprof/gprof.info '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info'
 install-info --info-dir='/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info' '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info/gprof.info'
This is not dpkg install-info anymore, but GNU install-info
See the man page for ginstall-info for command line arguments
test -z "/home/thd/development/rtems/4.12/share/man/man1" || /bin/mkdir -p "/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1"
 /usr/bin/install -c -m 644 '../../binutils-2.26/gprof/gprof.1' '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-gprof.1'
make[5]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/gprof'
make[4]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/gprof'
make[3]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/gprof'
make[2]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/gprof'
make[2]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/intl'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/intl'
make[2]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make  install-recursive
make[3]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
Making install in po
make[4]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld/po'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld/po'
make[4]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make[5]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
  /bin/sh ./libtool   --mode=install /usr/bin/install -c ld-new '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/./arm-rtems4.12-ld.bfd'
libtool: install: /usr/bin/install -c ld-new /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/./arm-rtems4.12-ld.bfd
/bin/sh ../../binutils-2.26/ld/../mkinstalldirs /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin
n=`echo ld.bfd | sed 's/^ld-new$/ld.bfd/;s&^&arm-rtems4.12-&'`; \
	if test "/home/thd/development/rtems/4.12/bin" != "/home/thd/development/rtems/4.12/arm-rtems4.12/bin"; then \
	  rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld.bfd; \
	  ln /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$n /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld.bfd >/dev/null 2>/dev/null \
	  ||  /bin/sh ./libtool --mode=install /usr/bin/install -c ld-new /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld.bfd; \
	fi; \
	if test "xyes" = "xyes"; then \
	  ld=`echo ld | sed 's/^ld-new$/ld.bfd/;s&^&arm-rtems4.12-&'`; \
	  rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$ld; \
	  ln /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$n /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$ld >/dev/null 2>/dev/null \
	  ||  /bin/sh ./libtool --mode=install /usr/bin/install -c ld-new /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$ld; \
	    rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld; \
	    ln /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/$n /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld >/dev/null 2>/dev/null \
	    ||  /bin/sh ./libtool --mode=install /usr/bin/install -c ld-new /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/bin/ld; \
	  fi; \
	fi
/bin/sh ../../binutils-2.26/ld/../mkinstalldirs /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/lib/ldscripts
mkdir -p -- /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/lib/ldscripts
for f in ldscripts/* ; do \
	  /usr/bin/install -c -m 644 $f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/arm-rtems4.12/lib/$f ; \
	done
 /usr/bin/install -c -m 644 ../../binutils-2.26/ld/ld.info '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info'
 install-info --info-dir='/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info' '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info/ld.info'
 /usr/bin/install -c -m 644 '../../binutils-2.26/ld/ld.1' '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-ld.1'
make[5]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make[4]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make[3]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make[2]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/ld'
make[2]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/libiberty'
make[3]: Entering directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/libiberty/testsuite'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/libiberty/testsuite'
if test -n ""; then \
		/bin/sh ../../binutils-2.26/libiberty/../mkinstalldirs /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/`/usr/bin/gcc -O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/home/thd/development/rtems/4.12/include -g -O2 -print-multi-os-directory`; \
		/usr/bin/install -c -m 644 ./libiberty.a /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/`/usr/bin/gcc -O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/home/thd/development/rtems/4.12/include -g -O2 -print-multi-os-directory`/./libiberty.an; \
		( cd /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/`/usr/bin/gcc -O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/home/thd/development/rtems/4.12/include -g -O2 -print-multi-os-directory` ; chmod 644 ./libiberty.an ;x86_64-linux-gnu-ranlib ./libiberty.an ); \
		mv -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/`/usr/bin/gcc -O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/home/thd/development/rtems/4.12/include -g -O2 -print-multi-os-directory`/./libiberty.an /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/`/usr/bin/gcc -O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/home/thd/development/rtems/4.12/include -g -O2 -print-multi-os-directory`/./libiberty.a; \
		case "" in \
		  /*)    thd=;; \
		  *)     thd=/home/thd/development/rtems/4.12/include/;; \
		esac; \
		/bin/sh ../../binutils-2.26/libiberty/../mkinstalldirs /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd${thd}; \
		for h in ../../binutils-2.26/libiberty/../include/ansidecl.h ../../binutils-2.26/libiberty/../include/demangle.h ../../binutils-2.26/libiberty/../include/dyn-string.h ../../binutils-2.26/libiberty/../include/fibheap.h ../../binutils-2.26/libiberty/../include/floatformat.h ../../binutils-2.26/libiberty/../include/hashtab.h ../../binutils-2.26/libiberty/../include/libiberty.h ../../binutils-2.26/libiberty/../include/objalloc.h ../../binutils-2.26/libiberty/../include/partition.h ../../binutils-2.26/libiberty/../include/safe-ctype.h ../../binutils-2.26/libiberty/../include/sort.h ../../binutils-2.26/libiberty/../include/splay-tree.h ../../binutils-2.26/libiberty/../include/timeval-utils.h; do \
		  /usr/bin/install -c -m 644 $h /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd${thd}; \
		done; \
	fi
make[3]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build/libiberty'
make[1]: Nothing to be done for `install-target'.
make[1]: Leaving directory `/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1/build'
+ /bin/rm -rf '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info/configure.info*'
+ /bin/rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info/dir
+ touch /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/info/dir
+ mkdir -p /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/locale
+ /bin/rm -f '/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/lib/libiberty*'
+ test '!' -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/arm-rtems4.12-dlltool
+ /bin/rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-dlltool.1
+ test '!' -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/arm-rtems4.12-nlmconv
+ /bin/rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-nlmconv.1
+ test '!' -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/arm-rtems4.12-windres
+ /bin/rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-windres.1
+ test '!' -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/bin/arm-rtems4.12-windmc
+ /bin/rm -f /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/man/man1/arm-rtems4.12-windmc.1
+ cd /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1
==> %clean:
+ echo '==> %clean:'
copy: /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd => /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset
reporting: tools/rtems-binutils-2.26-1.cfg -> arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1.txt
making dir: /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1-root-thd/home/thd/development/rtems/4.12/share/rtems/rsb
reporting: tools/rtems-binutils-2.26-1.cfg -> arm-rtems4.12-binutils-2.26-x86_64-linux-gnu-1.xml
config: tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
package: arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1
script:  1: #!/bin/sh
script:  2: # ___build_pre in as set up in defaults.py
script:  3: # Save the original path away.
script:  4: export SB_ORIG_PATH=${PATH}
script:  5: # Directories
script:  6: SB_PREFIX="/home/thd/development/rtems/4.12"
script:  7: SB_PREFIX_CLEAN=$(echo "/home/thd/development/rtems/4.12" | /bin/sed -e 's/^\///')
script:  8: SB_SOURCE_DIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/sources"
script:  9: SB_BUILD_DIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: SB_HOST_CFLAGS="-O2 -pipe "
script: 13: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 14: SB_HOST_LDFLAGS=" -L/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}/lib"
script: 15: SB_BUILD_CFLAGS="-O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_CXXFLAGS="-O2 -pipe -I/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}/include"
script: 17: SB_BUILD_LDFLAGS=" -L/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}/lib"
script: 18: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 19: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 20: SB_ARCH="x86_64"
script: 21: SB_OS="linux"
script: 22: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 23: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 24: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 25: export SB_CFLAGS SB_CXXFLAGS
script: 26: # Documentation
script: 27: SB_DOC_DIR="/home/thd/development/rtems/4.12/share/doc"
script: 28: export SB_DOC_DIR
script: 29: # Packages
script: 30: SB_PACKAGE_NAME="arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1"
script: 31: SB_PACKAGE_BUILDNAME="arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1"
script: 32: SB_PACKAGE_VERSION="6-20160526"
script: 33: SB_PACKAGE_RELEASE="1"
script: 34: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 35: # Build directories
script: 36: export SB_PREFIX
script: 37: SB_BUILD_DIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1"
script: 38: SB_BUILD_ROOT="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1-root-thd"
script: 39: SB_BUILD_ROOT_BINDIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1-root-thd/${SB_PREFIX_CLEAN}/bin"
script: 40: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 41: SB_BUILD_CXC_DIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1-cxc"
script: 42: SB_BUILD_CXC_ROOT="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1-thd-cxc"
script: 43: SB_BUILD_CXC_ROOT_BINDIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1-thd-cxc/${SB_PREFIX_CLEAN}/bin"
script: 44: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 45: SB_TMPROOT="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset"
script: 46: SB_TMPPREFIX="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}"
script: 47: SB_TMPBINDIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset/${SB_PREFIX_CLEAN}/bin"
script: 48: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 49: SB_TMPCXCROOT="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd/devel/beagle.bset"
script: 50: SB_TMPCXCPREFIX="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd-cxc/devel/beagle.bset/${SB_PREFIX_CLEAN}"
script: 51: SB_TMPCXCBINDIR="/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/tmp/sb-thd-cxc/devel/beagle.bset/${SB_PREFIX_CLEAN}/bin"
script: 52: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 53: # Extra path support
script: 54: SB_EXTRAPATH="/home/thd/development/rtems/src/rtems-source-builder-beng/source-builder"
script: 55: # The compiler flags
script: 56:
script: 57:
script: 58: export CFLAGS_FOR_TARGET
script: 59: export CXXFLAGS_FOR_TARGET
script: 60: # Set up the path. Put the CXC path first.
script: 61: if test -n "${SB_TMPBINDIR}" ; then
script: 62:  PATH="${SB_TMPBINDIR}:$PATH"
script: 63: fi
script: 64: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 65:  PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_EXTRAPATH}" ; then
script: 68:  PATH="${SB_EXTRAPATH}:$PATH"
script: 69: fi
script: 70:
script: 71:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/home/thd/development/rtems/src/rtems-source-builder-beng/rtems/build/arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1"
script: 79: echo "=> arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1:"
script: 80: echo "==> %prep:"
script: 81: build_top=$(pwd)
script: 82: gcc_source="gcc-6-20160526"
script: 83: source_dir_gcc=${gcc_source}
source setup: arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1: source gcc -q -n ${gcc_source}
making dir: /home/thd/development/rtems/src/rtems-source-builder-beng/rtems/sources
download: (full) ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2 -> sources/gcc-6-20160526.tar.bz2
download: ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2 -> sources/gcc-6-20160526.tar.bz2
download: no ssl context
download: ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2: error: <urlopen error ftp error: 550 pub/gcc/snapshots/6-20160526: No such file or directory>
