GSoC Mentors / Projects of Interest
Kuan Hsun Chen kuan-hsun.chen at tu-dortmund.de
Wed Feb 1 17:17:32 UTC 2017
Hi Gedare,
I think we are not able to modify the content of tickets. I have tried the
ticket I initialized before.
I can only change properties summary and action.
Best,
Kuan-Hsun
2017-02-01 17:55 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> On Wed, Feb 1, 2017 at 12:49 AM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> > Hello,
> > I'm unable to change the content of "Description" field on Trac. I
> > read https://devel.rtems.org/wiki/TracTickets and couldn't find any
> > luck. I read a thread on Trac's mailing list
> > (https://lists.gt.net/trac/users/46376). Perhaps, it has to do
> > something with TICKET_EDIT_DESCRIPTION permissions. How do I go about
> > doing this? What is it that I'm missing?
> If you're logged in then you should see a small link "Modify ↓" just
> above the ticket box.
> > Regards,
> > Tanu Hari Dixit.
> > On Wed, Feb 1, 2017 at 9:25 AM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> >>> * You removed the "Introduction" section. Any reason or just an
> oversight?
> >>> * The 'status' field is gone too. But, I think the status is not
> >>> needed in the ticket format.
> >> I removed the "Introduction" section by mistake. I'll include it.
> >>> Did you face any difficulties in making the transition? It would be
> >>> good to document your workflow on the Open Projects page.
> >> I wikiformatted the text myself. But it would have been better if I
> >> had just copied the already formatted text that pops up when we try to
> >> edit the project page
> >> (https://devel.rtems.org/wiki/Developer/Projects/Open/Improv
> eBeagleBSP?action=edit).
> >> No difficulties as such. I'll document the workflow on the open
> >> projects page.
> >>> We should convert all of the open projects to tickets eventually. And
> >>> then generate a report in the Open Projects page based on the tickets.
> >>> I have done this for the BSP ones and found the following changes
> >>> should be made in the workflow:
> >> Could you please direct me to the tickets you created? I couldn't find
> >> them on Trac.
> >>> I knew I had bought at least one so went to Amazon to see what we
> >>> have here at OAR.
> >>> https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-Su
> pport/dp/B004LBXO2A
> >>> Other folks in the community may have alternatives. It is a pretty
> generic
> >>> piece of hardware. But there was that issue with the FTDI driver
> refusing
> >>> to work with cloned FTDI chips. So I would bet there are some out there
> >>> you don't want.
> >> I'll include the above hyperlink.
> >> Thanks,
> >> Tanu Hari Dixit.
> >> On Wed, Feb 1, 2017 at 4:33 AM, Joel Sherrill <joel at rtems.org> wrote:
> >>> On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>>> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit <
> >>>> wrote:
> >>>> > Hello,
> >>>> > I created (https://devel.rtems.org/ticket/2891#ticket) on the
> lines of
> >>>> > Gedare's advice for this open project
> eBeagleBSP).
> >>>> Looks nice, a few minor things:
> oversight?
> >>>> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page is
> >>>> > probably broken. What should I replace it with? Please tell if some
> >>>> See if you can find something appropriate on Google?
> >>> have here at OAR.
> pport/dp/B004LBXO2A
> generic
> refusing
> >>> you don't want.
> >>>> > edit is needed and whether I should follow this pattern.
> Furthermore,
> >>>> > please indicate whether this project is of interest. Also which
> other
> >>>> > open projects should be converted to tickets?
> >>>> * Use only one keyword. I prefer "SoC" so it is generic to other
> >>>> 'summer of code' style projects.
> >>>> * Use the components field to further categorize. We have some obvious
> >>>> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
> >>>> Others should be identified or else we can create new components if
> >>>> necessary. I'd like to stick with the current subheadings for this
> >>>> year's GSoC, but we can revise later.
> >>>> > Probably the community is interested in the idea to create simple
> >>>> > examples or sanity tests for all RTEMS directives so that they can
> be
> >>>> > included in the documentation (something that is user friendly).
> Also,
> >>>> > there was a thread titled 'Desirable Application Stacks (Add-On
> >>>> > Library Collections)' . Which ideas can be derived from there?
> >>>> > Regards,
> >>>> > Tanu Hari Dixit.
> >>>> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org>
> wrote:
> >>>> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>>> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit
> >>>> >>> wrote:
> >>>> >>> > I'll be glad to do it. Please guide me as to how to proceed.
> >>>> >>> We will need to import each existing Open Project description
> into a
> >>>> >>> new ticket. It would be best to start with one to "try it out".
> The
> >>>> >>> project title should be the Summary of the ticket, the text of the
> >>>> >>> project page should be converted into the Description of the
> ticket,
> >>>> >>> type should be Enhancement, Milestone "Indefinite", and put GSoC
> into
> >>>> >>> the keywords, and we might want to use some other keywords e.g. to
> >>>> >>> define the project type (e.g. one of: testing, ecosystem, kernel,
> >>>> >>> statistics, BSP, API, libbsd, languages, libraries). The owner
> should
> >>>> >>> be assigned to one of the mentors if indicated, with others in CC
> if
> >>>> >>> any, or else set blank.
> >>>> >> I agree it would be nice to get all the Open Project ideas as
> tickets
> >>>> >> and
> >>>> >> off the Wiki. Some of the ideas are likely no longer
> interesting/valid
> >>>> >> at
> >>>> >> this point and could just be deleted.
> >>>> >> FWIW I also want to move some of the Wiki content into Sphinx
> >>>> >> documents.
> >>>> >> I think being able to release them with RTEMS branches and use git
> >>>> >> for revision control.
> >>>> >> --joel
> >>>> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom <gedare at rtems.org
> >>>> >>> > wrote:
> >>>> >>> >> Yes that would be much nicer. Maybe we can get potential GSoC
> >>>> >>> >> Students
> >>>> >>> >> to do the work ;)
> >>>> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
> >>>> >>> >> <sebastian.huber at embedded-brains.de> wrote:
> >>>> >>> >> > Maybe we should move all this open projects wiki stuff into
> >>>> >>> >> > tickets
> >>>> >>> >> > with
> >>>> >>> >> > some sort of "GSoC" tag.
> >>>> >>> >> > Sebastian Huber, embedded brains GmbH
> >>>> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >>>> >>> >> > Phone   : +49 89 189 47 41-16
> >>>> >>> >> > Fax     : +49 89 189 47 41-09
> >>>> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
> >>>> >>> >> > PGP     : Public key available on request.
> >>>> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> des
> >>>> >>> >> > EHUG.
> >>>> >>> >> _______________________________________________
> >>>> >>> >> devel mailing list
> >>>> >>> >> devel at rtems.org
> >>>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
> >>>> >>> devel mailing list
> >>>> >>> devel at rtems.org
> devel mailing list
> devel at rtems.org
M.Sc. Kuan-Hsun Chen
TU Dortmund
Department of Computer Science 12
Design Automation of Embedded Systems
Otto-Hahn-Strasse 16, Room 102
44227 Dortmund
Germany
Phone:  *+49 231 755 6124 <+49%20231%207556124>*
Mail:   kuan-hsun.chen at tu-dortmund.de <kuan-hsun.chen at tu-dortmund.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170201/9a481e97/attachment-0002.html>
