leon3 on gdb simulator anyone?
Jiri Gaisler
jiri at gaisler.se
Tue Feb 14 19:42:36 UTC 2017
If you build gdb and sis through RSB, leon2 and leon3 emulation will be
provided. You should start sis with -leon2 or -leon3 to enable it. In
gdb, do 'target sim -leon3'.
You can also build gdb-7.11 separately, after applying this patch:
https://gaisler.org/gdb/gdb-7.11-sis-leon2-leon3.diff
Jiri.
On 02/14/2017 07:03 PM, Joel Sherrill wrote:
> Jiri added support and I thought it worked but not today. My 4.11 tool
> didn't even work.
> Hopefully Jiri will comment.
> On Feb 14, 2017 11:25 AM, "Cudmore, Alan P. (GSFC-5820)"
> <alan.p.cudmore at nasa.gov <mailto:alan.p.cudmore at nasa.gov>> wrote:
> I didn’t think leon3 ran on sis, just erc32.
> I can run leon3 on a patched QEMU and TSIM2.
> Alan
> *From: *devel <devel-bounces at rtems.org
> <mailto:devel-bounces at rtems.org>> on behalf of Joel Sherrill
> <joel at rtems.org <mailto:joel at rtems.org>>
> *Reply-To: *"joel at rtems.org <mailto:joel at rtems.org>"
> *Date: *Tuesday, February 14, 2017 at 12:01 PM
> *To: *"rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>"
> <devel at rtems.org <mailto:devel at rtems.org>>
> *Subject: *leon3 on gdb simulator anyone?
> Hi
> I built a new toolset today and sis in gdb doesn't run
> leon3 executables.
> Does this work for someone else or is something broken?
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170214/fe068d13/attachment.html>
