Problem configuring ethernet interface for NFS in rtems-libbsd
Tue Feb 14 10:21:40 UTC 2017
On 14/02/17 11:10, vivek kukreja wrote:
> Hello developers,
> I'm working on transporting application traces to host using the
> libbsd ethernet driver. I have compiled an app for
> arm/xilinx_zynq_a9_qemu and used the rtems bsd commands to setup NFS
> in the app.
> This example used to work until last year but the implementation of
> the function 'rtems_bsd_command_ifconfig' has been changed since. I'm
> getting the following error on qemu while trying to setup the ethernet
> interface:
> [zone: socket] kern.ipc.maxsockets limit reached
> [zone: udp_inpcb] kern.ipc.maxsockets limit reached
> [zone: udpcb] kern.ipc.maxsockets limit reached
I am not sure if this is really an error. Could you please send the
complete log messages.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
