Regarding running one test
Tanu Hari Dixit tokencolour at gmail.com
Mon Feb 6 14:47:03 UTC 2017
Hello Joel,
> You either configure for no tests, samples or all tests.
I finally understand this. Thanks.
> If you are trying to speed up a build for debug purposes, you can be
> careful and build just cpukit again and then switch.to the test
> directory.
By this do you mean, that if I make some changes in the cpukit, I rebuild
it---(i.e run the configure script in  rtems/cpukit and consequently make)
and it will be all that I am required to do? Won't I need to make the
executables again?
Regards,
Tanu Hari Dixit.
On Mon, Feb 6, 2017 at 7:08 PM, Tanu Hari Dixit <tokencolour at gmail.com>
wrote:
> Hello Gedare, Joel,
> I was able to re-build and execute the samples following your advice.
> Thank you.
> Regards,
> Tanu Hari Dixit.
> On Sun, Feb 5, 2017 at 3:03 AM, Gedare Bloom <gedare at rtems.org> wrote:
> > After you do a git-pull you should usually re-run bootstrap, delete
> > your build, and re-run configure and make. This is especially true if
> > you re-build a toolchain, at least to get started.
> > On Sat, Feb 4, 2017 at 10:26 AM, Tanu Hari Dixit <tokencolour at gmail.com>
> wrote:
> >> Hi Kevin, Kuan-Hsun,
> >> Thank you for the answer.
> >> I have run into a problem before trying the above solutions for myself,
> >> while updating my local copy of the rtems repository with upstream with
> "git
> >> pull".
> >> After I updated the local copy, I built the sparc toolset with
> >> ../source-builder/sb-set-builder --log=l-sparc-test.txt
> >> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
> >> Then I ran  ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
> >> bootstrap.
> >> Then from  builds/erc32_test(subdirectory) I ran
> >> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$
> ../../rtems/configure
> >> --target=sparc-rtems4.12 --enable-rtemsbsp=erc32 --enable-tests
> >> --prefix=${HOME}/development/rtems/install_path_test
> >> And when I ran make, It showed the following error;
> >> make[2]: Leaving directory
> >> `/home/thd/development/rtems/src/builds/erc32_test/tools/build'
> >> make[1]: Leaving directory
> >> Making all in tools/cpu
> >> make[1]: Entering directory
> >> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu'
> >> Making all in generic
> >> make[2]: Entering directory
> >> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu/generic'
> >> make[2]: Nothing to be done for `all'.
> >> make[2]: Nothing to be done for `all-am'.
> >> Making all in testsuites/tools
> >> `/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools'
> testsuites/tools/generic'
> >> Making all in sparc-rtems4.12/c
> >> `/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c'
> >> Making all in .
> >> Making all in erc32
> rtems4.12/c/erc32'
> >> make[2]: *** No rule to make target `all'.  Stop.
> rtems4.12/c/erc32'
> >> make[1]: *** [all-recursive] Error 1
> >> make: *** [all-recursive] Error 1
> >> I have ran into this problem more than once. When last time this
> happened, I
> >> thought I must have messed up somewhere in the git (or rtems) workflow
> and
> >> hence decided to make a clean clone of the rtems repo and continue with
> it.
> >> I also tried git reset --hard <hash-number> last time and had no luck.
> >> Right now, I did not do a hard reset and currently git reflog shows the
> >> following output:
> >> 239dd35 HEAD@{0}: pull: Fast-forward
> >> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
> >> git status shows
> >> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
> >> On branch master
> >> Your branch is up-to-date with 'origin/master'.
> >> Changes not staged for commit:
> >>   (use "git add <file>..." to update what will be committed)
> >>   (use "git checkout -- <file>..." to discard changes in working
> directory)
> >>     modified:   c/src/lib/libbsp/powerpc/acinclude.m4
> >> no changes added to commit (use "git add" and/or "git commit -a")
> >> I don't know what I am missing. Do I need to do something before pulling
> >> from upstream? How do I rectify this? Please help me with this.
> >> Thank you,
> >> Tanu Hari Dixit.
> >> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen
> >> <kuan-hsun.chen at tu-dortmund.de> wrote:
> >>> Or alternatively you can prepare simulator like qemu to executed each
> of
> >>> it after compiling the source tree.
> >>> Like this in testsuites/hello/:
> >>> qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M
> -kernel \
> >>> hello.exe -smp 4
> >>> Best,
> >>> Kuan-Hsun
> >>> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
> >>>> I use the rtems tester.
> >>>> ftp://ftp.rtems.org/pub/rtems/people/chrisj/rtems-tester/
> rtems-tester.html
> >>>> Kevin Kirspel
> >>>> Electrical Engineer - Sr. Staff
> >>>> Idexx Roswell
> >>>> 235 Hembree Park Drive
> >>>> Roswell GA 30076
> >>>> Tel: (770)-510-4444 ext. 81642
> >>>> Direct: (770)-688-1642
> >>>> Fax: (770)-510-4445
> >>>> -----Original Message-----
> >>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari
> Dixit
> >>>> Sent: Saturday, February 04, 2017 12:23 AM
> >>>> To: rtems-devel at rtems.org <devel at rtems.org>
> >>>> Subject: Regarding running one test
> >>>> Hello all,
> >>>> How do I run a single test from the testsuites? I want to run one test
> >>>> from the rtems/testsuites/fstests. How do I go about doing that?
> >>>> Regards,
> >>>> Tanu Hari Dixit.
> >>>> _______________________________________________
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
> rtems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFFM1bA&r=
> HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=zH4W9XS8-
> wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94eNhQoI76FuuhiadOC
> FEoiJ3HdxyrrQ&e=
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> M.Sc. Kuan-Hsun Chen
> >>> TU Dortmund
> >>> Department of Computer Science 12
> >>> Design Automation of Embedded Systems
> >>> Otto-Hahn-Strasse 16, Room 102
> >>> 44227 Dortmund
> >>> Germany
> >>> Phone:  +49 231 755 6124
> >>> Mail:   kuan-hsun.chen at tu-dortmund.de
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170206/0b672715/attachment-0002.html>
