Undefined reference to `__sync_bool_compare_and_swap_4' for some Leon configurations with gfortran
Jan.Sommer at dlr.de
Tue Feb 28 14:27:07 UTC 2017
> -----Ursprüngliche Nachricht-----
> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Gesendet: Montag, 27. Februar 2017 15:25
> An: Sommer, Jan; devel at rtems.org
> Betreff: Re: AW: AW: AW: Undefined reference to
> gfortran
> >> >Gesendet: Montag, 27. Februar 2017 15:11
> >> >An: Sommer, Jan;devel at rtems.org
> >> >Betreff: Re: AW: AW: Undefined reference to
> >> >gfortran
> >> >On 27/02/17 15:08,Jan.Sommer at dlr.de wrote:
> >>> > >Ok, thanks for the clarification.
> >>> > >I will try to create a patch for gcc and put rtems CC for the discussion.
> >> >Another option would be to provide the __sync_() stuff also via libatomic.
> > True. I will ask on the gcc mailinglist what they would prefer.
> This __sync_() stuff seems to be used in several places in GCC. So, changing
> libbacktrace is probably not enough. We need a general solution for the
> __sync_() builtins on RTEMS. I don't think GCC can be changed to emit
> __atomic_() calls for the __sync_() builtins (I would still try to ask). The libgcc or
> libatomic is probably a good place to add them for RTEMS as functions
> implemented via __atomic_() builtins.
I updated the __sync-check of libbacktrace and now the undefined references are gone and my test program compiles.
If there are no objections I would try to push something like the attached patch upstream. Do you have any suggestions to which branches?
I thought about trunk and the gcc-6 branch or do we need further backports for older RTEMS versions?
Best regards,
Jan
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Desc: fix-leon2-libbacktrace.patch
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170228/dbb4a22c/attachment.obj>
