Building toolset for Beaglebone with RSB fails (for me).
Fri Feb 10 21:41:37 UTC 2017
On Fri, Feb 10, 2017 at 3:27 PM, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> I need to do the same for the Pi. I also noticed the Pi BSP Readme is out of
> date.
> Joel, where would we put instructions in the Sphinx documentation for the Pi
> and BB?
See also https://devel.rtems.org/ticket/2854
> Alan
> On Fri, Feb 10, 2017 at 3:24 PM, Joel Sherrill <joel at rtems.org> wrote:
>> GCC does not keep snapshots forever. Ben's instructions and git repo must
>> be behind the master at git.rtems.org. clone the repos from there, use the
>> master, and I believe his instructions will work.
>> Ben.. if you see this, maybe it is time to.merge some of your instructions
>> into the new Sphinx documentation in a section for BB users.
>> --joel
>> On Feb 10, 2017 2:04 PM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
>>> Hello Devs,
>>> I wanted to build the toolset for Beaglebone following the blog
>>> (http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html).
>>> However, the build failed.
>>> I got the following message.
>>> download:
>>> ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2 ->
>>> sources/gcc-6-20160526.tar.bz2
>>> download:
>>> ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2:
>>> error: <urlopen error ftp error: 550 pub/gcc/snapshots/6-20160526: No such
>>> file or directory>
>>> error: downloading
>>> ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2: all
>>> paths have failed, giving up
>>> Build FAILED
>>>   See error report:
>>> rsb-report-arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1.txt
>>> error: downloading
>>> Build Set: Time 0:01:46.366099
>>> Build FAILED
>>> Probably, the link is broken.
>>> It is probably using
>>> rtems-source-builder/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
>>> which sets this url which ultimately is used by
>>> rtems-source-builder/source-builder/config/gcc-common-1.cfg . Please correct
>>> me if I am wrong.
>>> How do I fix this? Is there something I am missing?
>>> Thanks,
>>> Tanu Hari Dixit.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
