Building toolset for Beaglebone with RSB fails (for me).
Alan Cudmore
alan.cudmore at gmail.com
Fri Feb 10 20:27:32 UTC 2017
I need to do the same for the Pi. I also noticed the Pi BSP Readme is out
of date.
Joel, where would we put instructions in the Sphinx documentation for the
Pi and BB?
Alan
On Fri, Feb 10, 2017 at 3:24 PM, Joel Sherrill <joel at rtems.org> wrote:
> GCC does not keep snapshots forever. Ben's instructions and git repo must
> be behind the master at git.rtems.org. clone the repos from there, use
> the master, and I believe his instructions will work.
> Ben.. if you see this, maybe it is time to.merge some of your instructions
> into the new Sphinx documentation in a section for BB users.
> --joel
> On Feb 10, 2017 2:04 PM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
>> Hello Devs,
>> I wanted to build the toolset for Beaglebone following the blog (
>> http://www.shrike-systems.com/beagleboard-xm-beaglebone-bla
>> ck-and-everything-else-rtems-on-the-beagles.html).
>> However, the build failed.
>> I got the following message.
>> download: ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-2016052
>> 6.tar.bz2 -> sources/gcc-6-20160526.tar.bz2
>> 6.tar.bz2: error: <urlopen error ftp error: 550
>> pub/gcc/snapshots/6-20160526: No such file or directory>
>> error: downloading ftp://gcc.gnu.org/pub/gcc/snap
>> shots/6-20160526/gcc-6-20160526.tar.bz2: all paths have failed, giving up
>> Build FAILED
>> See error report: rsb-report-arm-rtems4.12-gcc-6
>> -20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1.txt
>> Build Set: Time 0:01:46.366099
>> Build FAILED
>> Probably, the link is broken.
>> It is probably using rtems-source-builder/rtems/con
>> fig/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
>> which sets this url which ultimately is used by
>> rtems-source-builder/source-builder/config/gcc-common-1.cfg . Please
>> correct me if I am wrong.
>> How do I fix this? Is there something I am missing?
>> Thanks,
>> Tanu Hari Dixit.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170210/45982e2d/attachment.html>
