Regarding running one test
Sat Feb 4 19:43:11 UTC 2017
On Feb 4, 2017 12:25 PM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
Hello Joel,
Thanks for the answer. I want to compile and build the exe file for just
one test. When I use the option --enable-tests with configure, does it
assume to build for all tests in the testsuites? I want to build for a
single test only. I haven't tried rtems-tester as of now because I updated
the rtems repository from upstream and have run into trouble. Can you
please help me with this?
You either configure for no tests, samples or all tests.
If you are trying to speed up a build for debug purposes, you can be
careful and build just cpukit again and then switch.to the test directory.
I am answering from my phone so can't give you an example of that. But
honestly, I just build from the top and use a fast machine.
Sorry.
Thanks,
Tanu Hari Dixit.
On Sat, Feb 4, 2017 at 10:24 PM, Joel Sherrill <joel at rtems.org> wrote:
> If you are building the erc32 BSP, there are a handful of options. It is
> probably the easiest BSP to run tests on a simulator.
> sparc-rtems4.12-run xxx.exe
> sparc-rtems4.12-gdb xxx.exe
> ... target sim
> ... load
> ... run
> The rtems-tester supports this BSP to ease running tests for this BSP.
> Also the older rtems-testing repo has a sim-scripts directory with scripts
> to ease using a number of simulators. It has gdb and direct run modes.
> --joel
> On Feb 4, 2017 10:23 AM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
>> The following is the output of the configure statement (I ran configure
>> again because I did not save the output of the previous one)
>> thd at thd-Inspiron-5537:~/development/rtems/src/builds/erc32_test1$
>> ../../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=erc32
>> --enable-tests --prefix=${HOME}/development/rtems/install_path_test1
>> checking for gmake... no
>> checking for make... make
>> checking for RTEMS Version... 4.11.99.0
>> checking build system type... x86_64-pc-linux-gnu
>> checking host system type... x86_64-pc-linux-gnu
>> checking target system type... sparc-unknown-rtems4.12
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... gawk
>> checking whether make sets $(MAKE)... yes
>> checking whether to enable maintainer-specific portions of Makefiles... no
>> checking that generated files are newer than configure... done
>> configure: creating ./config.status
>> configure: configuring in ./tools/build
>> configure: running /bin/sh '../../../../rtems/tools/build/configure'
>> '--prefix=/home/thd/development/rtems/install_path_test1'
>> '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'
>> '--enable-rtemsbsp=erc32' '--enable-tests' '--target=sparc-rtems4.12'
>> '--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/build'
>> checking for x86_64-pc-linux-gnu-gcc... no
>> checking for gcc... gcc
>> checking whether the C compiler works... yes
>> checking for C compiler default output file name... a.out
>> checking for suffix of executables...
>> checking whether we are cross compiling... no
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ISO C89... none needed
>> checking for style of include used by make... GNU
>> checking dependency style of gcc... gcc3
>> checking how to run the C preprocessor... gcc -E
>> checking for grep that handles long lines and -e... /bin/grep
>> checking for egrep... /bin/grep -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking getopt.h usability... yes
>> checking getopt.h presence... yes
>> checking for getopt.h... yes
>> checking libgen.h usability... yes
>> checking libgen.h presence... yes
>> checking for libgen.h... yes
>> checking for strerror... yes
>> checking for strtol... yes
>> checking for basename... yes
>> checking for strnlen... yes
>> checking for bash... /bin/bash
>> config.status: creating Makefile
>> config.status: creating install-if-change
>> config.status: creating config.h
>> config.status: executing depfiles commands
>> configure: configuring in ./tools/cpu
>> configure: running /bin/sh '../../../../rtems/tools/cpu/configure'
>> '--cache-file=/dev/null' '--srcdir=../../../../rtems/tools/cpu'
>> checking rtems target cpu... sparc
>> === configuring in generic (/home/thd/development/rtems/s
>> rc/builds/erc32_test1/tools/cpu/generic)
>> configure: running /bin/sh ../../../../../rtems/tools/cpu/generic/configure
>> --disable-option-checking '--prefix=/home/thd/development/rtems/install_path_test1'
>> 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu'
>> 'target_alias=sparc-rtems4.12' --cache-file=/dev/null
>> --srcdir=../../../../../rtems/tools/cpu/generic
>> config.status: creating size_rtems
>> configure: configuring in ./testsuites/tools
>> configure: running /bin/sh '../../../../rtems/testsuites/tools/configure'
>> '--cache-file=/dev/null' '--srcdir=../../../../rtems/testsuites/tools'
>> rc/builds/erc32_test1/testsuites/tools/generic)
>> configure: running /bin/sh ../../../../../rtems/testsuites/tools/generic/configure
>> --srcdir=../../../../../rtems/testsuites/tools/generic
>> config.status: creating difftest
>> config.status: creating sorttimes
>> configure: configuring in sparc-rtems4.12/c
>> configure: running /bin/sh '../../../../rtems/c/configure'
>> '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu'
>> '--target=sparc-rtems4.12'  '--enable-rtemsbsp=erc32' '--enable-tests'
>> '--with-target-subdir=sparc-rtems4.12' '--exec-prefix=/home/thd/devel
>> opment/rtems/install_path_test1/sparc-rtems4.12'
>> '--includedir=/home/thd/development/rtems/install_path_test1/sparc-rtems4.12/include'
>> '--cache-file=/dev/null' '--srcdir=../../../../rtems/c'
>> checking host system type... sparc-unknown-rtems4.12
>> checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
>> target architecture: sparc.
>> available BSPs: erc32.
>> 'make all' will build the following BSPs: erc32.
>> other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
>> Thank you,
>> Tanu Hari Dixit.
>> On Sat, Feb 4, 2017 at 9:26 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
>> wrote:
>>> I don’t have the spac toolset so I cannot test your situation.  However,
>>> can you post the output of your configure?  I want to make sure it found
>>> the erc32 BSP.
>>> Kevin Kirspel
>>> Electrical Engineer - Sr. Staff
>>> Idexx Roswell
>>> 235 Hembree Park Drive
>>> Roswell GA 30076
>>> Tel: (770)-510-4444 ext. 81642 <(770)%20510-4444>
>>> Direct: (770)-688-1642 <(770)%20688-1642>
>>> Fax: (770)-510-4445 <(770)%20510-4445>
>>> *From:* Tanu Hari Dixit [mailto:tokencolour at gmail.com]
>>> *Sent:* Saturday, February 04, 2017 10:27 AM
>>> *To:* Kuan Hsun Chen <kuan-hsun.chen at tu-dortmund.de>
>>> *Cc:* rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin <
>>> *Subject:* Re: Regarding running one test
>>> Hi Kevin, Kuan-Hsun,
>>> Thank you for the answer.
>>> I have run into a problem before trying the above solutions for myself,
>>> while updating my local copy of the rtems repository with upstream with
>>> "git pull".
>>> After I updated the local copy, I built the sparc toolset with
>>> ../source-builder/sb-set-builder --log=l-sparc-test.txt
>>> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
>>> Then I ran  ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
>>> bootstrap.
>>> Then from  builds/erc32_test(subdirectory) I ran
>>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$
>>> And when I ran make, It showed the following error;
>>> make[2]: Leaving directory `/home/thd/development/rtems/s
>>> rc/builds/erc32_test/tools/build'
>>> make[1]: Leaving directory `/home/thd/development/rtems/s
>>> Making all in tools/cpu
>>> make[1]: Entering directory `/home/thd/development/rtems/s
>>> rc/builds/erc32_test/tools/cpu'
>>> Making all in generic
>>> make[2]: Entering directory `/home/thd/development/rtems/s
>>> rc/builds/erc32_test/tools/cpu/generic'
>>> make[2]: Nothing to be done for `all'.
>>> make[2]: Nothing to be done for `all-am'.
>>> Making all in testsuites/tools
>>> rc/builds/erc32_test/testsuites/tools'
>>> rc/builds/erc32_test/testsuites/tools/generic'
>>> Making all in sparc-rtems4.12/c
>>> rc/builds/erc32_test/sparc-rtems4.12/c'
>>> Making all in .
>>> Making all in erc32
>>> rc/builds/erc32_test/sparc-rtems4.12/c/erc32'
>>> make[2]: *** No rule to make target `all'.  Stop.
>>> make[1]: *** [all-recursive] Error 1
>>> make: *** [all-recursive] Error 1
>>> I have ran into this problem more than once. When last time this
>>> happened, I thought I must have messed up somewhere in the git (or rtems)
>>> workflow and hence decided to make a clean clone of the rtems repo and
>>> continue with it. I also tried git reset --hard <hash-number> last time and
>>> had no luck.
>>> Right now, I did not do a hard reset and currently git reflog shows the
>>> following output:
>>> 239dd35 HEAD@{0}: pull: Fast-forward
>>> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__git.rtems.org_rtems.git&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=ryMs7_iFDreSyA8ad3iXqtVo0QByXEG61ZeaU1r6J4A&e=>
>>> git status shows
>>> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
>>> On branch master
>>> Your branch is up-to-date with 'origin/master'.
>>> Changes not staged for commit:
>>>   (use "git add <file>..." to update what will be committed)
>>>   (use "git checkout -- <file>..." to discard changes in working
>>> directory)
>>>     modified:   c/src/lib/libbsp/powerpc/acinclude.m4
>>> no changes added to commit (use "git add" and/or "git commit -a")
>>> I don't know what I am missing. Do I need to do something before pulling
>>> from upstream? How do I rectify this? Please help me with this.
>>> Thank you,
>>> Tanu Hari Dixit.
>>> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen <
>>> kuan-hsun.chen at tu-dortmund.de> wrote:
>>> Or alternatively you can prepare simulator like qemu to executed each of
>>> it after compiling the source tree.
>>> Like this in testsuites/hello/:
>>> 1.  qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel
>>> 2.  hello.exe -smp 4
>>> Best,
>>> Kuan-Hsun
>>> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
>>> I use the rtems tester.  ftp://ftp.rtems.org/pub/rtems/
>>> people/chrisj/rtems-tester/rtems-tester.html
>>> <https://urldefense.proofpoint.com/v2/url?u=ftp-3A__ftp.rtems.org_pub_rtems_people_chrisj_rtems-2Dtester_rtems-2Dtester.html&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=Gv6QEbMGt88773MgovVmHykfnOxbLOP5J32IzwNVNEc&e=>
>>> Kevin Kirspel
>>> Idexx Roswell
>>> Roswell GA 30076
>>> Fax: (770)-510-4445
>>> -----Original Message-----
>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari
>>> Dixit
>>> Sent: Saturday, February 04, 2017 12:23 AM
>>> To: rtems-devel at rtems.org <devel at rtems.org>
>>> Subject: Regarding running one test
>>> Hello all,
>>> How do I run a single test from the testsuites? I want to run one test
>>> from the rtems/testsuites/fstests. How do I go about doing that?
>>> Regards,
>>> Tanu Hari Dixit.
>>> devel mailing list
>>> devel at rtems.org
>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rt
>>> ems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFF
>>> M1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=zH4W9XS
>>> 8-wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94eNhQoI76
>>> FuuhiadOCFEoiJ3HdxyrrQ&e=
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=elBFGM7Up_H75tt-b3VbfyK1iPdyr-jmME-Ab4rL2hk&s=2TitOf1dwrWdEOQH2NpO_av9kjH_jPk9KJdkJUNk2Js&e=>
>>> M.Sc. Kuan-Hsun Chen
>>> TU Dortmund
>>> Department of Computer Science 12
>>> Design Automation of Embedded Systems
>>> Otto-Hahn-Strasse 16, Room 102
>>> 44227 Dortmund
>>> Germany
>>> Phone:  *+49 231 755 6124 <+49%20231%207556124>*
>>> Mail:   kuan-hsun.chen at tu-dortmund.de
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170204/05fac3c5/attachment-0002.html>
