GSoC Mentors / Projects of Interest
Tanu Hari Dixit tokencolour at gmail.com
Mon Feb 6 03:36:41 UTC 2017
Hello all,
I added the following tickets for the BSP projects:
https://devel.rtems.org/ticket/2898#ticket
https://devel.rtems.org/ticket/2899#ticket
https://devel.rtems.org/ticket/2900#ticket
https://devel.rtems.org/ticket/2901#ticket
https://devel.rtems.org/ticket/2903#ticket
https://devel.rtems.org/ticket/2904#ticket
https://devel.rtems.org/ticket/2905#ticket
Also, I have edited the open projects page to include my workflow for
adding tickets(
https://devel.rtems.org/wiki/Developer/OpenProjects#HelpConverttoTickets).
Kindly review it and help me edit the required changes.
Thank you,
Tanu Hari Dixit.
On Wed, Feb 1, 2017 at 11:44 PM, Tanu Hari Dixit <tokencolour at gmail.com>
wrote:
> > If you're logged in then you should see a small link "Modify ↓" just
> > above the ticket box.
> I clicked on the Modify link but it doesn't give me an option to edit
> the description.
> Thanks,
> Tanu Hari Dixit.
> On Wed, Feb 1, 2017 at 10:47 PM, Kuan Hsun Chen
> <kuan-hsun.chen at tu-dortmund.de> wrote:
> > Hi Gedare,
> > I think we are not able to modify the content of tickets. I have tried
> the
> > ticket I initialized before.
> > I can only change properties summary and action.
> > Best,
> > Kuan-Hsun
> > 2017-02-01 17:55 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> >> On Wed, Feb 1, 2017 at 12:49 AM, Tanu Hari Dixit <tokencolour at gmail.com
> >> wrote:
> >> > Hello,
> >> > I'm unable to change the content of "Description" field on Trac. I
> >> > read https://devel.rtems.org/wiki/TracTickets and couldn't find any
> >> > luck. I read a thread on Trac's mailing list
> >> > (https://lists.gt.net/trac/users/46376). Perhaps, it has to do
> >> > something with TICKET_EDIT_DESCRIPTION permissions. How do I go about
> >> > doing this? What is it that I'm missing?
> >> > Regards,
> >> > Tanu Hari Dixit.
> >> > On Wed, Feb 1, 2017 at 9:25 AM, Tanu Hari Dixit <
> >> > wrote:
> >> >>> * You removed the "Introduction" section. Any reason or just an
> >> >>> oversight?
> >> >>> * The 'status' field is gone too. But, I think the status is not
> >> >>> needed in the ticket format.
> >> >> I removed the "Introduction" section by mistake. I'll include it.
> >> >>> Did you face any difficulties in making the transition? It would be
> >> >>> good to document your workflow on the Open Projects page.
> >> >> I wikiformatted the text myself. But it would have been better if I
> >> >> had just copied the already formatted text that pops up when we try
> to
> >> >> edit the project page
> >> >> (https://devel.rtems.org/wiki/Developer/Projects/Open/
> ImproveBeagleBSP?action=edit).
> >> >> No difficulties as such. I'll document the workflow on the open
> >> >> projects page.
> >> >>> We should convert all of the open projects to tickets eventually.
> And
> >> >>> then generate a report in the Open Projects page based on the
> tickets.
> >> >>> I have done this for the BSP ones and found the following changes
> >> >>> should be made in the workflow:
> >> >> Could you please direct me to the tickets you created? I couldn't
> find
> >> >> them on Trac.
> >> >>> I knew I had bought at least one so went to Amazon to see what we
> >> >>> have here at OAR.
> >> >>> https://www.amazon.com/GearMo-Header-TTL-232R-3V3-Windows-
> Support/dp/B004LBXO2A
> >> >>> Other folks in the community may have alternatives. It is a pretty
> >> >>> generic
> >> >>> piece of hardware. But there was that issue with the FTDI driver
> >> >>> refusing
> >> >>> to work with cloned FTDI chips. So I would bet there are some out
> >> >>> there
> >> >>> you don't want.
> >> >> I'll include the above hyperlink.
> >> >> Thanks,
> >> >> Tanu Hari Dixit.
> >> >> On Wed, Feb 1, 2017 at 4:33 AM, Joel Sherrill <joel at rtems.org>
> wrote:
> >> >>> On Tue, Jan 31, 2017 at 12:54 PM, Gedare Bloom <gedare at rtems.org>
> >> >>> wrote:
> >> >>>> On Tue, Jan 31, 2017 at 12:21 PM, Tanu Hari Dixit
> >> >>>> wrote:
> >> >>>> > Hello,
> >> >>>> > I created (https://devel.rtems.org/ticket/2891#ticket) on the
> lines
> >> >>>> > of
> >> >>>> > Gedare's advice for this open project
> ImproveBeagleBSP).
> >> >>>> Looks nice, a few minor things:
> >> >>>> oversight?
> >> >>>> > The link to buy USB-TTL FTDI Cable 3.3V on the open project page
> is
> >> >>>> > probably broken. What should I replace it with? Please tell if
> some
> >> >>>> See if you can find something appropriate on Google?
> >> >>> have here at OAR.
> >> >>> generic
> >> >>> refusing
> >> >>> there
> >> >>> you don't want.
> >> >>>> > edit is needed and whether I should follow this pattern.
> >> >>>> > Furthermore,
> >> >>>> > please indicate whether this project is of interest. Also which
> >> >>>> > other
> >> >>>> > open projects should be converted to tickets?
> And
> >> >>>> tickets.
> >> >>>> * Use only one keyword. I prefer "SoC" so it is generic to other
> >> >>>> 'summer of code' style projects.
> >> >>>> * Use the components field to further categorize. We have some
> >> >>>> obvious
> >> >>>> ones for the subheadings now, such as 'bsps', 'libbsd', 'testing'.
> >> >>>> Others should be identified or else we can create new components if
> >> >>>> necessary. I'd like to stick with the current subheadings for this
> >> >>>> year's GSoC, but we can revise later.
> >> >>>> > Probably the community is interested in the idea to create simple
> >> >>>> > examples or sanity tests for all RTEMS directives so that they
> can
> >> >>>> > be
> >> >>>> > included in the documentation (something that is user friendly).
> >> >>>> > Also,
> >> >>>> > there was a thread titled 'Desirable Application Stacks (Add-On
> >> >>>> > Library Collections)' . Which ideas can be derived from there?
> >> >>>> > Regards,
> >> >>>> > Tanu Hari Dixit.
> >> >>>> > On Tue, Jan 31, 2017 at 4:52 AM, Joel Sherrill <joel at rtems.org>
> >> >>>> > wrote:
> >> >>>> >> On Mon, Jan 30, 2017 at 5:13 PM, Gedare Bloom <gedare at rtems.org
> >> >>>> >> wrote:
> >> >>>> >>> On Mon, Jan 30, 2017 at 12:25 PM, Tanu Hari Dixit
> >> >>>> >>> wrote:
> >> >>>> >>> > I'll be glad to do it. Please guide me as to how to proceed.
> >> >>>> >>> We will need to import each existing Open Project description
> >> >>>> >>> into a
> >> >>>> >>> new ticket. It would be best to start with one to "try it out".
> >> >>>> >>> The
> >> >>>> >>> project title should be the Summary of the ticket, the text of
> >> >>>> >>> the
> >> >>>> >>> project page should be converted into the Description of the
> >> >>>> >>> ticket,
> >> >>>> >>> type should be Enhancement, Milestone "Indefinite", and put
> GSoC
> >> >>>> >>> into
> >> >>>> >>> the keywords, and we might want to use some other keywords e.g.
> >> >>>> >>> to
> >> >>>> >>> define the project type (e.g. one of: testing, ecosystem,
> kernel,
> >> >>>> >>> statistics, BSP, API, libbsd, languages, libraries). The owner
> >> >>>> >>> should
> >> >>>> >>> be assigned to one of the mentors if indicated, with others in
> CC
> >> >>>> >>> if
> >> >>>> >>> any, or else set blank.
> >> >>>> >> I agree it would be nice to get all the Open Project ideas as
> >> >>>> >> tickets
> >> >>>> >> and
> >> >>>> >> off the Wiki. Some of the ideas are likely no longer
> >> >>>> >> interesting/valid
> >> >>>> >> at
> >> >>>> >> this point and could just be deleted.
> >> >>>> >> FWIW I also want to move some of the Wiki content into Sphinx
> >> >>>> >> documents.
> >> >>>> >> I think being able to release them with RTEMS branches and use
> git
> >> >>>> >> for revision control.
> >> >>>> >> --joel
> >> >>>> >>> > On Mon, Jan 30, 2017 at 9:38 PM, Gedare Bloom
> >> >>>> >>> > wrote:
> >> >>>> >>> >> Yes that would be much nicer. Maybe we can get potential
> GSoC
> >> >>>> >>> >> Students
> >> >>>> >>> >> to do the work ;)
> >> >>>> >>> >> On Mon, Jan 30, 2017 at 1:40 AM, Sebastian Huber
> >> >>>> >>> >> <sebastian.huber at embedded-brains.de> wrote:
> >> >>>> >>> >> > Maybe we should move all this open projects wiki stuff
> into
> >> >>>> >>> >> > tickets
> >> >>>> >>> >> > with
> >> >>>> >>> >> > some sort of "GSoC" tag.
> >> >>>> >>> >> > Sebastian Huber, embedded brains GmbH
> >> >>>> >>> >> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> >>>> >>> >> > Phone   : +49 89 189 47 41-16
> >> >>>> >>> >> > Fax     : +49 89 189 47 41-09
> >> >>>> >>> >> > E-Mail  : sebastian.huber at embedded-brains.de
> >> >>>> >>> >> > PGP     : Public key available on request.
> >> >>>> >>> >> > Diese Nachricht ist keine geschäftliche Mitteilung im
> Sinne
> >> >>>> >>> >> > des
> >> >>>> >>> >> > EHUG.
> >> >>>> >>> >> _______________________________________________
> >> >>>> >>> >> devel mailing list
> >> >>>> >>> >> devel at rtems.org
> >> >>>> >>> >> http://lists.rtems.org/mailman/listinfo/devel
> >> >>>> >>> devel mailing list
> >> >>>> >>> devel at rtems.org
> >> devel mailing list
> >> devel at rtems.org
> > M.Sc. Kuan-Hsun Chen
> > TU Dortmund
> > Department of Computer Science 12
> > Design Automation of Embedded Systems
> > Otto-Hahn-Strasse 16, Room 102
> > 44227 Dortmund
> > Germany
> > Phone:  +49 231 755 6124
> > Mail:   kuan-hsun.chen at tu-dortmund.de
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170206/0871d825/attachment-0002.html>
