Build error on rtems master
Joel Sherrill
joel at rtems.org
Thu Feb 2 19:51:23 UTC 2017
That sounds like a reasonable error and fix. Please send a patch
to the mailing list.
I assume the build of all BSPs I just started is likely to fail if
I didn't enable SMP. :)
--joel
On Thu, Feb 2, 2017 at 1:07 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
wrote:
> I’m getting a build error with the latest master due to the changes
> removing CONFIGURE_SMP_APPLICATION. The default-configuration.c file sets
> CONFIGURE_SMP_MAXIMUM_PROCESSORS to 32 thus enabling the internal
> _CONFIGURE_SMP_APPLICATION define on targets without SMP. I had to add a
> #if defined(RTEMS_SMP)
> guard around
> #if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
> #define _CONFIGURE_SMP_APPLICATION
> #endif
> to get it to compile. I was building for the xilinx_zynq_a9_qemu BSP.
> Kevin Kirspel
> Electrical Engineer - Sr. Staff
> Idexx Roswell
> 235 Hembree Park Drive
> Roswell GA 30076
> Tel: (770)-510-4444 ext. 81642 <(770)%20510-4444>
> Direct: (770)-688-1642 <(770)%20688-1642>
> Fax: (770)-510-4445 <(770)%20510-4445>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170202/13e7c381/attachment-0002.html>
