[PATCH 2/8] termios: Change tty_rcvwakeup to bool
Thu Feb 23 15:40:16 UTC 2017
Just a generic note that if you are reworking most of termios, you can
also take this opportunity to make it have a consistent "RTEMS" style.
On Thu, Feb 23, 2017 at 9:45 AM, Sebastian Huber
> Optimize callout invocation check.
>  cpukit/libcsupport/include/rtems/termiostypes.h |  2 +-
>  cpukit/libcsupport/src/termios.c                | 18 +++++++++---------
>  2 files changed, 10 insertions(+), 10 deletions(-)
> diff --git a/cpukit/libcsupport/include/rtems/termiostypes.h b/cpukit/libcsupport/include/rtems/termiostypes.h
> index 2dcaa16..5240b85 100644
> --- a/cpukit/libcsupport/include/rtems/termiostypes.h
> +++ b/cpukit/libcsupport/include/rtems/termiostypes.h
> @@ -377,7 +377,7 @@ typedef struct rtems_termios_tty {
>    struct ttywakeup tty_snd;
>    struct ttywakeup tty_rcv;
> -  int              tty_rcvwakeup;
> +  bool             tty_rcvwakeup;
>     * @brief Corresponding device node.
> diff --git a/cpukit/libcsupport/src/termios.c b/cpukit/libcsupport/src/termios.c
> index f13e867..8445d23 100644
> --- a/cpukit/libcsupport/src/termios.c
> +++ b/cpukit/libcsupport/src/termios.c
> @@ -440,7 +440,7 @@ rtems_termios_open_tty(
>      tty->tty_snd.sw_arg = NULL;
>      tty->tty_rcv.sw_pfn = NULL;
>      tty->tty_rcv.sw_arg = NULL;
> -    tty->tty_rcvwakeup  = 0;
> +    tty->tty_rcvwakeup  = false;
>      tty->minor = minor;
>      tty->major = major;
> @@ -1505,7 +1505,7 @@ rtems_termios_read_tty (struct rtems_termios_tty *tty, char *buffer,
>      *buffer++ = tty->cbuf[tty->cindex++];
>      count--;
>    return initial_count - count;
> @@ -1522,7 +1522,7 @@ rtems_termios_read (void *arg)
>    if (rtems_termios_linesw[tty->t_line].l_read != NULL) {
>      sc = rtems_termios_linesw[tty->t_line].l_read(tty,args);
>      rtems_semaphore_release (tty->isem);
>      return sc;
> @@ -1571,10 +1571,10 @@ rtems_termios_enqueue_raw_characters (void *ttyp, const char *buf, int len)
>       * check to see if rcv wakeup callback was set
> -    if (( !tty->tty_rcvwakeup ) && ( tty->tty_rcv.sw_pfn != NULL )) {
> +    if (tty->tty_rcv.sw_pfn != NULL && !tty->tty_rcvwakeup) {
> +      tty->tty_rcvwakeup = true;
>        (*tty->tty_rcv.sw_pfn)(&tty->termios, tty->tty_rcv.sw_arg);
> -      tty->tty_rcvwakeup = 1;
>      return 0;
> @@ -1659,9 +1659,9 @@ rtems_termios_enqueue_raw_characters (void *ttyp, const char *buf, int len)
> @@ -1974,7 +1974,7 @@ rtems_termios_imfs_read (rtems_libio_t *iop, void *buffer, size_t count)
>      args.flags = iop->flags;
>      sc = rtems_termios_linesw[tty->t_line].l_read (tty, &args);
>      if (sc != RTEMS_SUCCESSFUL) {
> 1.8.4.5
> devel mailing list
> devel at rtems.org
