[PATCH 8/9] Patching USB serial drivers and Termios for use in RTEMS
Tue Feb 14 13:33:35 UTC 2017
For imports of FreeBSD files into RTEMS or Newlib, please use the SVN
checkout to get the right $FreeBSD$ identifiers, e.g.
https://git.rtems.org/rtems/tree/cpukit/libcsupport/include/sys/event.h#n26
On 14/02/17 13:32, Kirspel, Kevin wrote:
> OK.  I want to update my RTEMS termios patch anyway to include a couple of changes that fell out of the FREEBSD USB serial test cases.
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642
> Direct: (770)-688-1642
> Fax: (770)-510-4445
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Tuesday, February 14, 2017 3:23 AM
> To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
> Subject: Re: [PATCH 8/9] Patching USB serial drivers and Termios for use in RTEMS
> We should first make the Termios API provided by RTEMS more FreeBSD
> compatible:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__devel.rtems.org_ticket_2897&d=DwIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=b-FtaO1HmjucZKZlsvK6tIij6oZHXcLVEQDsr-_9vzo&s=Lk4w_YapbZ_YpYJxpoNWtTLXIafXLa4ORXwi8DNZykw&e=
> Would you mind sending the relevant patches of this ticket to the mailing list?
> Since <termios.h> is a POSIX header file, it should go into Newlib from my point of view.
> https://urldefense.proofpoint.com/v2/url?u=https-3A__devel.rtems.org_ticket_2833&d=DwIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=b-FtaO1HmjucZKZlsvK6tIij6oZHXcLVEQDsr-_9vzo&s=QKAQ8SOYH7JdglpgNU1JgKrjx0pkXnYxgmhzNuY6mEs&e=
