[PATCH 8/8] termios: Make write POSIX compatible
Thu Feb 23 14:45:40 UTC 2017
Currenlty only blocking read/write operations are implemented.  A
blocking write must transfer at least one character.  It should not wait
for the device for the second character and so on.
 cpukit/libcsupport/src/termios.c | 89 +++++++++++++++++++++++++---------------
 1 file changed, 56 insertions(+), 33 deletions(-)
diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
index d185398..e1bdd0b 100644
--- a/cpukit/libcsupport/src/termios.c
+++ b/cpukit/libcsupport/src/termios.c
@@ -1020,20 +1020,24 @@ startXmit (
  * Send characters to device-specific code
-static void
-doTransmit (const char *buf, size_t len, rtems_termios_tty *tty)
+static size_t
+doTransmit (const char *buf, size_t len, rtems_termios_tty *tty,
+            bool wait, bool nextWait)
   unsigned int newHead;
   rtems_termios_device_context *ctx = tty->device_context;
   rtems_interrupt_lock_context lock_context;
   rtems_status_code sc;
+  size_t todo;
   if (tty->handler.mode == TERMIOS_POLLED) {
     (*tty->handler.write)(ctx, buf, len);
-    return;
+    return len;
-  while (len) {
+  todo = len;
+  while (todo > 0) {
     size_t nToCopy;
     size_t nAvail;
@@ -1043,18 +1047,27 @@ doTransmit (const char *buf, size_t len, rtems_termios_tty *tty)
       newHead -= tty->rawOutBuf.Size;
     rtems_termios_device_lock_acquire (ctx, &lock_context);
-    while (newHead == tty->rawOutBuf.Tail) {
-      tty->rawOutBufState = rob_wait;
-      rtems_termios_device_lock_release (ctx, &lock_context);
-      sc = rtems_semaphore_obtain(
-        tty->rawOutBuf.Semaphore, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-      if (sc != RTEMS_SUCCESSFUL)
-        rtems_fatal_error_occurred (sc);
-      rtems_termios_device_lock_acquire (ctx, &lock_context);
+    if (newHead == tty->rawOutBuf.Tail) {
+      if (wait) {
+        do {
+          tty->rawOutBufState = rob_wait;
+          rtems_termios_device_lock_release (ctx, &lock_context);
+          sc = rtems_semaphore_obtain(
+            tty->rawOutBuf.Semaphore, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+          if (sc != RTEMS_SUCCESSFUL)
+            rtems_fatal_error_occurred (sc);
+          rtems_termios_device_lock_acquire (ctx, &lock_context);
+        } while (newHead == tty->rawOutBuf.Tail);
+        wait = nextWait;
+      } else {
+        return len - todo;
     /* Determine free space up to current tail or end of ring buffer */
-    nToCopy = len;
+    nToCopy = todo;
     if (tty->rawOutBuf.Tail > tty->rawOutBuf.Head) {
       /* Available space is contiguous from Head to Tail */
       nAvail = tty->rawOutBuf.Tail - tty->rawOutBuf.Head - 1;
@@ -1086,22 +1099,24 @@ doTransmit (const char *buf, size_t len, rtems_termios_tty *tty)
     buf += nToCopy;
-    len -= nToCopy;
+    todo -= nToCopy;
+  return len;
 void
 rtems_termios_puts (
   const void *_buf, size_t len, struct rtems_termios_tty *tty)
-  doTransmit (_buf, len, tty);
+  doTransmit (_buf, len, tty, true, true);
  * Handle output processing
-static void
-oproc (unsigned char c, struct rtems_termios_tty *tty)
+static bool
+oproc (unsigned char c, rtems_termios_tty *tty, bool wait)
   char buf[8];
   size_t len;
@@ -1129,7 +1144,7 @@ oproc (unsigned char c, struct rtems_termios_tty *tty)
     case '\r':
       if ((tty->termios.c_oflag & ONOCR) && (oldColumn == 0))
-        return;
+        return true;
       if (tty->termios.c_oflag & OCRNL) {
         buf[0] = '\n';
         if (tty->termios.c_oflag & ONLRET)
@@ -1170,26 +1185,34 @@ oproc (unsigned char c, struct rtems_termios_tty *tty)
   tty->column = oldColumn + columnAdj;
-  doTransmit (buf, len, tty);
+  return doTransmit (buf, len, tty, wait, true) > 0;
 static uint32_t
-rtems_termios_write_tty (struct rtems_termios_tty *tty, const char *buffer,
-  uint32_t initial_count)
+rtems_termios_write_tty (rtems_termios_tty *tty, const char *buf, uint32_t len)
   if (tty->termios.c_oflag & OPOST) {
-    uint32_t count;
+    uint32_t todo;
+    bool wait;
-    count = initial_count;
+    todo = len;
+    wait = true;
-    while (count--)
-      oproc (*buffer++, tty);
+      if (!oproc (*buf, tty, wait)) {
+        break;
+      ++buf;
+      --todo;
+      wait = false;
   } else {
-    doTransmit (buffer, initial_count, tty);
+    return doTransmit (buf, len, tty, true, false);
-  return initial_count;
 rtems_status_code
@@ -1224,10 +1247,10 @@ echo (unsigned char c, struct rtems_termios_tty *tty)
     echobuf[0] = '^';
     echobuf[1] = c ^ 0x40;
-    doTransmit (echobuf, 2, tty);
+    doTransmit (echobuf, 2, tty, true, true);
     tty->column += 2;
   } else {
-    oproc (c, tty);
+    oproc (c, tty, true);
@@ -1284,18 +1307,18 @@ erase (struct rtems_termios_tty *tty, int lineFlag)
          * Back up over the tab
         while (tty->column > col) {
-          doTransmit ("\b", 1, tty);
+          doTransmit ("\b", 1, tty, true, true);
           tty->column--;
       else {
         if (iscntrl (c) && (tty->termios.c_lflag & ECHOCTL)) {
-          doTransmit ("\b \b", 3, tty);
+          doTransmit ("\b \b", 3, tty, true, true);
           if (tty->column)
             tty->column--;
         if (!iscntrl (c) || (tty->termios.c_lflag & ECHOCTL)) {
           if (tty->column)
             tty->column--;
1.8.4.5
