git retrieval with git blocked
Cláudio Silva claudiodcsilva at gmail.com
Tue Feb 14 17:35:48 UTC 2017
Hello Joel,
The best way, I found, to use RSB behind restrictive firewalls was to
follow these instructions:
http://www.emilsit.net/blog/archives/how-to-use-the-git-protocol-through-a-http-connect-proxy/
It essentially forces all git traffic to go through a SOCKS proxy. This
works well if the firewall doesn't block SSH connections to the outside
world. However, it can be a bit slow.
Best Regards,
Cláudio
On Mon, Feb 13, 2017 at 5:49 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I am helping someone with git and ftp blocked by a firewall. That
> definitely
> limits the options. We used github for some clones using https.
> + Does rtems.org support https clone?
> + Can we do snapshots from git.rtems.org like github?
> Any RSB hints based for the firewall situation?
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170214/a0be2202/attachment-0002.html>
