Regarding running one test
Sat Feb 4 16:54:43 UTC 2017
If you are building the erc32 BSP, there are a handful of options. It is
probably the easiest BSP to run tests on a simulator.
sparc-rtems4.12-run xxx.exe
sparc-rtems4.12-gdb xxx.exe
... target sim
... load
... run
The rtems-tester supports this BSP to ease running tests for this BSP.
Also the older rtems-testing repo has a sim-scripts directory with scripts
to ease using a number of simulators. It has gdb and direct run modes.
--joel
On Feb 4, 2017 10:23 AM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
> The following is the output of the configure statement (I ran configure
> again because I did not save the output of the previous one)
> thd at thd-Inspiron-5537:~/development/rtems/src/builds/erc32_test1$
> ../../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=erc32
> --enable-tests --prefix=${HOME}/development/rtems/install_path_test1
> checking for gmake... no
> checking for make... make
> checking for RTEMS Version... 4.11.99.0
> checking build system type... x86_64-pc-linux-gnu
> checking host system type... x86_64-pc-linux-gnu
> checking target system type... sparc-unknown-rtems4.12
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> checking that generated files are newer than configure... done
> configure: creating ./config.status
> configure: configuring in ./tools/build
> configure: running /bin/sh '../../../../rtems/tools/build/configure'
> '--prefix=/home/thd/development/rtems/install_path_test1'
> '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
> '--enable-rtemsbsp=erc32' '--enable-tests' '--target=sparc-rtems4.12'
> '--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/build'
> checking for x86_64-pc-linux-gnu-gcc... no
> checking for gcc... gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... no
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for style of include used by make... GNU
> checking dependency style of gcc... gcc3
> checking how to run the C preprocessor... gcc -E
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking getopt.h usability... yes
> checking getopt.h presence... yes
> checking for getopt.h... yes
> checking libgen.h usability... yes
> checking libgen.h presence... yes
> checking for libgen.h... yes
> checking for strerror... yes
> checking for strtol... yes
> checking for basename... yes
> checking for strnlen... yes
> checking for bash... /bin/bash
> config.status: creating Makefile
> config.status: creating install-if-change
> config.status: creating config.h
> config.status: executing depfiles commands
> configure: configuring in ./tools/cpu
> configure: running /bin/sh '../../../../rtems/tools/cpu/configure'
> '--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/cpu'
> checking rtems target cpu... sparc
> === configuring in generic (/home/thd/development/rtems/
> src/builds/erc32_test1/tools/cpu/generic)
> configure: running /bin/sh ../../../../../rtems/tools/cpu/generic/configure
> --disable-option-checking '--prefix=/home/thd/development/rtems/install_path_test1'
> 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu'
> 'target_alias=sparc-rtems4.12' --cache-file=/dev/null
> --srcdir=../../../../../rtems/tools/cpu/generic
> config.status: creating size_rtems
> configure: configuring in ./testsuites/tools
> configure: running /bin/sh '../../../../rtems/testsuites/tools/configure'
> '--cache-file=/dev/null' '--srcdir=../../../../rtems/testsuites/tools'
> src/builds/erc32_test1/testsuites/tools/generic)
> configure: running /bin/sh ../../../../../rtems/testsuites/tools/generic/configure
> --srcdir=../../../../../rtems/testsuites/tools/generic
> config.status: creating difftest
> config.status: creating sorttimes
> configure: configuring in sparc-rtems4.12/c
> configure: running /bin/sh '../../../../rtems/c/configure'
> '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu'
> '--target=sparc-rtems4.12'  '--enable-rtemsbsp=erc32' '--enable-tests'
> '--with-target-subdir=sparc-rtems4.12' '--exec-prefix=/home/thd/
> development/rtems/install_path_test1/sparc-rtems4.12'
> '--includedir=/home/thd/development/rtems/install_
> path_test1/sparc-rtems4.12/include'  '--cache-file=/dev/null'
> '--srcdir=../../../../rtems/c'
> checking host system type... sparc-unknown-rtems4.12
> checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
> target architecture: sparc.
> available BSPs: erc32.
> 'make all' will build the following BSPs: erc32.
> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
> Thank you,
> Tanu Hari Dixit.
> On Sat, Feb 4, 2017 at 9:26 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> wrote:
>> I don’t have the spac toolset so I cannot test your situation.  However,
>> can you post the output of your configure?  I want to make sure it found
>> the erc32 BSP.
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642 <(770)%20510-4444>
>> Direct: (770)-688-1642 <(770)%20688-1642>
>> Fax: (770)-510-4445 <(770)%20510-4445>
>> *From:* Tanu Hari Dixit [mailto:tokencolour at gmail.com]
>> *Sent:* Saturday, February 04, 2017 10:27 AM
>> *To:* Kuan Hsun Chen <kuan-hsun.chen at tu-dortmund.de>
>> *Cc:* rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin <
>> *Subject:* Re: Regarding running one test
>> Hi Kevin, Kuan-Hsun,
>> Thank you for the answer.
>> I have run into a problem before trying the above solutions for myself,
>> while updating my local copy of the rtems repository with upstream with
>> "git pull".
>> After I updated the local copy, I built the sparc toolset with
>> ../source-builder/sb-set-builder --log=l-sparc-test.txt
>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
>> Then I ran  ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
>> bootstrap.
>> Then from  builds/erc32_test(subdirectory) I ran
>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$
>> And when I ran make, It showed the following error;
>> make[2]: Leaving directory `/home/thd/development/rtems/s
>> rc/builds/erc32_test/tools/build'
>> make[1]: Leaving directory `/home/thd/development/rtems/s
>> Making all in tools/cpu
>> make[1]: Entering directory `/home/thd/development/rtems/s
>> rc/builds/erc32_test/tools/cpu'
>> Making all in generic
>> make[2]: Entering directory `/home/thd/development/rtems/s
>> rc/builds/erc32_test/tools/cpu/generic'
>> make[2]: Nothing to be done for `all'.
>> make[2]: Nothing to be done for `all-am'.
>> Making all in testsuites/tools
>> rc/builds/erc32_test/testsuites/tools'
>> rc/builds/erc32_test/testsuites/tools/generic'
>> Making all in sparc-rtems4.12/c
>> rc/builds/erc32_test/sparc-rtems4.12/c'
>> Making all in .
>> Making all in erc32
>> rc/builds/erc32_test/sparc-rtems4.12/c/erc32'
>> make[2]: *** No rule to make target `all'.  Stop.
>> make[1]: *** [all-recursive] Error 1
>> make: *** [all-recursive] Error 1
>> I have ran into this problem more than once. When last time this
>> happened, I thought I must have messed up somewhere in the git (or rtems)
>> workflow and hence decided to make a clean clone of the rtems repo and
>> continue with it. I also tried git reset --hard <hash-number> last time and
>> had no luck.
>> Right now, I did not do a hard reset and currently git reflog shows the
>> following output:
>> 239dd35 HEAD@{0}: pull: Fast-forward
>> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems.git&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=ryMs7_iFDreSyA8ad3iXqtVo0QByXEG61ZeaU1r6J4A&e=>
>> git status shows
>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
>> On branch master
>> Your branch is up-to-date with 'origin/master'.
>> Changes not staged for commit:
>>   (use "git add <file>..." to update what will be committed)
>>   (use "git checkout -- <file>..." to discard changes in working
>> directory)
>>     modified:   c/src/lib/libbsp/powerpc/acinclude.m4
>> no changes added to commit (use "git add" and/or "git commit -a")
>> I don't know what I am missing. Do I need to do something before pulling
>> from upstream? How do I rectify this? Please help me with this.
>> Thank you,
>> Tanu Hari Dixit.
>> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen <
>> kuan-hsun.chen at tu-dortmund.de> wrote:
>> Or alternatively you can prepare simulator like qemu to executed each of
>> it after compiling the source tree.
>> Like this in testsuites/hello/:
>> 1.  qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel
>> 2.  hello.exe -smp 4
>> Best,
>> Kuan-Hsun
>> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
>> I use the rtems tester.  ftp://ftp.rtems.org/pub/rtems/
>> people/chrisj/rtems-tester/rtems-tester.html
>> <https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_people_chrisj_rtems-2Dtester_rtems-2Dtester.html&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=Gv6QEbMGt88773MgovVmHykfnOxbLOP5J32IzwNVNEc&e=>
>> Kevin Kirspel
>> Idexx Roswell
>> Roswell GA 30076
>> Fax: (770)-510-4445
>> -----Original Message-----
>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit
>> Sent: Saturday, February 04, 2017 12:23 AM
>> To: rtems-devel at rtems.org <devel at rtems.org>
>> Subject: Regarding running one test
>> Hello all,
>> How do I run a single test from the testsuites? I want to run one test
>> from the rtems/testsuites/fstests. How do I go about doing that?
>> Regards,
>> Tanu Hari Dixit.
>> devel mailing list
>> devel at rtems.org
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rt
>> ems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFF
>> zH4W9XS8-wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94e
>> NhQoI76FuuhiadOCFEoiJ3HdxyrrQ&e=
>> devel mailing list
>> devel at rtems.org
>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=2TitOf1dwrWdEOQH2NpO_av9kjH_jPk9KJdkJUNk2Js&e=>
>> M.Sc. Kuan-Hsun Chen
>> TU Dortmund
>> Department of Computer Science 12
>> Design Automation of Embedded Systems
>> Otto-Hahn-Strasse 16, Room 102
>> 44227 Dortmund
>> Germany
>> Phone:  *+49 231 755 6124 <+49%20231%207556124>*
>> Mail:   kuan-hsun.chen at tu-dortmund.de
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170204/fb046671/attachment-0002.html>
