Compilation error in libpci path inclusion.
Wed Feb 15 12:51:23 UTC 2017
AFAIK unless someone has added some support, the drvmgr was written by the
Gaisler folks for SPARC BSPs and that's all the BSPs that work with it so
far.
--joel
On Feb 14, 2017 11:46 PM, "John Soni Jose" <john.k at gracelabs.com> wrote:
> Hi All,
> Any inputs or suggestions to move forward on this issue.
> Regards
> John
> On Tuesday 14 February 2017 03:46 PM, John Soni Jose wrote:
>> Hi All,
>> Trying to execute PCI shell terminal task "cpukit/libmisc/shell/main_pci"
>> on an x86 machine.
>> Made below changes for including LIBPCI. The changes were made in "cpukit/
>> configure.ac" and "cpukit/libmisc/shell/shellconfig.c"
>> diff --git a/cpukit/configure.ac b/cpukit/configure.ac
>> index 3d6888c..095866e 100644
>> --- a/cpukit/configure.ac
>> +++ b/cpukit/configure.ac
>> @@ -385,7 +385,7 @@ AC_MSG_RESULT([$HAVE_SHA])
>>  # Filter libpci to only build for architectures that have support for it
>>  AC_MSG_CHECKING([whether CPU supports libpci])
>>  case $RTEMS_CPU in
>> -  sparc)
>> +  sparc | i386)
>>     HAVE_LIBPCI=yes ;;
>>     HAVE_LIBPCI=no ;;
>> diff --git a/cpukit/libmisc/shell/shellconfig.c
>> b/cpukit/libmisc/shell/shellconfig.c
>> index 11a4ff0..a676550 100644
>> --- a/cpukit/libmisc/shell/shellconfig.c
>> +++ b/cpukit/libmisc/shell/shellconfig.c
>> @@ -15,5 +15,6 @@
>>  #define CONFIGURE_SHELL_COMMANDS_INIT
>>  #define CONFIGURE_SHELL_COMMANDS_ALL
>> +#define RTEMS_PCI_CONFIG_LIB
>> diff --git a/cpukit/libpci/Makefile.am b/cpukit/libpci/Makefile.am
>> index cf336ed..a0dff03 100644
>> --- a/cpukit/libpci/Makefile.am
>> +++ b/cpukit/libpci/Makefile.am
>> @@ -41,7 +41,7 @@ libpci_a_SOURCES += pci_print.c
>>  # Driver manager PCI bus
>>  libpci_a_SOURCES += pci_bus.c
>>  include_drvmgrdir = $(includedir)/drvmgr
>> -include_drvmgr_HEADERS = pci_bus.h
>> +include_drvmgr_HEADERS = pci_bus.h drvmgr.h
>> After the above changes ran bootstrap command to regenerate preinstall.am
>> files.
>> Hitting this compilation error. The same error is happening for both x86
>> and leon2
>> "gmake[6]: *** No rule to make target `drvmgr.h', needed by
>> `../../cpukit/../../../pc386/lib/include/drvmgr/drvmgr.h'.  Stop.
>> gmake[6]: Leaving directory `/opt/RTEMS/sandbox/i386-rtems
>> 4.12/i386-rtems4.12/c/pc386/cpukit/libpci'"
>> "gmake[6]: Entering directory `/opt/RTEMS/sandbox/leon-rtems
>> 4.12/sparc-rtems4.12/c/leon2/cpukit/libpci'
>> `../../cpukit/../../../leon2/lib/include/drvmgr/drvmgr.h'.  Stop."
>> Do we need to enable any other flags for successful compilation of libpci
>> Regards
>> John
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170215/2819971f/attachment-0002.html>
