Building toolset for Beaglebone with RSB fails (for me).
Ben Gras
beng at shrike-systems.com
Sat Feb 11 03:08:15 UTC 2017
All,
I see, yes. Noted. I will try to find time for this soon but it may be a
little while.
Ben
On 02/10/2017 03:24 PM, Joel Sherrill wrote:
> GCC does not keep snapshots forever. Ben's instructions and git repo
> must be behind the master at git.rtems.org <http://git.rtems.org>.
> clone the repos from there, use the master, and I believe his
> instructions will work.
> Ben.. if you see this, maybe it is time to.merge some of your
> instructions into the new Sphinx documentation in a section for BB users.
> --joel
> On Feb 10, 2017 2:04 PM, "Tanu Hari Dixit" <tokencolour at gmail.com
> <mailto:tokencolour at gmail.com>> wrote:
> Hello Devs,
> I wanted to build the toolset for Beaglebone following the blog
> (http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>).
> However, the build failed.
> I got the following message.
> download:
> ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2
> <ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2>
> -> sources/gcc-6-20160526.tar.bz2
> download:
> <ftp://gcc.gnu.org/pub/gcc/snapshots/6-20160526/gcc-6-20160526.tar.bz2>:
> error: <urlopen error ftp error: 550 pub/gcc/snapshots/6-20160526:
> No such file or directory>
> error: downloading
> all paths have failed, giving up
> Build FAILED
> See error report:
> rsb-report-arm-rtems4.12-gcc-6-20160526-newlib-2.4.0.20160527-x86_64-linux-gnu-1.txt
> error: downloading
> Build Set: Time 0:01:46.366099
> Build FAILED
> Probably, the link is broken.
> It is probably using
> rtems-source-builder/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
> which sets this url which ultimately is used by
> rtems-source-builder/source-builder/config/gcc-common-1.cfg .
> Please correct me if I am wrong.
> How do I fix this? Is there something I am missing?
> Thanks,
> Tanu Hari Dixit.
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170210/89a1de13/attachment-0001.html>
